| R1stu |
 R1stu Shrek!
| jaffa90 |
 jaffa90 World Chat Champion
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| skatefreak |
 skatefreak World Chat Champion
| R1stu |
 R1stu Shrek!
| Riejufixing |
 Riejufixing World Chat Champion
 Posted: 15:26 - 17 Aug 2018 Post subject: Re: Can these discs be saved? |
What's supposed to be the matter with them? |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 15:28 - 17 Aug 2018 Post subject: |
Perfectly alright, check the thickness.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| pepperami |
 pepperami Super Spammer
| MCN |
 MCN Super Spammer
| R1stu |
 R1stu Shrek!
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:45 - 17 Aug 2018 Post subject: |
What are they off/for?
If they are stainless discs..... to be that bad, then they are probably shot.
If they aren't stainless... Grimeca/Brembo wop-fitment, Morini/Guzzi/Ducati etc.... they look pretty normal.... Er-Nibs Italian Tractor's rotors don't look much different the morning after she'd had a solvol binge!!!!
Two things that would be on my mind are thickness and warpage; then if re-fitted to bike, the pads.
Used to be more common on older race-bikes to 'upgrade' stainless rotors to cast; Pads for stainless rotors are softer, because the metal isn't; so using soft pads for stainless discs on cast would see the brakes very grabby and chewed up in short time.
Going the other way, and using harder pads for cast discs on stainless discs would result in wooden brakes, and rider applying gross lever pressure to get some effect, and often the discs warping and getting scored.
Was most often observed on things like air-cooled RD's and stuff with folk mixing and matching TZ race bits, and the common one of 'upgrading' wire wheels for cast, but keeping the wires to mount 'wets', whilst slicks or race tyres fitted to the mags; but leaving whatever discs were on the wheels, so that the discs got mis-matched when swapped. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| sickpup |
 sickpup Old Timer
| Riejufixing |
| pepperami |
| Pete. |
 Pete. Super Spammer
 Posted: 20:17 - 17 Aug 2018 Post subject: |
Buy 1/2 a kg of citric acid crystals off ebay. Fill bucket with boiling water, dissolve as much of the citric as possible and dunk the discs in for a couple of hours. All the rust will be gone leaving a black film which will wipe right off.
Citric acid is totally safe (it's a food additive) and non-toxic so pour it down the drain when you're done.
Done this week: two small lathe chucks 90 minutes in a bucket of hot citric acid solution. Here's the before and after pics. ____________________ a.k.a 'Geri'
| RhynoCZ |
| Riejufixing |
| R1stu |
 R1stu Shrek!
| R1stu |
 R1stu Shrek!
| Riejufixing |
| MCN |
 MCN Super Spammer
 Posted: 17:52 - 20 Aug 2018 Post subject: |
Those discs are not new. They are 'other' discs.
They have been 'cleaned' using Scotchbrite pad or similar.
I can see from the way the very shiny areas around any of the holes.
Those pads are shit for machined surfaces. I would not use on a brake disc. I would prefer a lathe, milling machine or a surface grinder.
The issue with Scotchbrite pads is that the abrasive doesn't move in a single direction. It dips into holes and is lifted up by the edges. That wears any of the edges in the path of the abrasive.
We stopped using them to clean off cylinder blocks, heads and spacer plates due to sealing issues.
A flat plate sander would do the job better. As the abrasive is supported properly.
Work up the grades to get to the finish. There is a correct grade of abrasive to use to 'condition' a brake disc so you don't break it.
The pitting is probably just the casting process. Maybe not a high quality foundry cast them and the pour was not pure.
https://www.youtube.com/watch?v=lM_Ravhnn3s ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN.
| stinkwheel |
| tom_e |
 tom_e Brolly Dolly
 Posted: 19:14 - 20 Aug 2018 Post subject: |
| MCN wrote: |
https://www.youtube.com/watch?v=lM_Ravhnn3s |
Those discs are not the new ones he bought but the ones from the first post. |
The last post was made 8 years, 68 days ago. Instead of replying here, would creating a new thread be more useful? |
