Yamaha xj 600n headlight
aidy
PostPosted: 16:48 - 08 Sep 2018    Post subject: Yamaha xj 600n headlight Reply with quote
Hi guys got a problem with my headlight if I put it on full then press for dipped beam it stays on full and if I press trigger to flash the light it does nothing with the light but the light on dash comes on. If I move the light switch to the middle and then press the trigger the light flashes and light on dash. Also the rev counter is only dim light on the right of the dial and the speedo has no light at all any help with these problems would be great and thanks for any help in advance [/i]
jaffa90
PostPosted: 18:05 - 08 Sep 2018    Post subject: Reply with quote
You have problems with your switches if they do nowt.
How about the flashers?
aidy
PostPosted: 13:12 - 09 Sep 2018    Post subject: Reply with quote
I replaced the headlight bulb and now the dipped beam works as it should so now all my lights work except for the speedometer clock light does not light can someone explain how to change the bulb and what bulb is neededthanks
jaffa90
PostPosted: 01:01 - 10 Sep 2018    Post subject: Reply with quote
Usually capless bulbs.
Google is your friend.
aidy
PostPosted: 12:21 - 15 Sep 2018    Post subject: Reply with quote
Managed to replace the bulb in my speedo clock and now all lights work as they should thanks everyone
The last post was made 7 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 42.1 Kb
