My honda nsr 125r won't start
Oulddave
PostPosted: 18:05 - 11 Aug 2018    Post subject: My honda nsr 125r won't start Reply with quote
It has a spark but wont start
Evil Hans
PostPosted: 18:38 - 11 Aug 2018    Post subject: Re: My honda nsr 125r won't start Reply with quote
We'll get back to you later when we've had a chance to process the overwhelming amount of information you've hit us with...
jaffa90
PostPosted: 20:45 - 11 Aug 2018    Post subject: Reply with quote
Spray,
PostPosted: 20:59 - 11 Aug 2018    Post subject: Reply with quote
If there is a GOOD spark, then it's likely fuel, but on my NS125R I had this problem and I changed the plug and the bike worked afterwards. They seem to be sensitive to spark plug condition.
Oulddave
PostPosted: 22:53 - 11 Aug 2018    Post subject: Reply with quote
I have put new coil and spark plug on
David ould
ZebraDriver
PostPosted: 08:34 - 12 Aug 2018    Post subject: Reply with quote
But is it the right plug? A mate once got a bike for free because it wouldn't start. Previous owner had put a short reach plug in a long reach hole
ZebraDriver
Oulddave
PostPosted: 16:24 - 12 Aug 2018    Post subject: Reply with quote
It is a br9ecs
David ould
stirlinggaz
PostPosted: 19:41 - 12 Aug 2018    Post subject: Reply with quote
Oulddave wrote:
It is a br9ecs
hi,
thats the recommended plug, but its also crap.
most nsr owners i know swear by the silly priced iridium flavour (BR9EIX)
However, thats not relevant right now.
have you tried bumping it?
would, at least narrow things down a bit.
cheers,
GAZ
arry
PostPosted: 19:51 - 12 Aug 2018    Post subject: Reply with quote
Here's a plan; start at the beginning and tell us everything.
https://i.kym-cdn.com/photos/images/newsfeed/000/536/549/309.jpg
bypass2
PostPosted: 20:13 - 12 Aug 2018    Post subject: Reply with quote
is the bike in regular use if not how old is the petrol. fresh petrol.is the plug getting wet. is there a good petrol flow from the petrol tap to the carb. try a bit of petrol down the plug hole then try starting it. try a new plug
alains
PostPosted: 20:33 - 19 Aug 2018    Post subject: Reply with quote
br9ecs is the worst , fit the br9eix and dont touch it !
alains
PostPosted: 13:36 - 25 Aug 2018    Post subject: Reply with quote
forgot to tell you :
follow the wire black/yellow coming from the CDI and going to the coil primary (with some part to the revcounter)
this wire provide the condenser discharge in the coil primay
as the intensity is micro clean contacts is essential . so clean the coil contact and the terminal
also this bug symptom is when the engine turn the revcounter needle comes frantic
The last post was made 8 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 72.47 Kb
