Keeway RKS side light bulb
harrow
PostPosted: 13:52 - 25 Jul 2018    Post subject: Keeway RKS side light bulb Reply with quote
Hello, it will soon be mot time and I need to fix one of the two side light bulbs, on a Keeway RKS 125 side light bulbs.
I removed the indicator panels on the left and right of the headlight a total of four screws.
I removed two screws on the rear of the headlight that.
The headlamp lens seems to be well attached ?
But do I have to remove the headlight front lens to get at the bulbs, or do I have to remove the whole headlamp to take it apart ?
https://www.puzey.co.za/spares/Keeway%20RKS%20125%20-%20250/framePartsCatalogue.pdf
harrow
PostPosted: 17:03 - 25 Jul 2018    Post subject: Reply with quote
Well am still not sorted out but doing more research why are motorcycle headlight and side light bulbs so awkward to replace.
I thought there was an EU ruling that bulbs had to be replaceable at the roadside ?
If anyone knows about this keeway rks bulb ?
iooi
PostPosted: 18:23 - 25 Jul 2018    Post subject: Reply with quote
Looks like you get at it from the rear.
harrow
PostPosted: 18:34 - 25 Jul 2018    Post subject: Reply with quote
Yes thank you, it might well be that way at least for the main/dip headlamp bulb.
I was just trying to limit how much I have to take apart.
If anyone knows how to change a keeway rks sidelight bulb ?
harrow
PostPosted: 12:17 - 26 Jul 2018    Post subject: Reply with quote
Bump
Evil Hans
PostPosted: 13:14 - 26 Jul 2018    Post subject: Reply with quote
Can you get your phone in behind and take a couple of (flash) pics ... it might give you an idea of what you are trying to get your fingers on!
Riejufixing
PostPosted: 13:26 - 26 Jul 2018    Post subject: Reply with quote
Bump
If you can't find a manual online try asking Keeyway, or just ask a dealer. It can't be rocket science!
Failing that, there's probably some easy way of taking a big piece of plastic off.
When you find how to do it, do post a write-up! Smile
Riejufixing
PostPosted: 13:27 - 26 Jul 2018    Post subject: Reply with quote
Posting them here would help guesswork too...
harrow
PostPosted: 14:39 - 26 Jul 2018    Post subject: Reply with quote
Riejufixing wrote:
Bump
Will let you all know, what seems surprising is each model of bike is so different and such hard work to reach the bulbs which are normal service items.
harrow
PostPosted: 17:15 - 26 Jul 2018    Post subject: Reply with quote
pictures
Evil Hans
PostPosted: 17:17 - 26 Jul 2018    Post subject: Reply with quote
harrow wrote:
pictures
no pictures
harrow
PostPosted: 17:24 - 26 Jul 2018    Post subject: Reply with quote
pics
https://ibb.co/bDSj8o
https://ibb.co/k3XHTo
https://ibb.co/nMGBoo
https://ibb.co/dRrBoo
https://ibb.co/ekXCuT
https://ibb.co/cCLbM8
https://ibb.co/mYkbM8
https://ibb.co/i7yroo
https://ibb.co/jVvhuT
https://ibb.co/i8CvET
https://ibb.co/iftroo
https://ibb.co/jmn1oo
https://ibb.co/ed9goo
https://ibb.co/mU3JZT
https://ibb.co/h1hvET
https://ibb.co/jLjWoo
https://ibb.co/jvCHTo
harrow
PostPosted: 11:50 - 31 Jul 2018    Post subject: Reply with quote
Solution.
remove the 4 cross head screws that attach the front indicators and plastic headlamp shroud,
remove single 10mm bolt below headlamp.
remove with allen key ignition switch shroud.
beneath shroud remove two 10mm headlamp top fixing bolts.
pull headlamp forwards.
see 2 5watt 501 sidelight bulbs.
assembly is a lot slower to get everything back correctly.
Riejufixing
PostPosted: 12:15 - 31 Jul 2018    Post subject: Reply with quote
Well done harrow! It might help someone else who encounters the same problem., There's always a first one.... "you're it!" Smile
The last post was made 8 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 80.42 Kb
