Would you be happy with this amount of flare?
mikester
PostPosted: 15:20 - 10 Sep 2018    Post subject: Would you be happy with this amount of flare? Reply with quote
Fitted a new chain today, used a DID rip off tool for riveting and gotta say I was very impressed with it.
Just wanted some thoughts on whether these pins are rolled out enough or if they should be a bit more flared. According to the instructions that came with the tool they're pretty much bob on but looking at the master link in my removed chain they seem way flatter, don't want to risk cracking the pins if they're pressed a decent amount already.
What are the thoughts of the BCF gurus?
cb1rocket
PostPosted: 17:13 - 10 Sep 2018    Post subject: Reply with quote
Needs flaring over more
PostPosted: 17:57 - 10 Sep 2018    Post subject: Reply with quote
Needs more flare...
https://zippy.gfycat.com/IcyEminentEmperorpenguin.webm
Nobby the Bastard
Harley Gaydar
PostPosted: 19:42 - 10 Sep 2018    Post subject: Reply with quote
You only need to flare it enough that the plate can't come off. There's very little sideways force on the chain so it doesn't take a lot.
Triumph Sprint ST 1050
MCN
PostPosted: 21:32 - 10 Sep 2018    Post subject: Reply with quote
Looks OK.
struan80
PostPosted: 01:23 - 11 Sep 2018    Post subject: Reply with quote
Get a professional to do it for you.
DrDonnyBrago
PostPosted: 08:20 - 11 Sep 2018    Post subject: Reply with quote
Last time I fitted a DID soft link I'm pretty sure it came with instructions for how wide the flaring should be. If you have a vernier caliper, see if it is wide enough.
From the photo it looks like it needs it an extra twist on the riveter. If the original master link was a riveted hard link or part of an endless chain you would expect it to look different.
mikester This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
MCN
PostPosted: 18:01 - 11 Sep 2018    Post subject: Reply with quote
mikester wrote:
Thanks guys, will purchase myself a set of vernier calipers and check it, DID guide states should be a 5.4 - 5.6mm spread. Pretty sure I'm at that already but will double check.
Y TRY 2 DIY if U do not have DA skills?
Kawasaki Jimbo
PostPosted: 18:11 - 11 Sep 2018    Post subject: Reply with quote
How else to get them?
mikester
PostPosted: 19:16 - 11 Sep 2018    Post subject: Reply with quote
Cos the DID guide stated that if the riveting head touches the plate after pressing then you're golden. It touches but the consensus seems to be that they need spreading a bit more.
Besides been out for an hour on it and chain still on so reckons I got the skills Thumbs Up
PostPosted: 19:21 - 11 Sep 2018    Post subject: Reply with quote
It'll be fine. Thumbs Up
MCN
PostPosted: 19:24 - 11 Sep 2018    Post subject: Reply with quote
Well you are, at the least, a little short on Tact.
kramdra
PostPosted: 19:59 - 11 Sep 2018    Post subject: Reply with quote
Looks shit and way off centre in my opinion, but it will probably do the job if it is otherwise within spec. Inspect it closely on the thin sides to be sure it has not cracked.
PostPosted: 14:38 - 24 Sep 2018    Post subject: Reply with quote
Alternatively you could use the nut and bolt approach.
https://pbs.twimg.com/media/DnzjIFuWsAAiM42.jpg
The last post was made 7 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 85.8 Kb
