| oldbeaver |
 oldbeaver L Plate Warrior
 Posted: 23:34 - 25 Jul 2018 Post subject: The single cylinder motorbike tacho problem. |
Hello everyone! I have a single cylinder Suzuki GZ150A, very nice, quiet, look bigger. It doesn't come with a factory tachometer.
I installed a universal analog tacho and feed it with the pulse signal of the coil.
As the engine is a four stroke, it has one spark every two revs, therefore, my tacho shows half the real revolutions of the engine. It just shows the pulses it receive. Not a fault, it says the true.
Was it a two cylinders, it would work fine.
I don´t know what would happen with a three cylinder or a four cylinder bike. There is no manual attached.
Now, how can I fool the tacho and make it show double as much pulses, meaning the real revs?
That is my question. Sorry for my limited English.
Some people has diesel trucks which don´t have tacho either. They get a signal from the alternator. Do you think guys that a motorbike alternator produces pulses suitable for tacho purposes?
Greetings to all and my wishes od good biking. |
| Riejufixing |
 Riejufixing World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 12:53 - 26 Jul 2018 Post subject: |
I've bought a cheapo tach that's for cars as an experiment. I'm betting on it being a frequency to voltage chip like an LM2907, and the 4-6-8 cylinder selector switch is just a different resistor value to adjust the scale. If I'm right, it'll just be a case of sticking a variable pot in to replace the switched resistors, find the value that works, and sticking in a fixed one. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| weasley |
 weasley World Chat Champion
| stinkwheel |
 Posted: 13:48 - 26 Jul 2018 Post subject: |
Have you checked in the back for a DIP switch or moveable jumper connection or in the connector for a looped wire (that may be designed to be cut in some circumstances)?
Been a long time since I looked into them but most aftermarket tachos will have two modes, either single spark per cycle or a wasted spark.
Doesn't really matter how many cylinders it has, the coil generally pulses either once or twice per revolution. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| oldbeaver |
| oldbeaver |
| Pete. |
 Pete. Super Spammer
 Posted: 21:45 - 26 Jul 2018 Post subject: |
Remove dial, place on scanner, import to PC, open in GIMP/Photoshop etc, edit image to adjust the RPM scale, print on glossy paper, glue glossy paper to dial, re-assemble tacho and fit. ____________________ a.k.a 'Geri'
| The Shaggy D.A. |
 Posted: 22:50 - 26 Jul 2018 Post subject: |
...except if the rev counter is calibrated for 4 cylinders and you only have one cylinder that red lines at 6000, the needle will only be using a quarter of the scale and be pointing where the 1500 was. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Pete. |
 Pete. Super Spammer
| WD Forte |
 Posted: 01:12 - 27 Jul 2018 Post subject: |
You took the innards out and they broke eh?
and you fucked about with the pot which is for fine tuning/adjustment/set up, I'll bet
You are Frank Spencer and I claim my five ponds
In case you're not trolling
"As the engine is a four stroke, it has one spark every two revs"
Your bike, like many, gives one pulse/spark per revolution
RTFM! I did
I bet that car tacho like the one I have, is designed for 2/3/4 pulses per rev
( 4 /6/8 cylinder car engines) ____________________ bikers smell of wee |
| weasley |
| Teflon-Mike |
 Teflon-Mike tl;dr
| WD Forte |
| oldbeaver |
The last post was made 8 years, 92 days ago. Instead of replying here, would creating a new thread be more useful? |
