| johnsmith222 |
 johnsmith222 World Chat Champion
| Fin |
 Fin World Chat Champion
 Posted: 22:03 - 24 Jul 2018 Post subject: |
Replaced the scary stretchy chain with something decent. Then went to tighten both mirrors as they were caving in when going fast.
First one I snapped my dads shitty allan key inside the bolt.
https://i.imgur.com/1Dfq4hD.png
With the 2nd mirror the thread was stripped so I went to remove the mirror and the mount fucking broke completely. This would only happen to me
https://i.imgur.com/cP4k5p4.png |
| recman |
 recman World Chat Champion
| DrDonnyBrago |
 Posted: 12:25 - 26 Jul 2018 Post subject: |
Changed the oil in my steering damper. Was notchy on steering as it was full of air.
Out came about a tbsp of brown cat piss, in went some nice blue 5wt fork oil. Much better.
Did it like this, just need to move it back and forth a lot until all the bubbles are gone and it feels smooth:
https://wotid.com/pictures/albums/userpics/10001/damper_01_800.jpg |
| AshWebster |
 AshWebster Brolly Dolly
| kramdra |
 kramdra World Chat Champion
| ThatDippyTwat |
| DrDonnyBrago |
| Hong Kong Phooey |
| kramdra |
 Posted: 12:32 - 27 Jul 2018 Post subject: |
I have decided to use brass nuts. Did not have any. Half inch hex bar is no good.. All my tools are metric. Why did I buy it, other than cheaper?! Making 12mm, drilling tapping and parting. These will be blind nuts to seal the stud from winter salt.
https://s20.postimg.cc/cyhi90au5/IMG_20180727_122415.jpg
Will use straight M8 studs, unfortunatlty they are genuine honda. I did not ask wemoto what they were. If anything like the reducing studs these will also be made of cheese.
https://s20.postimg.cc/ak3eu7jfh/IMG_20180727_161053.jpg
Test fit all good. Studs installed with copper grease and a quick spray with silver paint to seal the last turns of thread.
| ThatDippyTwat |
| waffles |
 waffles World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:05 - 27 Jul 2018 Post subject: |
Stuffed some paper in between the seals on the leaky racebike fork leg, herded air back into the tyres, and took it for a ride for the first time in weeks.
First 5 minutes: what a stupid bike. It's gutless and it's annoyingly loud with the chavcan on it and you have to change gears all the time, I should just try and sell it to some mug.
Last 55 minutes: HAAAAAAAAHAHAHAHAHAHAHA, what a stupid bike. Redline it in every gear, keep it screaming like a Northern schoolgirl, any gap's a goal, I'm never being a mug and selling this thing.
I'm such a tart. Whatever I've just ridden is my favouritest bike ever. ____________________ Biking is 1/20th as dangerous as horse riding.
| Johnnythefox |
 Johnnythefox Traffic Copper
| recman |
| Fin |
 Posted: 23:21 - 27 Jul 2018 Post subject: |
https://i.imgur.com/lckl1Np.png
https://i.imgur.com/pSierAy.png
Desperate attempts to quieten the exhaust so I could get onto the track. It actually worked quite well really while it was in the garage. Fortunately there wasn't a static noise test and they'd just black flag anyone who was too noisy. The fibreglass must have held up okay for the 100 or so miles to the track as it started to shoot out while on the track
Apparently it was going everywhere |
| kramdra |
| andym |
 andym World Chat Champion
| kramdra |
| sickpup |
 sickpup Old Timer
 Posted: 17:47 - 01 Aug 2018 Post subject: |
59 plate Deauville
In the never ending story of sorting this one I have moved onto the rear end.
The bottom shock eye had some play, only about 2 mm so I thought I better sort it. Bits ordered and arrived, try to take rear shock off and the bottom bolt is seized solid. So remove bevel box, remove drive shaft and try and remove swing arm and yep it's seized solid.
A lot of huffing and puffing and 24 hours later we are left with this
https://www.bikechatforums.com/download.php?id=101360
which needs to go off to an old man in a shed to be seperated and have the new bearing pressed into place. |
| Wheezybiker |
 Wheezybiker Nitrous Nuisance
| Fin |
 Posted: 21:33 - 03 Aug 2018 Post subject: |
Put it in the garage, started to close the door and it fell over
footrest snapped off
That will give me something to do tomorrow.
https://i.imgur.com/RFyZQZm.jpg
I always put the bike on the centre stand so my guess is that in frustration of being very hot and sweaty I stood on the centre stand too hard causing it to bounce, rock forward enough to come off the stand then topple over. |
| ThatDippyTwat |
 Posted: 23:11 - 03 Aug 2018 Post subject: |
VFR750 -
Replaced all the Dzus fastners and some of the clips. Added the missing ones.
Replaced starter solenoid/Fuse assembly - This had signs it had been very toasty at some point.
Oil & Filter.
Sticker on the fuel cap - it was looking a bit grim.
Wound up neighbour that was bitching about the "Obviously illegal" end can up by showing him the relevant stamped numbers on it.
Debated adding phone mount - CBA.
Looked at the two broken studs I have discovered - CBA.
Made more noise for the grumpy old curmudgeon to whinge about.
Tomorrow for replacing the studs, maybe phone mount if I have any will to live left after doing the studs.
125 -
Had it inspected for the insurance. No issues.
Chain lube and tension.
Discovered carb needs a clean, again. Tank is likely full of shit. Looking to remove it and seal it. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 16:21 - 05 Aug 2018 Post subject: |
| ThatDippyTwat |
The last post was made 8 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
