| Tomzo47 |
 Tomzo47 Brolly Dolly
| Riejufixing |
 Riejufixing World Chat Champion
| Tomzo47 |
| Riejufixing |
| Tomzo47 |
| Riejufixing |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 01:53 - 16 Sep 2018 Post subject: |
Hang rugs on the walls, wear Merino wool thermals and socks. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| MCN |
 MCN Super Spammer
| doggone |
 doggone World Chat Champion
 - Super Spammer
| Riejufixing |
| stevo as b4 |
| Polarbear |
 Polarbear Super Spammer
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| kramdra |
 kramdra World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 22:16 - 16 Sep 2018 Post subject: |
Heating a brick workshop is all well and good but if you're going to put any machine tools in there then they are going to rust if the shed is very thermally inefficient. Far more so if it has a tin roof.
I'd find a way to insulate it, even if it was just rockwool, battens and hardboard. ____________________ a.k.a 'Geri'
| MCN |
 MCN Super Spammer
| Riejufixing |
 Posted: 22:44 - 16 Sep 2018 Post subject: |
| Pete. wrote: | Heating a brick workshop is all well and good but if you're going to put any machine tools in there then they are going to rust if the shed is very thermally inefficient. Far more so if it has a tin roof.
I'd find a way to insulate it, even if it was just rockwool, battens and hardboard. |
Ah, my current workshop has a tin roof. However, directly under it is 11mm Stirling board. It's good. I like corrugated iron. My workshop roof was bought from somewhere near Hiitchen, Herts, from somewhere called "reel slitters" or something, by my dad, about 15 years ago. Unfortunately I can't recall the exact name of the place. You could see them get rolls of galvanised sheet metal, and make them corrugated.
Galvanised iron is IMO far, far superior to poxy "Onduline" and similar. |
| Pete. |
 Pete. Super Spammer
 Posted: 22:51 - 16 Sep 2018 Post subject: |
| Riejufixing wrote: | | Pete. wrote: | Heating a brick workshop is all well and good but if you're going to put any machine tools in there then they are going to rust if the shed is very thermally inefficient. Far more so if it has a tin roof.
The stirling board prevents condensation forming on the underside of the tin roof when the outside temperature drops by insulating the air inside from the metal. It's probably not terribly efficient but it'll be enough to do the job. You'll still lose heat through it though. ____________________ a.k.a 'Geri'
| Riejufixing |
| fatjames |
 fatjames World Chat Champion
 Posted: 10:57 - 17 Sep 2018 Post subject: |
In Bristol there is a wood recycling project. If you have something like that, you might be able to reduce the cost. (they give pallets for free)
So you could potentially batten it for free. You could even cover it with the wider boards so free if you can joint the edges. Then you could spend your budget on kingspan / rockwooll / screws / plugs.
I wonder if you could fill the void with sawdust? Might be a bit fire risky.
Doing the same on the floor and covering it in carpet (off cuts or free to collector from gumtree), it will help it feel warmer too. (depending on use)
Having some sort of timber walls will make hanging tools and nudie pics easier  |
| Tomzo47 |
 - Super Spammer
| Riejufixing |
The last post was made 7 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
