Stuck oil filter cap after filter change
badgerman1
PostPosted: 18:47 - 27 Aug 2018    Post subject: Stuck oil filter cap after filter change Reply with quote
Just changed the oil and filter on by 600 bandit and the cap i used to tighten it back up has stuck onto the oil filter and I can't remove it.
Does anybody have any ideas how to remove it or is it ok just to leave it attached and save myself a few minutes on the next change (assuming it stays attached)?
Thanks.
doggone
PostPosted: 19:18 - 27 Aug 2018    Post subject: Reply with quote
Pic would help, not sure what you mean exactly but leaving it on sounds unwise.
Islander
PostPosted: 19:48 - 27 Aug 2018    Post subject: Reply with quote
Give it tap or two with a bit of wood or a rubber mallet if you have one. It'll just need a bit of straightening on the filter to release. Thumbs Up
PostPosted: 20:04 - 27 Aug 2018    Post subject: Reply with quote
New bike.
Riejufixing
PostPosted: 20:07 - 27 Aug 2018    Post subject: Re: Stuck oil filter cap after filter change Reply with quote
Eh?
johnsmith222
PostPosted: 20:28 - 27 Aug 2018    Post subject: Re: Stuck oil filter cap after filter change Reply with quote
Riejufixing wrote:
Eh?
https://cdn.shopify.com/s/files/1/1272/9301/products/BMS_BMW_Oil_Filter_Cap_RemovalInstall_Tool_-_1_large.jpg?v=1495483833
one of these is stuck on the filter.
Riejufixing
PostPosted: 20:43 - 27 Aug 2018    Post subject: Re: Stuck oil filter cap after filter change Reply with quote
bluezedd wrote:
OH! It's an oil filter removal tool. The way people talk, argh! I thought he was from up north, and had got his hat stuck on it.
How the hell can one of those get stuck on? Knock it off.
doggone
PostPosted: 20:47 - 27 Aug 2018    Post subject: Re: Stuck oil filter cap after filter change Reply with quote
What would you do with the ferret.
johnsmith222
PostPosted: 20:48 - 27 Aug 2018    Post subject: Reply with quote
he'd probably be safer to have used his cap to tighten it tbh, especially if it's twisted the end of the new filter.
OP stick an extender bar on it, then wiggle the extension to see if that releases.
Otherwise, loosen the oil filter trying to remove the tool, then tighten it back up with your hands.
carvell
Scuttler
PostPosted: 20:50 - 27 Aug 2018    Post subject: Reply with quote
Turn it back the other way to untwist whatever's happened and tap it off.
Next time, hand tighten only!
Yamaha TDM 850
badgerman1
PostPosted: 20:52 - 27 Aug 2018    Post subject: Reply with quote
Cheers guys, it is the oil filter removal tool and i am from up north Smile
I'll try and get something to try and knock it off.
Cheers.
Riejufixing
PostPosted: 21:41 - 27 Aug 2018    Post subject: Reply with quote
Cheers.
"Deep frozen ferret, grip tail, swing".
Psssssssst!
"Don't tell the RSPCA!". Laughing
Edit: Sorry. I have had to wash some wheat beer down with cheap Lidl lager. I do realise that you are a mustelid like the ferret. I apologise for any hurt caused.
Raffles
PostPosted: 00:10 - 28 Aug 2018    Post subject: Reply with quote
Unscrew the probably now fucked new filter and knock the removal tool off it with a hammer or similar. Throw away the new filter and hand-tighten another new, undamaged one.
MCN
PostPosted: 01:52 - 28 Aug 2018    Post subject: Reply with quote
Step back from the motorcycle.
Don't try to wiggle it off.
You might damage the filter (Or something else)
Take it to a bike shop.
Or if you want to DIY some more then buy a new filter for when the one you just fitted fails when you try to remove your 'CAP' (FFS, a cap.. Shocked. Very Happy.)
Evil Hans
PostPosted: 08:39 - 28 Aug 2018    Post subject: Reply with quote
For future reference, the clue is in the name Wink
DrSnoosnoo
PostPosted: 10:45 - 28 Aug 2018    Post subject: Reply with quote
Yeah, how tight did you actually put it on? Hand tighten in fine, you're only sealing the rubber o-ring. You sometimes need the tool for removal because crud can stick it shut.
If you've managed to get the tool stuck on, I'd be worried you've twisted the filter and damaged it.
The last post was made 8 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 88.33 Kb
