Brake fluid replacement on ABS bike
lynnnsr
PostPosted: 16:02 - 21 Aug 2018    Post subject: Brake fluid replacement on ABS bike Reply with quote
Bike is a CB650F
Brake fluid is dark and over 2 years old.
Can I replace the fluid using the normal, non-ABS procedure or will I screw something up?
Thanks
NSR 125 (with L-Plates) > 1994 NTV 650 > 2015 CB650F > 16 VFR800F
whitedevil
PostPosted: 18:37 - 21 Aug 2018    Post subject: Reply with quote
Just bleed as normal its fine, there is only a tiny amount of fluid in the abs servo, you could if you wanted bleed as normal, go out for a ride and activate the abs a few times to get the fluid out and then rebleed again if you really want too. Thats what i do.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
RhynoCZ
PostPosted: 20:08 - 21 Aug 2018    Post subject: Reply with quote
Riding the motorcycle won't bleed the air out of the ABS pump. The easiest thing to do is not to let the fluid drop below the reservoir while you change the fluid, then bleed as normal. Just do not drain dry the system.
If you do get air in the system (you let the fluid drop too low), you're going to have to activate the ABS pump with a computer and/or a fuse trick.
lynnnsr
PostPosted: 20:57 - 21 Aug 2018    Post subject: Reply with quote
Cheers both, just a routine change not letting air in then. Will do.
The last post was made 7 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.83 - MySQL Queries: 13 - Page Size: 39.39 Kb
