New Clutch and New Drive Chain - Juddering
White Naked One
PostPosted: 16:49 - 22 Aug 2018    Post subject: New Clutch and New Drive Chain - Juddering Reply with quote
Just bought FZR600 with brand new clutch, drive chain, sprockets. Bike juddered a lot on take off and needed a lot of clutch slipping to take off without juddering. Seller said it needs time to bed in. Done about 100 miles and it has gone much better but it's still there. Hoping it will go altogether soon. Had clutches fitted on other bikes before without this judder, is it usual on the FZR's?
jaffa90
PostPosted: 20:32 - 22 Aug 2018    Post subject: Reply with quote
Were these clutch plates soaked in oil before fitting?
Also what chain slack have you when laden?
arry
PostPosted: 00:03 - 23 Aug 2018    Post subject: Reply with quote
Could be as simple as knackered cush drive rubbers if they've had it all apart and not replaced them.
White Naked One
PostPosted: 11:09 - 23 Aug 2018    Post subject: Reply with quote
Drive chain a bit slack. Will tighten it. Not sure if that would cause the juddering though.
pompousporcup...
PostPosted: 11:36 - 23 Aug 2018    Post subject: Reply with quote
did he fit new plates to the old basket? My old yzf used to judder a bit without lots of revs.. the basket teeth were worn so the plates has a lot of movement..
PostPosted: 12:12 - 23 Aug 2018    Post subject: Reply with quote
If you do the obvious - chain tension, cush drive rubbers, cable tension and it doesn't really help you are left with 2 choices.
Leave it be and hope it does bed in properly.
Take it apart and check what the previous owner has done.
It really all depends on actually how bad it is. Mildly annoying or bloody frustrating. Laughing
It's actually a pretty easy job to do on most bikes (I've never done an FZR so I can't say for certain but most IL4 Japs are a piece of piss) so with a manual, whip it apart and check everything.
White Naked One
PostPosted: 19:03 - 23 Aug 2018    Post subject: Reply with quote
The chain had about 2 inches drop so tightened it to 1 inch and I know this makes me look a dummy for not checking earlier but tyre pressure was 18 in the front and 25 in the rear so sorted that too and it has made a difference. Yes the clutch is still a bit snatchy and the brakes too as brand new but much better. Looks like the clutch discs weren't oil-soaked prior to fitting so a couple of hundred miles of use should hopefully sort it.
PostPosted: 10:04 - 24 Aug 2018    Post subject: Reply with quote
You don't have to soak them, people do though. I never have but some literally leave them soaking.
The last post was made 8 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.99 - MySQL Queries: 13 - Page Size: 53.73 Kb
