advice
timbuck
PostPosted: 21:18 - 28 Jul 2018    Post subject: advice Reply with quote
hello, ive just got a lexmoto ht 125 Very Happy (dont laugh) and i was wondering if i can change the handlebars for a different style , sorry if i sound green but i havent had a bike for over 30 years, many thanks.
tim<>
kgm
PostPosted: 21:33 - 28 Jul 2018    Post subject: Reply with quote
You can, just be careful of altering cable routing as you don't want them catching or sticking and you don't want to stretch them too far.
Why do you want to change them?
arry
PostPosted: 21:39 - 28 Jul 2018    Post subject: Reply with quote
Probably because the standard ones are gopping. They look like a child's trike.
timbuck
PostPosted: 21:49 - 28 Jul 2018    Post subject: Reply with quote
i want to change them for a straighter handle bar because as kgm said they do resemble a kids trike, i just wanted to know if the grips and levers would go straight on another set.
tim<>
arry
PostPosted: 21:56 - 28 Jul 2018    Post subject: Reply with quote
Same internal diameter bars and you'd be fine. You might struggle to get the grips off without damaging them depending on how well they've been bonded.
WD Forte
PostPosted: 00:04 - 29 Jul 2018    Post subject: Reply with quote
You've been off a bike for 30 years and have no idea that most bikes use 7/8"-22mm bars.
My advice
Never mind the looks just get on and ride the fecker
Those bars with their high wide mirrors will give better rear visibility Then low narrow bars which will let you see your elbows
and sod all else.
bikers smell of wee
timbuck
PostPosted: 11:56 - 29 Jul 2018    Post subject: Reply with quote
thanks for everyones advice . much appreciated Thumbs Up
tim<>
fatjames
PostPosted: 11:14 - 30 Jul 2018    Post subject: Reply with quote
Order new grips too. Getting the old ones off will be a pain.
Make sure you'll have clearance with the screen / tank.
You don't want the cables to be too short, so check from lock to lock. If the throttle cable is to short, turning the bars might rev the engine / brakes could be applied slightly.
If they end up longer, make sure they're not going to catch on anything.
You'll want to make sure any handlebar mounted reservoirs end up level. If you're dropping in height, you might need to remove some brake fluid too.
The last post was made 8 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 54.41 Kb
