| Jay2903 |
 Jay2903 Scooby Slapper
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
| Raffles |
 Raffles World Chat Champion
| MarJay |
 MarJay But it's British!
| Jay2903 |
| Jay2903 |
| Jay2903 |
| mentalboy |
 mentalboy World Chat Champion
| Jay2903 |
| mentalboy |
 Posted: 01:54 - 07 Aug 2018 Post subject: |
| Jay2903 wrote: | | mentalboy wrote: | What are the points like? The XS was one of those machines that you had to open up the points on a frustratingly regular basis. |
Points and timing adjusted by mechanic |
If points are fine, which they might not be because you haven't checked yet, your mechanic might have checked them but it really is something you need to start doing for yourself, and you are happy with HT leads and plugs, then that takes you to the coils.
You don't want to start messing with those until you have done as Marjay recommended - he didn't say that the carbs weren't jetted correctly but was suggesting that you may have an air issue between the carbs and airbox. If you have a compression tester it wouldn't hurt to take some readings, make a note of them and check every so often, keep a log of the readings and it will let you know if or when you have any compression issues.
True story: I had quite a lot of old XS twins back in the 90's and used to pick up non runners from the breakers for 100 quid a pop, open points and ride off, much to amusement of the chap who ran the place. Then run into the ground for six to twelve months, fuck it up properly and go trade it with a 100 quid for another one. Great engines, pretty much indestructible, but were prone to electrical gremlins. ____________________ Make mine a Corona. |
| Jay2903 |
 Posted: 09:34 - 07 Aug 2018 Post subject: |
| mentalboy wrote: |
True story: I had quite a lot of old XS twins back in the 90's and used to pick up non runners from the breakers for 100 quid a pop, open points and ride off, much to amusement of the chap who ran the place. Then run into the ground for six to twelve months, fuck it up properly and go trade it with a 100 quid for another one. Great engines, pretty much indestructible, but were prone to electrical gremlins. |
The points are fine
Valve clearances are fine
It has pod filters so no air box
No leaks before/after carbs
Coils are new
Condenser is new
Plugs new
Plug caps new
Ht leads are fine |
| Ste |
 Ste Not Work Safe
 Posted: 09:42 - 07 Aug 2018 Post subject: |
So let me get this straight, it started running badly after you took the airbox off and replaced it with pods but you haven't tried refitting the airbox to see how it runs?
At least give it a try if not just to eliminate it as the really obvious possible cause of the problems. |
| P.addy |
 P.addy Red Rocket
| Jay2903 |
| Ste |
 Ste Not Work Safe
| Jay2903 |
| Ste |
 Ste Not Work Safe
| Jay2903 |
| Ste |
 Ste Not Work Safe
| Jay2903 |
| pepperami |
 pepperami Super Spammer
 Posted: 12:50 - 07 Aug 2018 Post subject: |
Having been the unfortunate owner of both an XS250 and an XS 400 in the past, I can confirm that they seem to like to fire on only one cylinder for no apparent reason on a common basis.
My mantra was points, condenser, coils, HT leads, plug caps, and then plugs.
Most of the time I would find the problem somewhere in that lot.
After that it would be time to look at those stupid vacuum operated carbs and that stupid vacuum operated fuel tap
I ended up replacing the diaphragms on mine.
It’s an old bike and rubbery bits go all slurrrgh after that many years.
You could always do what I did to solve the problem ....... I got rid of mine ...... my life is a lot calmer now  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| mentalboy |
| Jay2903 |
 Posted: 13:52 - 07 Aug 2018 Post subject: |
| pepperami wrote: |
You could always do what I did to solve the problem ....... I got rid of mine  ...... my life is a lot calmer now  |
Points look fine, condenser is new, coils are new, plug caps are new, plugs are new, thanks leads are fine.
Carb diaphragms replaced a while ago.
Non original tank so standard fuel taps not vacuum ones. (Fuel tap new also). |
| Jay2903 |
| P.addy |
 P.addy Red Rocket
The last post was made 8 years, 35 days ago. Instead of replying here, would creating a new thread be more useful? |
