Engine noise HELP
L33n
PostPosted: 08:59 - 23 Aug 2018    Post subject: Engine noise HELP Reply with quote
Need help I have a 2014 leeway txm 8000mile has Suzuki GS 125 engine in I have noise in top end now I have built & stripped engines so not a novist its a tapping noise checked tappets can chain & valves all sound all bottom end bearings are new I had the head changed & this noise has evolved no piston slap or rod knock its ohc anyone got ideas could I of missed something ? Piston been put in right way dot facing ex outlet so no valve press valves checked at tdc compression can chain tensionor gd its spring loaded please HELP could it be pre igniting?
Evil Hans
PostPosted: 09:54 - 23 Aug 2018    Post subject: Re: Engine noise HELP Reply with quote
L33n wrote:
Need help I have a 2014 Keeway txm 8000mile whichhas Suzuki GS 125 engine in.
I have a noise in the top end - now I have built & stripped engines so not a novice. Its a tapping noise. I checked tappets, cam chain & valves - all sound
All bottom end bearings are new. I had the head changed & this noise has evolved.
No piston slap or rod knock. It's ohc.
Anyone got ideas - could I have missed something ?
Piston has been put in right way, dot facing ex outlet so no valve press. Valves checked at tdc. Compression, cam chain tensionor good - its spring loaded please
Added some spacing, punctuation and the right name of the bike for you. No charge. Wink
L33n This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
owl
PostPosted: 10:37 - 23 Aug 2018    Post subject: Reply with quote
Pass the popcorn
Evil Hans
PostPosted: 11:29 - 23 Aug 2018    Post subject: Reply with quote
L33n wrote:
Like we don't all have a life to be messing around. Just needed help not a twat
Thought I was being helpful, making it easier for folk to read. I didn't have to waste my time on it. Go fuck yourself.
PostPosted: 11:56 - 23 Aug 2018    Post subject: Reply with quote
Oh dear, and some people wonder why newbies can get a rough ride.
Riejufixing
PostPosted: 12:16 - 23 Aug 2018    Post subject: Re: Engine noise HELP Reply with quote
I've rebuilt a similar engine, and had exactly the same problem! It was quite hard to find the solution, but thank goodness I did because continuing to run it would have been very expensive.
L33n
PostPosted: 12:23 - 23 Aug 2018    Post subject: Reply with quote
Mate I just wanted help with my problem thought that's what forums are for but obviously don't look like am getting it here didn't mean to p$ss anyone off was just genuine cry out for help these ain't my things so thought you was doing it to take the p$ss my bad & if none of you can help that's fair enough thanks for your time anyway I will ask on another forum
Evil Hans
PostPosted: 12:34 - 23 Aug 2018    Post subject: Reply with quote
Long shot, but are you sure it's not blowing at the exhaust manifold?
L33n
PostPosted: 12:40 - 23 Aug 2018    Post subject: Reply with quote
No mate new gasket when head was replaced its a tapping noise so to say tappets but defiantly not tappets valve clearances are bang on valves & stems are nice checked for piston slap nothing but its 100% top end :/ what I mean by crying for help lol I have don't multiple engine rebuilds spot on I know the obvious to look out for but none of them timings correct lobes down tdc crank & can markings line up spot on :/
L33n
PostPosted: 12:43 - 23 Aug 2018    Post subject: Reply with quote
I know this may sound silly but what about if new gaskets on head are thicker so more room when it tdc could that make a sound I would say no just lower compression correct? But compression test spot on
Evil Hans
PostPosted: 12:55 - 23 Aug 2018    Post subject: Reply with quote
Can you post a video or sound clip? Just in case someone recognises it?
The last post was made 8 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 69.97 Kb
