| Rozay |
 Rozay L Plate Warrior
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:51 - 30 Jul 2018 Post subject: |
Try charging the battery, or kick-starting the engine.
Starter motors suck maybe 10x the nominal ampage rating of the battery.
That looks like a 4Amp-Hour battery. Charging system, might deliver something like 35W or 3A at 'peak' charging revs; probably around 3,000. So it would take the generator, working full pelt, over an hour and a half to charge that battery from completely flat. On a 4A mains work-shop charger, it would still take probably 8hours to charge fully from fully flat, as the ampage delivered will fall as the battery accepts charge, so it will only take 4A for the first few moments, then the rate will start to drop, and it will take much longer than notional amp-hour rating to fill.
Common issue on little bikes; especially CG's that were never intended to have big 40A sucking starter motors on them, let alone sat-nav or smart-phone chargers sucking more of available electric.
Basically they don't make enough electric to replace in battery during running, what you likely take out during start and run, and problem is even worse if the engine never gets thrashed, and you rarely make peak charging revs; toddling around short shifting up the box, rarely letting the thing rev out, or holding higher revs it just wont make the charge. Do lots of short hops and stop-starts and use the e-start sucking 10x the amps the genny can make at peak, you have little chancs it will keep the battery topped up. Start wiring on additional accessories to charge your phone or use a sat-nav... well, you were starting from over-draft before you began, that's maxing out the credit card, and no wonder bank-manager shouts 'enough! Over-Draft limit exceeded!'
This is even more common on Chinky clones where the build quality and component quality isn't wonderful to start with; so no great surprise really.
Charge battery, on a bench charger; remove the accesory sockets and thrash the thing a bit!
IF you still have problems, then likely a new battery is in order; deep-discharging batteries, IE using starter motor.. when battery not near fully charged, will kill them in quick-time, and good odds your battery is long past its best... if it was particularly great to start with.
Get new; follow instructions to fill with acid; charge; check acid level; leave to settle; put back on charge, to be sure properly charged; repeat as necessary until acid level dont drop; THEN maybe a day later, think about fitting to bike...
THEN if you give it a chance; don't hammer battery on the e-start; dont suck more amps from it than needed trying to run smur-phone chargers etc; give the genny a chance and let the motor rev, and give it some longer runs to give it chance to put back charge... IF then you still have issues, then might be time to look at regulator or generator or other things... BUT until the usual suspects are eliminated, its PROBABLY them... ie a flat, knackered battery, never properly charged from over-load of short hop rides and excessive e-starts and bolt on electrical accessories! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| jaffa90 |
 jaffa90 World Chat Champion
| Rozay |
| jaffa90 |
| Riejufixing |
 Riejufixing World Chat Champion
| Rozay |
| Riejufixing |
| Rozay |
The last post was made 8 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
