| DrDonnyBrago |
 Posted: 17:35 - 29 Jul 2018 Post subject: Fork pinch bolt seized, snapped off... |
Hi all,
Doing fork oil, bike is new to me (2004 sv1000s). Fork pinch bolts were all insanely tight and very corroded, three came out, one snapped off. Fork is now off the bike. Plus gas and cutting a slot in the back of the bolt for an impact driver did fuck all, the bolt steel is very soft and there are no signs of it budging. It's just getting more and more chewed up.
As such I think it needs drilling out, or welding to a nut etc etc by someone with a more advanced skillset and toolset than I.
Best place to take it? Garages, engineering firms? What sort of business am I looking for?
I'm in Southampton if anybody can suggest a specific place, otherwise general suggestions would be appreciated.
Cheers,
Donny
https://i.imgur.com/lRoYBQKh.jpg
| recman |
 recman World Chat Champion
| J4mes |
 J4mes World Chat Champion
| Islander |
 Islander World Chat Champion
 Posted: 20:35 - 29 Jul 2018 Post subject: |
You also have the option of dissolving the bolt out of the fork bottom by using a strong hot alum solution. Plenty of information on Google and Youtube.  |
| redeem ouzzer |
| Riejufixing |
| Riejufixing |
| kramdra |
 kramdra World Chat Champion
 Posted: 07:33 - 30 Jul 2018 Post subject: Re: Fork pinch bolt seized, snapped off... |
| DrDonnyBrago wrote: | Hi all,
Cheers,
Donny |
If the slot is still there in the bolt, hit the yoke with a blow torch and you'll soon be able to wind it in with a screwdriver. Don't melt the ally yoke, rub soap around the area and when the soap turns black it's time to stop heating. ____________________ a.k.a 'Geri'
| DrDonnyBrago |
| Islander |
 Posted: 09:41 - 30 Jul 2018 Post subject: |
Not sure about the chemistry, but it needs to be as concentrated as you can make it and hot (close to a simmer) for it to work effectively. Obviously, you'll need an aluminium, glass or ceramic container. Some people advocate drilling a hole into the steel part to give a greater surface area to attack as well.
It's an old watchmaker's trick for removing steel screws from a brass component  |
| recman |
| Riejufixing |
| fatjames |
 fatjames World Chat Champion
 Posted: 12:50 - 30 Jul 2018 Post subject: |
I wonder if the bolt is binding due to the gap. Maybe try clamping it together / putting the other bolt back in to bring them together?
Hard to explain what I mean. Highly skilled artist's impression:
https://i.imgur.com/qxRsafh.jpg |
| DrDonnyBrago |
| DrDonnyBrago |
| J4mes |
| DrDonnyBrago |
| Riejufixing |
| recman |
| skatefreak |
 Posted: 16:29 - 30 Jul 2018 Post subject: |
Curious here as well...
Had a crash bobbin bolt bend right over & snap almost flush... well and truly stuck in an the engine mount...
Almost had the front wheel off the ground with fancy easy out rod type thingy so eventually figured snapping that in there would make it even worse so hammered it out, drilled clear through and whacked a nut on the end of a longer bolt...
Not saying it's right but does the job  |
| recman |
 Posted: 16:36 - 30 Jul 2018 Post subject: |
| skatefreak wrote: | Curious here as well...
Absolutely. There are plenty of methods to remove a sheared bolt, I once sacrificed a long pozi screwdriver because the bolt was out of reach of my extractor. |
 Posted: 17:01 - 30 Jul 2018 Post subject: |
My local guy took 45 similarly stuck fork brace bolts out of a set of fork lowers for me using his milling machine. Milled the centres out to the point he could collapse the threads in then ran a tap up the middle.
I really do want to try the hot alum thing myself some time though and that particular part would have loaned itself nicely to it. I've done the opposite by dissolving a stuck alloy seapost out of a steel bike frame with caustic. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Suntan Sid |
 Posted: 18:06 - 30 Jul 2018 Post subject: |
The alum trick is one of those things that work better in theory than in practice. If you have an expensive alloy part that absolutely must not suffer any damage at all - such as a complicated part you've machined and snapped a tap off in one of the holes - it's the stuff to use (or sinker EDM).
For a cylinder head or fork lower - drill it out! Dissolving with alum is like trying to get somewhere by hitching a ride on a glacier. ____________________ a.k.a 'Geri'
The last post was made 8 years, 90 days ago. Instead of replying here, would creating a new thread be more useful? |
