front end vibration
timbuck
PostPosted: 19:24 - 21 Aug 2018    Post subject: front end vibration Reply with quote
hello folks, im getting quite a lot of vibration on the front end of my bike at around 30 mph, can anyone tell me what it might be. thanks .
tim<>
c_dug
PostPosted: 19:41 - 21 Aug 2018    Post subject: Reply with quote
Cruising along, braking, accelerating, turning, carrying luggage, both hands on the bars...?
Way more info required.
Usual suspects are oddly warn tyres or knackered/loose headstock bearings.
Islander
PostPosted: 20:01 - 21 Aug 2018    Post subject: Reply with quote
Check your tyre pressures as a starting point.
Check the wheel rim for missing balance weights too.
PostPosted: 20:03 - 21 Aug 2018    Post subject: Reply with quote
Bonus point available if you say what bike it is. Wink
timbuck
PostPosted: 20:25 - 21 Aug 2018    Post subject: Reply with quote
sorry, its a lexmoto 125 ht-8, ( i know chinese rubbish). i like it. Very Happy
tim<>
PostPosted: 21:36 - 21 Aug 2018    Post subject: Reply with quote
I would check tyre pressures, check wheel bearings and check balance before delving any deeper.
Also have a good look around the tyres for any damage or unusual wear,
arry
PostPosted: 21:38 - 21 Aug 2018    Post subject: Reply with quote
Spill all the beans, we might actually be able to help.
timbuck
PostPosted: 21:42 - 21 Aug 2018    Post subject: Reply with quote
no beans to spill, just vibration on front end around 30 mph, .
tim<>
Nobby the Bastard
Harley Gaydar
one of the hamsters running round in your front wheel is getting a bit old and has to stop periodically, making the wheel unbalanced.
Triumph Sprint ST 1050
arry
PostPosted: 21:49 - 21 Aug 2018    Post subject: Reply with quote
See post 2.
White Naked One
PostPosted: 19:15 - 23 Aug 2018    Post subject: Reply with quote
Is the tyre coming to the end of its life? Vibration is one of the bugbears of a tyre just prior to it reaching it's minimum tread.
Tdibs
PostPosted: 10:19 - 24 Aug 2018    Post subject: Reply with quote
Put it on the center stand, put something heavy on the back seat so the front wheel is free to spin.
Check the tyre still has good tread, is correct pressure and has no bulges/defects.
Check the wheel spins freely/no hard dragging and that you still have material left on your brake pads.
Check if there is any lateral play in the wheel, as in keep the forks straight and see if the wheel wiggles at all from side to side (it should not)
The last post was made 8 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 69.97 Kb
