Home brew beer.
Ribenapigeon
PostPosted: 10:54 - 23 Jul 2018    Post subject: Home brew beer. Reply with quote
Would maple syrup be good for homebrew? If so how much per litre would I need to add?
RhynoCZ
PostPosted: 16:36 - 23 Jul 2018    Post subject: Reply with quote
U wot m8?
What do you mean? How? What? Shocked
owl
PostPosted: 16:58 - 23 Jul 2018    Post subject: Reply with quote
probably a good place to start
https://www.fermentarium.com/homebrewing/brewing-beer/what-does-sugar-do-to-your-beer/
Ribenapigeon
PostPosted: 17:05 - 23 Jul 2018    Post subject: Reply with quote
RhynoCZ wrote:
U wot m8?
I bought a homebrew kit. Then the instructions said i should add brew improver. I looked up the brew improver on the brew kit site and it was basically suger so im thinking rather than shell out on a bag of the stuff I could use some mapel syrup I have.
grr666
PostPosted: 18:43 - 23 Jul 2018    Post subject: Reply with quote
Shell out?
PostPosted: 20:34 - 23 Jul 2018    Post subject: Reply with quote
I would expect it to alter the taste a bit, For good or bad Thinking
There again, my one attempt at home brew beer was so disgusting I never tried it again so don't take a blind bit of notice of what I say. Laughing
Triumph Trophy Launch Edition
wr6133
It's spray malt mixed with brewers sugar. The malt gives the beer more body. You can go to a home brew shop and just buy spray malt to make the kit up with, flavour and mouth feel will be better but alcohol content will generally be less than if adulterated with brewing sugar.
Before I quit drinking I was really in to brewing, I warn you it's a very addictive hobby. Before you know it you'll have graduated from cheap kits to full grain and end up with more beer than you can give away.
MCN
PostPosted: 22:03 - 23 Jul 2018    Post subject: Reply with quote
You need water yeast and sugar to make alcohol.
Local whatever has sugar in it is used to make alcohol locally.
Grains are germinated then stopped by heating which turns the starches in the grains to sugar/malts. Alcohol is made from that. Whiskey starts off as beer.
You could probably make a mead from maple syrup.
Beer uses grains as the source of sugar for the yeast to make alcohol and what ever grains used imparts the characteristic flavour.
It's a very simple process. Not too much can go wrong until you drink all the final product. Smile
Ariel Badger
PostPosted: 00:31 - 24 Jul 2018    Post subject: Reply with quote
Guess OP is in prison in Canada.
Ribenapigeon
PostPosted: 13:05 - 24 Jul 2018    Post subject: Reply with quote
Discovered a homebrew shop near me so will give them a visit. Im very curious about the maple syrup though as I love the flavour.
johnsmith222
PostPosted: 17:19 - 24 Jul 2018    Post subject: Reply with quote
Definitely one of these guys:
https://en.wikipedia.org/wiki/Great_Canadian_Maple_Syrup_Heist
andym
PostPosted: 04:42 - 25 Jul 2018    Post subject: Reply with quote
The flavour rarely stays the same, I've only tried maple syrup once and I imagine when all the sweetness is gone you'll be left with a very bitter (and weak) alcohol.
If you plan on making 23L then you'll need about 11-12 litres of maple syrup.
MCN
PostPosted: 08:31 - 25 Jul 2018    Post subject: Reply with quote
Don't waste the MS on home brew.
Get the frying pan on whisk up some pancakes and completely slather the hoowurs in maple syrup. (As God intended.)
asta1
PostPosted: 00:21 - 26 Jul 2018    Post subject: Reply with quote
I don't know much about home brew having never done it, but at least in a standard brew from first principles (ie mashing, boiling and filtering properly from raw, dry malt etc), maple syrup could be interesting.
Off the top of my head most of the sweetness is just sucrose and will be fermented away, leaving some of the bitterness from the maillard reaction products from processing. You will gain a bit of colour and probably some additional body and mouthfeel. I'd also expect at least some additional fruity ester type character as well as caramel notes, but depends on the brand and the dose rate.
If you decide to add the stuff prior to fermentation, watch your dosing rates. Chuck in too much of this type of refined sugar and your fermentation will get stuck.
Personally, I think I'd be inclined to treat it as a late addition in FV as a priming sugar for bottle fermentation as opposed to trying to brew with it as a primary ingredient. Certainly, if your home brew involves a proper boil step, most of the interesting character will probably flash off with the volatiles, which rather defeats the object. Primary fermentation will also strip a lot of the character.
I'd shoot for maybe 5-10%(v/v) syrup added after the end of primary fermentation for optimal 'maple syrup' character.
Either way, its not th most ridiculous addition I've heard proposed, so worth a punt and let us know how it works out.
CBT Acquired: 09/07/2015
A2 Licence Passed: 12/02/16
Current Bike: Yamaha MT-07 bought 02/07/16
DrDonnyBrago
PostPosted: 12:08 - 26 Jul 2018    Post subject: Reply with quote
I've done loads of all grain home brews, started on kits.
Any time I've added a a significant amount of sugary adjunct (i.e. honey) it has brewed out bone dry and harsh as a badger's arse hole, even then I couldn't taste the honey so doubt you'll get much from maple.
Maybe as a priming sugar, use the nutritional information carbohydrate values to figure out how much you'll need to avoid bottle bombs.
Ribenapigeon
PostPosted: 14:05 - 26 Jul 2018    Post subject: Reply with quote
MCN wrote:
....... . (As God intended.)
If there is a God i would wager Kylie Minogues arse would be a higher priority target.
MCN
PostPosted: 14:27 - 26 Jul 2018    Post subject: Reply with quote
That would be sweet.
Ribenapigeon
PostPosted: 17:38 - 27 Jul 2018    Post subject: Reply with quote
I have two 6ltr brews going now. Stsrted 24 hrs ago. Bubbling away at about one bubble through the air locks every 3 seconds.
joombo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Ribenapigeon
PostPosted: 18:49 - 03 Aug 2018    Post subject: Reply with quote
All brewed now. Just need to test over the next 24 hrs to see the specific gravity is stable then filter and keg it.
asta1
PostPosted: 22:48 - 03 Aug 2018    Post subject: Reply with quote
Don't know if you do already, but if you can make it fit, 6-12 hours in the fridge as a 'crash cool' step will do wonders for your yeast flocculation and the eventual clarity of the product.
What's the yeast strain by the way and how are you filtering?
Ribenapigeon
PostPosted: 23:47 - 03 Aug 2018    Post subject: Reply with quote
Ive got a 0.5 micron water filter im going to pump the beer through. Its the kind used to filter tap water. It needs a bit of pressure to use so im going to pick up a hand pump pressure sprayer vessel from B&Q to force the beer through the filter with.
asta1
PostPosted: 00:10 - 04 Aug 2018    Post subject: Reply with quote
Hmm, sterile filtered home brew. Interesting. No reason it won't work, but you might end up blinding the filter pretty quickly with the yeast and cold break. Have you used it before in this application?
I'd expect a fair reduction in CO2 level as well after that sort of process, not to mention a fair bit of O2 take up. Hows the shelf life? Do you get papery off notes?
Ribenapigeon
PostPosted: 08:57 - 04 Aug 2018    Post subject: Reply with quote
I haven't tasted it yet. I might filter it twice as I also have a lower rated filter for bigger particles. Maybe use that first then go 0.5mn to finish it.
There is a gap of 334 days between these two posts...
Riejufixing
PostPosted: 23:29 - 04 Jul 2019    Post subject: Reply with quote
Well, I was going to ask whether anyone "does" homebrew.
The end of this thread seems to imply "I did, once....". I wonder what happened...
The last post was made 7 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 125.74 Kb
