CBF600 High Idle
waxandhide
PostPosted: 09:17 - 17 Aug 2018    Post subject: CBF600 High Idle Reply with quote
Hi guys,
Just bought a 2007 CBF600 (FI) SA-8 with 43k miles on it. Overall the bike is is good condition but it seems to have a small idling issue and I'm stumped!
The auto choke will kick in regardless of whether it's the first start of the day from cold or if I've been riding for a while, turn the engine off for a minute and then start it again.
Once at temperature, the bike seems to run at around 1500 RPM but when I put it into neutral the revs drop to around 1350 RPM and then rise again when I put it in gear. When riding to slow down and pulling the clutch in, they also don't seem to drop as quickly as they probably should.
Any thoughts/help would be much appreciated!
jaffa90
PostPosted: 10:39 - 17 Aug 2018    Post subject: Reply with quote
Does this bike have a choke cable to pull out?
Is the idle screw set ok?
Sounds like you have clutch drag so what engine oil is in it?
waxandhide
PostPosted: 10:42 - 17 Aug 2018    Post subject: Reply with quote
It's the fuel injected version so no manual choke or idle screw.
I did think clutch related but it's not dragging in any gear so not sure.
jaffa90
PostPosted: 10:58 - 17 Aug 2018    Post subject: Reply with quote
Your bike has many sensors giving the brain ecu info,
sounds like the cold start / temp sensor could be faulty but i`m no expert on F.I.
The last post was made 8 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 37.94 Kb
