Having a bad day?
turningCircle
PostPosted: 13:55 - 27 Aug 2018    Post subject: Having a bad day? Reply with quote
Just bought a new pair of tyres, cost me £285 fitted, get home, park up, look back at my bike, what do you know, there is a big screw puncture through the back tyre. In the 25 minutes it took to ride home, I caught a puncture. Tyre completely flat. Thumbs Up
Can someone remind me, why do I ride a motorcycle again? Neutral I might take up knitting instead.
Courier265
PostPosted: 14:30 - 27 Aug 2018    Post subject: Reply with quote
AH Bollocks! Sick
arry
PostPosted: 14:56 - 27 Aug 2018    Post subject: Reply with quote
How deflating.
owl
PostPosted: 15:55 - 27 Aug 2018    Post subject: Reply with quote
It happens, mine was 2 days later, fortunately I managed to plug it and used it till worn.
It really... stings
pepperami
PostPosted: 16:55 - 27 Aug 2018    Post subject: Reply with quote
I hope you have kept the screw so when you take up DIY as hobby, you can use the screw Thumbs Up
Andy_Pagin
PostPosted: 18:41 - 27 Aug 2018    Post subject: Re: Having a bad day? Reply with quote
To perfect your puncture repairing skills. Worked for me.
Hong Kong Phooey
PostPosted: 21:57 - 27 Aug 2018    Post subject: Reply with quote
It's always the rear end that gets a prick stuck in it.
They should make back tyres from the same stuff as the front.
Are you well versed in plugging up your rear?
skatefreak
PostPosted: 10:26 - 28 Aug 2018    Post subject: Reply with quote
Snotty string, had 3 in a tire I eventually used on track for half a season...
Takes about 5-10 minutes to sort and saves a fortune Very Happy
Jayy
Mr. Ponzi
PostPosted: 23:19 - 28 Aug 2018    Post subject: Reply with quote
I bought a brand new bike, a Husky 701. The engine blew up after 3k miles. I got it back after nearly 2 months and 3 weeks later, it blew up again.
I'll take your flat tyre and trade you.
DrSnoosnoo
PostPosted: 11:36 - 29 Aug 2018    Post subject: Reply with quote
When? I saw you were waiting for them to fix it and give it you back.... more details!
PostPosted: 12:22 - 29 Aug 2018    Post subject: Reply with quote
Was it an Avon tyre?
Just they always used to do you a free replacement on a punctured radial as long as it had over a certain tread depth left on it.
Not sure if they still do or if any other manufacturers do the same but it's worth an ask.
DrDonnyBrago
PostPosted: 12:27 - 29 Aug 2018    Post subject: Reply with quote
I always get my punctures sorted by a guy that does hot vulcanised tyre repairs. Basically liquid rubber put into the hole and heated to cure it. Can be used on side walls, Z rated tyres etc. Good for some punctures as it is a bit more flexibile in how it is used compared to a conventional glued in mushroom.
kramdra
PostPosted: 18:24 - 29 Aug 2018    Post subject: Reply with quote
As-new-puncture-repairs are my main source of rear tires, they are quite common, except for puncture resistant Road5's. I have not seen one yet Sad
Take it back. That is a lot of money for a punctured tire, and it will not take long to fix. Unlikely they would swap it for new.
Temporary fixes - strings, plugs, are good short term but have a reasonable failure rate between 3-6 months.
It is not expensive or time consuming to fit your own tires and do the proper repairs yourself.
skatefreak
PostPosted: 15:17 - 30 Aug 2018    Post subject: Reply with quote
Just curious on what this is based?
Admittedly I've only done < 20 snotty string's but out of 7-8 in car tires, 5 in motorcycles and one in a van tire at 75psi and a bunch of buggies... None have ever failed?
turningCircle
Well, it's funny you mention it - it was a Road 5 that got punctured! Decided to just cut my losses and buy a new one, can't be arsed with some dodgy workaround. Definitely going to teach myself some basic bike maintenance; i'm clueless at the moment.
DrDonnyBrago
PostPosted: 15:27 - 30 Aug 2018    Post subject: Reply with quote
buy a new one.... i'm clueless at the moment.
Indeed. Did the garage offer to "dispose" of the old one for you?
johnsmith222
PostPosted: 15:40 - 30 Aug 2018    Post subject: Reply with quote
Proper puncture repairs aren't a "dodgy workaround".
kramdra
PostPosted: 19:40 - 30 Aug 2018    Post subject: Reply with quote
That is many. Wouldnt care too much on four wheels. I had a couple fail that were old and I wanted to know why. When I remove tire, old strings usually fall out with no effort, no stickyness, only air holding it in. A large bump could knock it inwards and deflare rapidly. The failures were slow punctures and I consider that to be luck. Snot strings are my prefered temporary fix. For rears they are good past an indicated 142.. Ive run them down to the cord and will continue to provided its less than a month. Fronts get a lot more stress from braking and bumps, deform a lot more, so I will actually obey the reduced speed warning and change asap. I do not care to use repaired fronts, they get ebayed or scrapped.
Tldr: I can swap and repair quite quick, no massive inconvenience to me.
talkToTheHat
PostPosted: 20:22 - 30 Aug 2018    Post subject: Reply with quote
Killed a road 4 a few months ago and a road 5 today
Bandit. does. everything.
The last post was made 7 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 103.24 Kb
