| bikertomm |
 bikertomm World Chat Champion
 Posted: 23:43 - 08 Aug 2018 Post subject: Puncture repair and axle greasing questions... |
Hi chaps,
I've come to ask the bcf font of all knowledge a few quick Q's
Recently got a screw right through my Metzler M7RR which has about 5mm of tread on. (180/55/17)
It's not directly central to the tyre, more like half way from the centre line, to the edge of the tyre. If that makes any sense?
Anyway, 3 out of 3 bike shops said they probably couldn't plug it.
So I've bought a new one for piece of mind. (Anyone want the old one? )
So I've taken the rear wheel off by myself like a big boy...
Should I apply any grease to the axle when I put it back in, and if so, what type? Lithium?
Appreciated n00b help.
Ta.  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| jaffa90 |
 jaffa90 World Chat Champion
| Riejufixing |
 Riejufixing World Chat Champion
| Riejufixing |
| P.addy |
 P.addy Red Rocket
| stinkwheel |
 Posted: 11:47 - 09 Aug 2018 Post subject: |
I would and have plugged a screw hole in a z-rated tyre. In fact, my record is three stab-through bungs in the same tyre AND I did a 156mph run on that tyre then proceeded to run it down to canvas round the middle (canvas with a bit of bung sticking out).
So yeah, I used stab throughs, you have the tyre off so could musroom it.
Anyway. I use a thin smear of copper grease anti-seize compound on the axle but am mindful it's mildly abrasive so make sure it's not present in quanitities it could contaminate any moving parts (the axle and inner races are stationary in-use). I have sealed bearings on all my bikes but if yours are open, you'd want to be careful no copper grease gets into them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| supZ |
 supZ World Chat Champion
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
| Islander |
 Islander World Chat Champion
 Posted: 14:00 - 09 Aug 2018 Post subject: |
i always use molybdenum grease for the spindle.
And yep, plug that tyre. It'll be fine.  |
| Confusion |
 Confusion Scooby Slapper
| stinkwheel |
 Posted: 14:41 - 09 Aug 2018 Post subject: |
| supZ wrote: | Personally I wouldn't use copper grease on an axle.
Use lithium grease myself. It's designed for use on bearings, moving parts etc..
Only use copper grease as anti-seize on things that aren't generally meant to move but may need to be 're-'moved at some point. I.e. back of pads, wheel nuts, bolts, brackets, etc.. |
The axle isn't a moving part and isn't meant to move, it just holds the bearings/wheels in place until they are clamped together. The wheel rotates because the outer races are a tight fit in the wheel and the inner race is firmly clamped between the spacers/fork legs and remains stationary. The bearings roll round against the inner race.
If your axle is rotating or something is rotating on your axle, there is something badly wrong. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
 Posted: 15:05 - 09 Aug 2018 Post subject: |
Copper grease is not a panacea and can cause issues.
It is over used by most DIYers.
BWM specifically use a Castrol thread lubricant.
Optimol TA
https://m.ebay.co.uk/itm/Castrol-Optimol-Paste-White-Now-Molub-Alloy-Universal-Assembly-Paste-100g/123203383253?hash=item1caf7e6fd5:g:JqkAAOSwBiBavMAR
Not cheap but you don't use it every day so the small tube will last a while.
I noticed on my BMW bikes that they use a white grease.
Further checks revealed it is the Castrol Optimol paste.
But I'm sure lots of folk on here will say rubbish use any grease.
But you asked specifically. Folk can use what they like. I use What the OEM recommends.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| bikertomm |
| Riejufixing |
| stevo as b4 |
 Posted: 23:29 - 09 Aug 2018 Post subject: |
Everyone is an expert mechanic I get that bit, and nobody likes to peddle round a once heard opinion about which products to use etc etc.
People and professionals have been doing things certain ways that have always worked well, but no text book will ever tell you to use these methods, tools or products, for everything from paint preparation to oil seal or bearing removal and installation. But read out a text book and you'll sound the boss man on the Internet!
I too use a smear of copper grease on axle spindles, and in fact I'll use copper grease on every single nut and bolt, except the few that I don't want coming undone. To me this means only things like brake disc bolts, crankshaft pulleys, and clutch baskets etc.
Everything else on my bikes and cars will have copper grease applied. Caliper sliding pins is another favourite for the Internet experts. My take on this is that unless your going to use water proof or underwater grease on them, you'd be better applying copper grease so they won't seize as easily once you've hosed down the bike a few times.
Im sure some people think copper grease contains large quantities of silicon carbide and is another word for Valve grinding compound.
But then as I said I use copper grease more often than not on fasteners and so my bikes and car are the most dangerous lethal bodged to oblivion vehicles on BCF that are unsafe in every way possible. |
| Riejufixing |
| MCN |
 MCN Super Spammer
 Posted: 00:21 - 10 Aug 2018 Post subject: |
| stevo as b4 wrote: | Everyone is an expert mechanic I get that bit, and nobody likes to peddle round a once heard opinion about which products to use etc etc.
Someone asked what to use?
There is no point in saying use butter or marg in a sandwich with today's options on what to use.
There are specific reasons not to use copper in certain applications.
And there are many occasions where using butter or marg has no detrimental effect.
If someone asks why not give the most specific answer?
This is just one example of industry information.
https://www.rocol.com/articles/anti-seize-product-selection
There are DIYers (at everything) who do not have the faintest idea of what they are doing or even care. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| jaffa90 |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 05:34 - 10 Aug 2018 Post subject: |
Weldtite? What a brilliant name for a grease... ____________________ They're not one night stands, they're auditions. |
| sickpup |
 sickpup Old Timer
| Courier265 |
 Courier265 World Chat Champion
 Posted: 20:59 - 10 Aug 2018 Post subject: Re: Puncture repair and axle greasing questions... |
| bikertomm wrote: | Hi chaps,
Bike shops do have rules they have to follow on puncture repairs
so I'm not surprised the shops you visited couldn't do them.
I personally never get my punctures repaired by a shop nowdays,
I use a plugging system which does the job well. Plus it's bloody
cheaper and more convenient. |
The last post was made 8 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
