| DEADmetal |
 DEADmetal Borekit Bruiser
 Posted: 05:58 - 02 Aug 2018 Post subject: Aprilia RS 125 - powerband narrowed |
I've got a new shape 2006 RS 125 fullpower. Got the bike when it had only 2k miles clocked. Now it's nearing 3.5k miles.
Before this problem occured, it pulled very strongly, up to 11k RPM (after which the power drop was very sudden). It had a solid top speed of 100 mph indicated. After riding it some (just about 200 miles), it lost power at 11k RPM and started pulling only up to 10.5k RPM (in higher gear), after which, it basically had no power. This powerband difference was very evident. It would not reach 11k RPM in 3rd and higher gears, when before, it reached 11k RPM explosively.
To solve this problem, I've tried:
1. Cleaning PV multiple times.
2. Keeping PV open permanently by using zipties.
3. Using blanking plate instead of PV.
4. Decatting the exhaust and completely emptying the expansion chamber, as well as cutting off the exhaust appendix (which, as I was told here on the forum, acts as a restrictor).
Only the exhaust mod made any difference in powerband. It now pulls up to 10.6k, instead of 10.5k, but it's still evidently lacking.
The power at say, 9k RPM, 10k RPM, or 10.3k RPM seems to not be lost, compared to how it was when I first started riding it (when it had high power up to 11k RPM). The problem is that it doesn't have power up to 11k RPM any more. The top speed has also suffered, obviously.
I'm thinking, if the carb would be clogged, the symptoms would be much more restrictive. Correct me if i'm wrong though. Could it be an electrical problem? Perhaps I should also mention that the CDI is taped over. Could it be so that something has been done to the CDI (a mod) and after I've ridden the bike for some time, this CDI mod failed?
While the symptoms of this problem are requiring a detailed explanation, hopefully, this post doesn't confuse anyone. In case something needs clearing up however, I'll try to rephrase it. |
| P.addy |
 P.addy Red Rocket
 Posted: 09:57 - 02 Aug 2018 Post subject: Re: Aprilia RS 125 - powerband narrowed |
| DEADmetal wrote: | I've got a new shape 2006 RS 125 fullpower. Got the bike when it had only 2k miles clocked. Now it's nearing 3.5k miles.
Do the bike WAS working fine with all its bits intact, then it started to not work OK so your solution is to cut bits off it. Now you're in a pickle because you might never know if you find the fault because your general configuration has changed. What you should have done is fixed the fault and THEN started fiddling with your setup. ____________________ a.k.a 'Geri'
| Yeti |
 Yeti Trackday Trickster
| skatefreak |
 Posted: 11:37 - 02 Aug 2018 Post subject: |
Not cleaned out the carb?
Clean out the carb before making permanent changes .
A minor fuel restriction can effect high RPM only so it's not unlikely.
It doesn't sound like you've introduced new problems yet but you need to improve your trouble shooting approach.
What could have changed to alter the performance of the bike?
The cat? Not likely. Stripping and cleaning the PV Maybe... but pinning it?
Failed CDI's usually stop a bike...
It sounds like you've ventured down the route of 'improving' the standard setup than trying to fix the problem now?
The thing with carbed bikes though is the first step to any running issue...
Service The Carb(s)! |
| DEADmetal |
 Posted: 15:37 - 02 Aug 2018 Post subject: |
| Paddy. wrote: | 2006, so 12 years old. 3500 miles.
Under 300 miles a year, so it's going to have sat around for a while. When was the rebuild done and what's the compression like on it now, use a decent compression tester. |
I've got it back in 2016. It sat around for almost 10 years before that. I didn't ride it much since, because of this problem and lack of time to attend to it, but it rode perfectly fine when I got it. So this problem shouldn't be related to it sitting for so long? Didn't check the compression but i'm going to do so in a few days hopefully (don't have the compression tester yet).
| Pete. wrote: | Do the bike WAS working fine with all its bits intact, then it started to not work OK so your solution is to cut bits off it. Now you're in a pickle because you might never know if you find the fault because your general configuration has changed. What you should have done is fixed the fault and THEN started fiddling with your setup. |
Well the only thing that has changed is a freed up expansion chamber. This can't possibly impact power in a negative way, speaking of FP bike.
| skatefreak wrote: | Not cleaned out the carb?
Clean out the carb before making permanent changes Rolling Eyes.
Failed CDI's usually stop a bike... |
Didn't clean out the carb. To be honest, I was avoiding opening it but now iI guess I'll have to. I'm reasoning that it can't be due to a clogged carb because the bike had only slightly more than 2k miles when the problem occurred, so not enough mileage for it to clog. Secondly, I think it would be a very unlikely scenario for a clogged carb to reduce the powerband just by 0.5k RPM, from 11k RPM. I'm not an expert however.
One more thing I should mention is that it's PV controller stopped working just when this problem appeared (can't remember if the two problems happened at once). So I've used another PV controller, from the new shape RS 125 of the same year. Both controllers have "7800" marking on them. That couldn't have influenced the powerband problem in any way, right?
Again, I stress that the CDI is taped over, so something must have been done to it. I've heard of derestricting fullpower CDIs, to get even more power. Can it be done? If so, perhaps the previous owner done that but his mod failed when I was riding the bike, and so it hasn't stopped CDI from working, just defaulted powerband to factory settings. Is it any likely?
--- edit:
No rebuild was ever done. The bike is basically as was from the factory. Could the powerband problem really be a sign of a lowered compression? It happened quite quickly, in about 200 miles, and it seemed a sudden change (can't remember how sudden - I wasn't experienced). I didn't ever ride it cold. So can a compression drop be so sudden under "normal" riding conditions?
| stevo as b4 |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Old Git Racing |
 Old Git Racing World Chat Champion
| Fin |
 Fin World Chat Champion
| P.addy |
 P.addy Red Rocket
 - Super Spammer
| skatefreak |
| MCN |
 MCN Super Spammer
| Polarbear |
 Polarbear Super Spammer
 Posted: 08:33 - 05 Aug 2018 Post subject: |
I would get hold of a standard exhaust and fit that THEN start looking for the problem but Pete already basically told you that.
From my knowledge of 70's and 80's 2 strokes one of the worst things you could do was fuck around with the exhaust unless you knew exactly what you were doing. Rejetting was de rigueur when you altered the exhaust or put expansion chambers on it. I presume you understand on a 2 stroke it's not just about flow through the exhaust.
I cannot understand the logic of something was running well, it isn't now, I'll change a fundamental part of the engine.  ____________________ Triumph Trophy Launch Edition |
| iooi |
 iooi Super Spammer
| Polarbear |
| ThatDippyTwat |
| MCN |
 MCN Super Spammer
| stirlinggaz |
| stirlinggaz |
The last post was made 8 years, 35 days ago. Instead of replying here, would creating a new thread be more useful? |
