Honda CB125 TD Rev Counter Broken
ajordan9
PostPosted: 09:59 - 25 Jul 2018    Post subject: Honda CB125 TD Rev Counter Broken Reply with quote
Hi all,
So I just got myself a Honda CB125 TD 1983 model last week with a few little issues I need to work on. Although I don't have much experience with bike maintenance I plan on learning as I go.
So my first issue I plan on tackling is the rev counter. It doesn't seem to want to work! Although the speedometer on the left of it works fine.
I followed the cable from the right hand side rev counter and the cable looks attached and in reasonable condition. But obviously I realise that means nothing.
Do you have any ideas I can start going through?
Thanks,
jaffa90
PostPosted: 10:02 - 25 Jul 2018    Post subject: Reply with quote
Does the inner cable rotate at both ends?
ajordan9
PostPosted: 10:05 - 25 Jul 2018    Post subject: Reply with quote
So to test that I would just unscrew both ends where they're connected and see if the inner twists right?
jaffa90
PostPosted: 10:15 - 25 Jul 2018    Post subject: Reply with quote
Yes, turning the inner cable at one end should turn it the other end, if not then a new cable complete for a tenner.
Teflon-Mike
tl;dr
PostPosted: 22:35 - 25 Jul 2018    Post subject: Reply with quote
Take off the cable gearbox end, and tacho-end.
Cable should rotate the same amount at both ends if you give one a twist... if it isn't more obviousely snapped and half a cable drops out the sleeve!
Be careful of the primary drive retaining screw; it's often siezed and rounds off easily.
Beneath is the cable drive, which is a very thin brass slot that the cable end slots into the middle of.
Common for numpty mechanics to fit the entire cable this end and push home the outer into the case and expect the inner to find the slot on its own.... seldom does. Consequently the drive goes round and round with the engine and doen't turn the cable; in worse cases the drive can wind up the cable trying to shove it out the way, and either inner cable and or the drive slot can get damaged... In which case you get no taco, or an erratic one.
Only way to tell is to take it off and have a look.
More beware that screw; outer cable has a groove in it where retaining screw should go; if screw chewerd or mangles often not fitted and drive end floats out and as above cable end or drive can easily get mangled. But also common for cable end to be hammered into the housing, in a oner with inner and NOT engage with drive slot, and forcing it damages both, whilst cable end NOT properly seated, and the retaining screw rammed home above or below or ommitted altogether.
In the most dire cases, the tacho takes its drive off a worm gear on the oil-pump; from Snowies Handy-How-To's:
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/100_0476.jpg
You can just see it, just there above her hand holding the rubber retainer out the way whilst she removes manky oil strainer.
That worm is metal, and can apply enormouse drive pressure from the 'reduction' it puts on the nylon pinion on the end of the tacho-drive in the primary drive cover.
If the cable is old or kinked and allowed to 'snag', and or primary case badly fitted, then that worm gear will tend to strip teeth off the nylon pinion; and no turn tacho cable.
OR could be in the tacho head.... the spring could be broke.. would tend to send needle round to the red-line and stay there regardless of engine revs... rather than not budge at all, but? Old bike, who knows.
Check obvious easy first, work from there; and snapped cable IS the most likely, obvious and easy to check.
ajordan9
PostPosted: 15:14 - 26 Jul 2018    Post subject: Reply with quote
So I took off the Tacho cable which goes from the head unit to the engine beside the oil plug. Spinning one end resulted in the same spin on the other end. I even took out the inner and degreased everything and lubed it up (being careful to keep the ends dry as per the Haynes manual instruction).
This is what either end looks like, a bit of degradation to the engine side but not sure how bad it is:
https://ibb.co/dX0R4T - engine side
https://ibb.co/gW1AW8
https://ibb.co/gGRAW8 - speedo side
Re-attached and sadly no joy.
Teflon - Im interested in your info, firstly thank you for this. When trying to peer inside the darkness of the tacho/engine end I couldn't really see how the cable attached into the hole and how to ensure it was connected properly. It looked like there was a circular pin type thing inside. Where exactly does the end need to go?
Thanks,
WD Forte
PostPosted: 15:56 - 26 Jul 2018    Post subject: Reply with quote
I've tested this type of tacho by using a cordless drill and a short length of some stiff-ish electrical cable or similar in the chuck.
It should fit snugly into where the cable usually goes
Running the drill anti clockwise as you look at the rear of the tacho should get the needle to move up a bit if the tacho mechanism is OK.
Dont worry the drill wont go fast enough to damage the tacho
its magnetically driven internally anyway
If the needle moves when you do this and cable is Ok then I'd
suspect the problem lies in the worm drive at the end of the camshaft
If it is you may want to live without it unless moneys no problem Laughing
bikers smell of wee
ajordan9
PostPosted: 16:10 - 26 Jul 2018    Post subject: Reply with quote
Hello WD, thanks for jumping in.
Im confused about the electrical cable stuff? Where am I sticking that? Over the end of the engine side tacho cable? Just to protect the cable end?
Teflon-Mike
tl;dr
PostPosted: 17:54 - 26 Jul 2018    Post subject: Reply with quote
https://images.cmsnl.com/img/partslists/honda-cb125td-superdream-1982-c-ireland-right-crankcase-cover_big00028371e__0600_9222.gif
Tacho drive is part 3, Should look like two tangs from the top, not a disc. If disc... tangs be broke,
To fit up cable: Slide inner out of outer at the engine end, maybe 3 inch.
slot cable end into drive in the case. make sure properly centered and seated.
Slide outer down inner cable, and bring the retained end down over the drive and into its rebate.
Fit screw... may mean wiggling cable outer bulb up and down a little to line up groove.
that way everything lines up as it should. Try pressing inner and outer into drive hole together, then cable wont always line up with slot, and drive tangs can get bent/broke.
Make sense?
WD Forte
PostPosted: 19:30 - 26 Jul 2018    Post subject: Reply with quote
You stick it in the hole where the tacho cable comes out in order to test drive the tacho
Remove cable from tacho, look uo hole.
you'll see a square hole and
this is what you need to drive.
2" of stiff cable, plastic rod etc should be strong yet flexible enough to drive it without damaging anything.
OR
you might be able to drive the cable from the engine end
if enough protudes and you can grip it
OR
use a bit of dowel and saw for an impromptu driver bit
bikers smell of wee
jaffa90
PostPosted: 23:21 - 26 Jul 2018    Post subject: Reply with quote
Tacho / engine rev counter !
Why bother on a 30 odd year old bike??????
Teflon-Mike
tl;dr
PostPosted: 00:32 - 27 Jul 2018    Post subject: Reply with quote
Why bother with the tacho on ANY bike?
Personally I find one more useful than the speedo, but still. Dont really need either.
On the CB125T though, which revved to a heady 14ooo rpm, which is STILL pretty high by modern standards, and at the time was at least 30% or more higher than the two-strokes of the era, it was, and still is, pretty audacious for an air-cooled, two valve four-stroke, and almost ANY four-stroke 125!
And pretty much the defining feature of the little twin!
So rather nice to see a tacho needle up in those sort of numbers from time to time!
Also tends to encourage using the gearbox and not short-shifting like you might on a CG!
ajordan9
PostPosted: 15:18 - 30 Jul 2018    Post subject: Reply with quote
Hey sorry about the radio silence, busy end to the week.
I think my issue is even after your description of where the tacho/engine side cable goes I cant physically see where it goes! I don't know if im being stupid or not...
So I managed to stick my phone in for a few pics... There genuinely doesn't seem like a 'slot'.
https://ibb.co/kopgeT
https://ibb.co/nMaMeT
https://ibb.co/dHbSKT
This seems to be some kind of spindle, no where to slot anything into. Is that thing right in the middle mean't to be there? The big that is raised right in the middle of the spindle? Or has the old tacho broken off?
The only slot type thing is right on the edge but thats just where the screw seems to go to hold the cable in place.
Thanks!
Teflon-Mike
tl;dr
PostPosted: 19:33 - 30 Jul 2018    Post subject: Reply with quote
https://cdn.bcf.44bytes.net/files/tach_drv.jpg
Sorry 'slot' is on the cable end; tang is on the engine end. That's what it 'should' look like, and the tang, aght be about 15mm deep or so. (Should also be brassy colour; that one black cos wasn't masked when motor painted)
Looks like yours 'may' be snapped off, and you need new tacho-drive.
What's the cable end look like?
jaffa90
PostPosted: 21:28 - 30 Jul 2018    Post subject: Reply with quote
Could it be this cable.
https://www.ebay.co.uk/itm/Tacho-Cable-Honda-CB-125-K5-1972-1975/362053259730?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3Ddf80815d4e634a51801cf69bb9137d38%26pid%3D100290%26rk%3D1%26rkt%3D4%26sd%3D362053259730%26itm%3D362053259730&_trksid=p2060778.c100290.m3507
Teflon-Mike
tl;dr
PostPosted: 23:03 - 30 Jul 2018    Post subject: Reply with quote
jaffa90 wrote:
No; is the short answer: Op Says he has a 1983 CB125TD-C Super-Dream; the Second generation 125 'Twin'. Your e-bay link actually says, '72-'75 CB125K, the earlier, by a decade, 'single'
Tacho Cable Honda CB 125 K5 (1972-1975)
Part Number: 731.93.87
From CMSL, microfishe: HONDA CB125TD SUPERDREAM 1982
CABLE,TACHOMETER
product number: 37260KC1000 supersession: 37260MC9830.
Different part numbers, for different bikes, of very different designs.
jaffa90
PostPosted: 23:14 - 30 Jul 2018    Post subject: Reply with quote
I meant the cable ends, the drive has a spade end and the type i posted looks like it will take one.
The last post was made 8 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 106.73 Kb
