Honda XL600v Transalp - 1996 Project
guitarcarfana...
PostPosted: 20:07 - 25 Aug 2018    Post subject: Honda XL600v Transalp - 1996 Project Reply with quote
So...came across an MOT failure locally...
Seller pictures:
https://oqhgtg.am.files.1drv.com/y4mG_RQB-15gWzUQqtCNyFxAC-ofoFhuqZW1XAjzK0igjNEotwjHCZ_qPfZSjzH2HZ-0C_zmxeu77LV3ZdChRdRWfPlo0yhQ9HNfUPAqpgxalF6U3NsNIxYYrnL2P1AhfQ7lFwrkeuA3CE31wFvYtivVS2BEjD3N5bq5vv03JJN59Y1LcmGfvDZnJFBD61AWAcoQaUrODlAQCJ04FQkH86TPw?
https://pm3uwa.am.files.1drv.com/y4mIVPij9XU3nB7pkc4EwrfFOcHY_KbLC3OzrY2Z0aaRVf495-DHiisdB7uJeizelvZNztwFxmvdxLyEZf9B5gPcHrWHNEa-jhq4_sxirTp57BU7xdpnzSpLiLDorEfnJlbf8ZZclqTz_KRX26W4Clq0fWEe9ImHtPsvXBzOzBlu9fD6Bd0bgKgm-sqhXJkO6bi_7s-ch3dmTOzVjZL-2gKlw?
Couldn't resist - need a project and this bike was tidy plus super cheap. Plus, good excuse to FINALLY do my DAS.
Here she is...
https://zfmuoq.am.files.1drv.com/y4mISA7_TBMyqV414TQpH1n5IAZarfBSLlW8ouPLeC_fWMi660HHyrn7aJGBSYExw-p3W5xsHC4ax2gZgxVimPYO1ximC41F6ceyNn_kuyrkzkjaAwurqk2X0ZY6t5pjpeKwt99tAK41fmOO1Cx2erbaNWYUwh6_A3ya8MdCyjyG6QpW75JpqQnRDDCrVnq3oz024gMZH7fajkYLDGHBE3Ydw?width=495&height=660&cropmode=none
1996...7 Previous Owners (last one for 10 years)...33K...been off the road for 6 of the last 10.
MOT fail was for:
Severely Leaking Rear Shock
Worn Rear Tyre
Dangerously Loose Drivechain
Advisories for:
Blowing Exhaust
Front Forks Misting
Front Tyre Near Limit
So, she starts and runs great. A quick blast down the track at the back of my house confirmed no issues. Changes smooth etc.
Time to order some bits...
guitarcarfana...
PostPosted: 20:17 - 25 Aug 2018    Post subject: Reply with quote
So plan of attack = I have ordered...
2 New Tyres
New Fork Seals/Oil
New Front/Rear Sprockets
New Chain
S/H Rear Shock
Oil Filter, Air Filter, Engine Oil, Coolant, Brake Fluid... Etc.
New exhaust gaskets
I've stripped down most of the bodywork etc. and tomorrow giving everything a detailed clean. It's very grimy/grubby!
Today, I took the old chain off and sprockets, removed the rear shock and removed the exhaust...then the fun began.
The blow was being caused by a snapped manifold bolt. Not cool! Previously, someone had tried to silicone a nut on haha! So 3 hours later, I managed to get the broken stud out (see my other post). Exhaust is a little tatty so ordered some VHT exhaust paint to give it a spruce up.
Here was the offending bolt...
https://cisfew.am.files.1drv.com/y4mSbSLYJpGWZF8TXG68yVH3Je7dnPTZ7_IxYM9jxl005NmjsiSFRg4V--XvEqO7KGP9EcbyCA9CCeMO2vvpl8XEb_HrrTld1u6kOjuTkt6lj_1yDhIYBs_VRyieO7Ria4PKS_4k-9NECphbVoYX107POQT1xzQPVONhaCWOvhN0P0hnQvYpZoQYVVKvAxLJBaArjlPIyizFwVPXg0tFP-VSQ?width=371&height=660&cropmode=none
Suntan Sid
PostPosted: 20:44 - 25 Aug 2018    Post subject: Reply with quote
Needs less tax disc holder! Wink
Keep us informed, sounds like a lot of easy fixes!
arry
PostPosted: 20:48 - 25 Aug 2018    Post subject: Reply with quote
This!
Looking forward to seeing how you get on.
guitarcarfana...
PostPosted: 20:57 - 25 Aug 2018    Post subject: Reply with quote
Will do. Tax disc holder removed!!
Shouldn't take long to get her up to speed. As you say, lots of easy fixes. Job tomorrow is full clean and degrease. So much grime around the sprockets and chain.
UncleFester
PostPosted: 08:53 - 26 Aug 2018    Post subject: Reply with quote
Bar end weights? Smile
2017 Z1000SX
guitarcarfana...
PostPosted: 12:09 - 03 Sep 2018    Post subject: Reply with quote
So work has been moving forward on the bike. First job was to start stripping it down and cleaning all the grime... I also re-painted the side and centre stands. And the brake and gear pedals.
https://cisgew.am.files.1drv.com/y4myeWKZvOmFvvdsrisabL9CcIeEigbhdzuS7EOqcr1X7qSwwKXFq1a2J23M5ePMvIEH7fNaPgr9dcFkXrh_BP7UaUUmNrvUc53XP9jdL4dh_0jT62QDsjBeM6Q9qmZGixfeezwlgK9ApmjhnLsix3Kek7lFNJlAFphEQNiQxM6bp84Z1NhncOiMdOWHgzIa-KZUvvSWL8oBAjoLkg1782jIw?width=495&height=660&cropmode=none
https://bqq5ca.am.files.1drv.com/y4moz4-hOImnZpVXlT2-3N0VhaAzXWU_gmDbQAbEnCy2ASYdxy0zn8bvcYOWbxpevSUHVGKe0gcFUciyu_rjStwuMWHCm9lgPBV6gl1V9gP8na3skRwm9T8nXZQxRCsPfS9y-dSk8jIlZmPiHmSsswqh82nCi2BTyQ0sbPAq4uWXj4j8eXJUHtY4K8E8A-As_WxttTXtFLyJlt4L2a9lTux7A?width=495&height=660&cropmode=none
https://qjpn4w.am.files.1drv.com/y4mzsqAYHExbeOewPaqOb89qCu9BIsdE5VcLi5qpududk4Uk4ktwiE8RPbbK_CVDqODAg7HNLcwUf8JeuGMwS48ARbre-s1BeKY9cWhvINsuzXR8bNYw8KF-6XLAlvFJXS4wLEXJXG3hkpFI24J1K9raBh3Saq5kQapJHTjk9Vi_kxtq7m3-UB6Rrxuq2Rxq0Gxrj0_ooA_88ABas8jhr61UQ?width=495&height=660&cropmode=none
Then I moved onto removing the forks to replace the seals...
https://oqhhtg.am.files.1drv.com/y4maYKY4l3-Y4_5JO4tfuP7BoXHsStnwErH4VLSl2GROnTG2SSThrNDZuKvxTTPZCF86QouyjwQE4vatiUg7MOHU0_L_3-S5Z3JVV5F7mNMh4DGucom5UwfpA1EnEnpE7fqq7gXfH3rHB0GHjkfbhRkdaC_LGFSbukzVeUuBijJq8uHFeEmSF0Hyy9zejw0LxHFtH5EqwHTNoXELwT1XzNoBg?width=495&height=660&cropmode=none
https://pm3vwa.am.files.1drv.com/y4mHX6-DNLQUmKFS20xBCZ_FBBYrpagJSv4rd9CorWIf6f0hRmeVBOUtT0YcJx3529g8Z5k5IX0InTNueBPWw7zY4f5uFHnMI7MK3LOrLEeEPY9jsQ8DVMEW7LSrsXX8l1Go4ZREJ_aUU6ZSqqdQ5I4r7nUJBwKllQk0ayLP7rGaXIQSNF9OPX8O8IQBJkFQNec79s0EPMVwrwkKSXap8qvCg?width=495&height=660&cropmode=none
I also removed the chain, sprockets etc. ready for replacement and fitted a secondhand rear shock.
Then I removed the exhaust and patched a hole in the rear box (JB Weld Exhaust). A bit of VHT paint and it's back on the bike looking acceptable...
https://y1mloq.am.files.1drv.com/y4mCAiiO7Gp2nMjHckRwLSA6cEXxR7QTVt5dlRl-8qhrDiXHF1w7ucrLFyFKhNZbPbOuVb948mBPgaChngu8w1O7zXe9A6YoxiXLGj1H3EppXzCOtNg5XzgBLziDkG6A8oZt-o5vHdESdFId6FIYhCqjh15huJnWubpekarPOL0BSrSbYdA13IHrAOT2lSfQ_M_avOpfDK5VaHiwFy86TONcA?width=371&height=660&cropmode=none
https://d8vkqa.am.files.1drv.com/y4mt5TywzO9BCyiBofxSL1_jiIqIQLLMZUVdVGz5MUFbasuaprzBs32z_QxQtJsC6ZpGgX5R-d6CfObPxYhLVpK23KlHPNvfDI8LXPH-r12KX9XytzQ_9Tlzmwk7G5E5vEyCvJh7ZxuFWaNyVzBwosHj0n8sb6zlTHRKG8dxB9xWnkxUalZ8V5KWbbifyqu3nckIVt_pnGFVsghbAPlFfqRcw?width=660&height=495&cropmode=none
Got both wheels off now and new tyres are fitted tomorrow. Then I can get the wheels back on, fit the new chain/sprockets and get the bike back on the ground. Then I can change oil and coolant (will be easier when I can get it up to temperature). I have new sparkplugs as well, but waiting on Amazon to deliver the tool!
Then she is ready for the MOT and I need to get my MOD1 booked in!!
Skudd
PostPosted: 20:03 - 03 Sep 2018    Post subject: Reply with quote
You lucky boy. That looks nice.
PostPosted: 21:37 - 03 Sep 2018    Post subject: Reply with quote
I always thought no bar ends was an MOT fail too but I can't find any reference to it in the manual.
Monkeywrenche...
PostPosted: 10:29 - 04 Sep 2018    Post subject: Reply with quote
How does the output shaft look?
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
PostPosted: 12:02 - 04 Sep 2018    Post subject: Reply with quote
My Cityfly never had bar ends, never had an issue.
ride_to_die
PostPosted: 12:10 - 04 Sep 2018    Post subject: Reply with quote
That is an excellent find you lucky git.
I'm not here for a long time, I'm here for a good time.
guitarcarfana...
PostPosted: 12:31 - 04 Sep 2018    Post subject: Reply with quote
Minimal wear - quite surprised tbh!
Monkeywrenche...
PostPosted: 13:46 - 04 Sep 2018    Post subject: Reply with quote
Excellent, grease it up well and keep it that way Thumbs Up
guitarcarfana...
PostPosted: 11:22 - 11 Sep 2018    Post subject: Reply with quote
So she's pretty much done. Everything on my list ticked off!
https://bosbew.am.files.1drv.com/y4mV6AAjIAhVDt-XOnkKQ2_3nqqF3elp9auIHBVyLWvX-g-GTpeiCa57B8eA4UzFPqVLtn7zO5FgXIEGk_fV5724ulB_-hIhl4imVssQBKHs70IUGty0U_-WGmsQDO1T0iLNNWJm-ocz6kgBTPvvyfbl8mOOb70W_qtG5SI7-qgPaqWFdPj3t2w8CsziZB8lsenI9w47BhBaijGa3Q3T3enZA?width=495&height=660&cropmode=none
https://awq0ca.am.files.1drv.com/y4m4EDNTsgcU8l6WW3MsxPGW8KJZgQyH4cgBydYgja0RqBVyeDMJ71ZmiFS0kjKzAghroTfbJVRuL7KUf9_9lbYMvw8SnecVDqj10oL1LwOrJCUkHLW3aKOX6C5AK2_ACuPz9MbKLfOWe0pbTKtc-OBmHKs9o3ezIEu0X0wv9uVrz9M4GehFODzoZ6cm_g2lwPnia0RP0nHz5A3Svn3-IkEfw?width=495&height=660&cropmode=none
https://qdpi4w.am.files.1drv.com/y4mPou_XWB6-3z9fZjZFWDTpIIgg6Zuc0xG6z29rd98oVMpyQkQklz-UspgTCllwghSPy-xKLfnKy9f4qyn5jAfWrV5tt_mUQycsOGgtBtk696kPxQBEWIFL1ZgLCScpVfYhzplfIWlUXUcbA5Kq79TMF2wSYtHLEKNFmmW2ofP7ZzFoReZ8DwkcT7Q6KZTX8-n-4GZlUZh-dysQR5V4tJjvQ?width=495&height=660&cropmode=none
https://dcvgqa.am.files.1drv.com/y4mYEwMkagjfvOnA2U_UTVB9gOpxyrPyojZsoNNfVYEEkuqXilQS4u06lbKbwB49IEj-r_PsamiGvVDp4zkMqW8OIPn_tiUwtuudlpVg4sksuc639r6vQ-_H4xZ6KNCeYEW208bf5veHgLqPuNpEG1neJKw23t4I4ddsd9Wwpe0dMFwZP3WFpZEKQpjMhCcxrjn0DYDXwdR3gwK17HGjt0LYg?width=495&height=660&cropmode=none
I also fitted an LED headlight bulb (premium, not budget so beam pattern is as it should be).
LOW:
https://pg3qwa.am.files.1drv.com/y4mqToUQv6CjqcXnNwwaY-TLQw6jaMy2MtAQVevGDLEm0FkaWiDj7eQgWYjTZ0zMgcSrpje4dAlZPowH5kzyZDedA_Sl5LMXbLTNs-GhzipANN7W0v_hNOlU_iPK4I3PkksSZISJqPnB5xZQ-ANxPBG2VrpnemCoS4REaNyrc-1oQgZGZH56o0GK_-yhLZgfL9xgF9qkR1Fy-Vxk3JSxkSFPQ?width=495&height=660&cropmode=none
HIGH:
https://ofhctg.am.files.1drv.com/y4mTf0mHjAkVD8HbIzaFqvGucM9kJdt6lJEwhOZqO8ozrm96jA2MBTKco_9TlIT4SRQ1CpzwPltgP2R7H-m41mdisjQTh_iyj21awa3ZCJuDIa3WN6EKp4RpQxwbZONDrTLNLCedM_FMY1v9mbeoRxVm-0Gh49xx4MYSXwk0aOrvdw9RAB3gwNUQYly3cvuqWB-U-PVVcj0osF1ro_dhdq3Hw?width=495&height=660&cropmode=none
I start my DAS next week and then will get her MOTed.
qarka
PostPosted: 11:32 - 11 Sep 2018    Post subject: Reply with quote
Very nice find! I had one of these for a year, loved it. Like riding a comfy, surprisingly nimble tractor. Good luck with the MOT and enjoy!
stevo as b4
PostPosted: 19:24 - 12 Sep 2018    Post subject: Reply with quote
Looks a tidy example of a Transalp! I've never ridden one but one of the instructors had one when I did my DAS. I liked the riding position as I'd come from trail and off road bikes.
Strange times, as I never did ride one or the bigger Africa Twin, but I had them on the same short list as a YZF600 and an SV650 etc.
guitarcarfana...
PostPosted: 15:49 - 13 Jan 2019    Post subject: Reply with quote
So...after passing my test, took her for the MOT. Not expecting any surprises as I had the fail sheet from August and it's been sat in my garage being pampered since.
Se failed on corrosion to the rear wheel - common issue and looks like previous owner had tried to hide with filler/paint!!
Shame this garage didn't mention when they fitted my new tyres mind...
Anyway, secondhand wheels are super rare so contacted a few wheel re-builders. Seems it's the busy season for them and looking at 4-6 weeks minimum....plus about £300 notes.
A bit of creative searching found me a mint wheel off a 650 (same rear) from Italy. Ordered and due to be delivered next week!
So panic over, but just the faff of getting the new tyre on old wheel swapped onto new wheel and then being able to take it for the re-MOT.
Robby
Dirty Old Man
PostPosted: 11:22 - 18 Jan 2019    Post subject: Reply with quote
Whilst you're working on it, I would recommend cleaning and re-greasing the headstock bearings, swingarm pivot bearings, and rear suspension linkage.
Those bits tend to go gradually so you don't notice, but make a significant difference to how the bike rides after a bit of servicing. A bit like tyres really, you don't notice how shit the old ones were until you get new ones.
For the wheel, a new rim shouldn't be all that expensive. Rebuilding a wheel is not exactly difficult, just very time consuming. The painfully expensive bit for me was buying new spokes, because I couldn't find any pattern ones. I ended up mostly cleaning and galvanising the existing spokes, and just buying a few new ones.
guitarcarfana...
PostPosted: 00:26 - 20 Jan 2019    Post subject: Reply with quote
New rim arrived and fitted. Perfect from Italian eBay seller Smile
Slight issue as Honda changed the spacer size, but managed to get some on eBay. Fitted and test run today all good.
Thanks for the heads up - I had all of the swingarm and suspension apart so greased liberally on the re-build.
MOT first thing Monday - then she will be sorted for the road. New project on the horizon as well... Cool
guitarcarfana...
PostPosted: 13:11 - 24 Jan 2019    Post subject: Reply with quote
All MOTed and running lovely - heated grips on order though....far to chilly!
The last post was made 7 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 119.54 Kb
