99 R1 stator plug toast?
skatefreak
PostPosted: 19:22 - 09 Sep 2018    Post subject: 99 R1 stator plug toast? Reply with quote
Plug from stator to rev on 99 R1 is crispy/burnt/falling apart (literally).
Stator shows correct resistance so plan to solder the cables together and do away with the plug for now (needs new wire soldering on to reach anywho..).
Is there a specific order these wires need to be connected? They’re all white ffs? Lol.
Any thoughts would be much appreciated.
https://cdn.bcf.44bytes.net/files/5ef21be3-2c5d-47cb-bde8-c187f3afe444.jpg
https://cdn.bcf.44bytes.net/files/3b0d2ae8-265a-41dd-9281-f5fe9f8cd315.jpg
https://cdn.bcf.44bytes.net/files/6a8cb520-e368-441d-a274-8dac0bd07e26.jpg
jaffa90
PostPosted: 01:09 - 10 Sep 2018    Post subject: Reply with quote
Jeez that reg (not rev) must have been red hot, connect the 3 white wires in any order.
Find out why it happened and what other damage has been done.
skatefreak
PostPosted: 09:14 - 10 Sep 2018    Post subject: Reply with quote
Thanks for the input.
I suspect it was corrosion on the contacts causing the heat buildup.
Testing the stator shows the correct resistance, regulator wires look absolutely fine. Thinking
There is cooked plastic on the spade connectors so I'm fairly confident this would be the cause.
Just struggling to find some cable thick enough also due to the high temps the wire has been cooked/contaminated and solder won't flow.
Just going to have to cut back further into the loom I guess Rolling Eyes
Skudd
PostPosted: 10:15 - 10 Sep 2018    Post subject: Reply with quote
You should have got the '98 R1, stuff of legends.
skatefreak
PostPosted: 10:50 - 10 Sep 2018    Post subject: Reply with quote
98 and 99 are pretty much the same machine.
00 was the next major revision and I may get a chance to play on an 04.
I won't lie, I prefer the looks of the later models and I doubt the extra 30 bhp wouldn't be appreciated but I'm curious to see what the power delivery is like and what all the fuss is about...
The 99 is a wheelie machine, although not such a good thing on bumpy country lanes without a steering damper Laughing
PostPosted: 12:02 - 10 Sep 2018    Post subject: Reply with quote
They all feed from the stator, no specific order.
Just go back until you see shiny metal and clean it all up.
skatefreak
PostPosted: 12:15 - 10 Sep 2018    Post subject: Reply with quote
Any clues on what gauge cable I should be looking for?
It looks like standard 240v/13 amp is a little thinner than the cables to be joined...
Would halfrauds 12v/27amp be overkill? Thinking
Kawasaki Jimbo
PostPosted: 12:47 - 10 Sep 2018    Post subject: Reply with quote
You can glean a few tips from Eastern Beaver Cool here.
When I did my '03 R1 I bought their ready-made kits, but then I had been going round the houses for months and eventually had to replace pretty much everything in one go. In hindsight I think the problem might have been a dodgy section of loom (guessing, I never saw it) between the reg/rec and battery. The kit by-passed it so the reg/rec goes straight to battery terminals instead of into a loom connection.[/url]
'93 Yamaha XJR400 grey import (p-ex’d), '99 Kawasaki ZX6R (nicked), another '99 ZX6R (still got it) and '03 Yamaha YZF-R1 (still got that too.)
skatefreak
PostPosted: 12:56 - 10 Sep 2018    Post subject: Reply with quote
14 AWG recommended so I will massively over-spec with 27amp cable then (plus it's the same price).
Insurance runs out tomorrow, not renewing due to winter & new baby due soon :-\.
Will solder it up this arvo and hopefully get out for one last hoon, also hopefully confirm I've solved the mystery rattle (tightening up the Exup valve cable, there was a fair amount of play...).
Mucho's gracious
Skudd
PostPosted: 21:13 - 10 Sep 2018    Post subject: Reply with quote
The '98 R1 is like no other machine known to man, it has a throttle that goes both ways.
skatefreak
PostPosted: 21:23 - 10 Sep 2018    Post subject: Reply with quote
Fair play...
Just some feed back, soldered the stator cables and getting a solid 14.5v @ 5k. Took it out for an hour and all seems to be good Thumbs Up
RhynoCZ
PostPosted: 21:48 - 10 Sep 2018    Post subject: Reply with quote
This could be a result of heavy oxidation of the contacts (the white stuff), I have seen this before.
skatefreak
PostPosted: 09:35 - 11 Sep 2018    Post subject: Reply with quote
This can be the only explanation I can conclude.
The connector is thoroughly burn out and all the wires have baked a little for an inch or two but aside from that there is no other damage apparent.
Stator/reg-rec/rest of the wiring is fine...
The bike is off the road for several months now, I plan to strip it down and give each plug a clean/pack with dialectic grease just to be on the safe side Thumbs Up
RhynoCZ
PostPosted: 11:06 - 11 Sep 2018    Post subject: Reply with quote
Yes, 1999 was a long time ago and unless you've cleaned all the electrical plugs (the critical ones being the stator, reg/rec and the fuse box and battery terminals) it was only a matter of time, when the oxidation build up would cause issues.
Keeping things clean and well lubricated is the key for longevity. Smile
PostPosted: 11:28 - 11 Sep 2018    Post subject: Reply with quote
Check the big one behind the infill panel on left hand side. That is a fucker.
The last post was made 7 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 87.42 Kb
