Seat hight
Mk1
PostPosted: 15:55 - 24 Sep 2018    Post subject: Seat hight Reply with quote
Seat hight
Hi all
I've just got back into the bike scene ive done my CBT and theory test and now waiting to do my mod1 in a few wks but the thing is im worried the seat hight on a 650cc as im only 5'5" ive been practicing my slow riding on my 125cc but not sure if this will help me 650 is a lot bigger. Can anyone give me any advice on this thanks
Renton
PostPosted: 17:10 - 24 Sep 2018    Post subject: Reply with quote
Hi,
The principles of riding slow will remain the same - head up; look forward where you want the bike to go, and be smooth with your inputs.
Does the school you are learning with have a lowered bike? It’s worth asking the question, as most do nowadays.
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
Johanna
PostPosted: 17:56 - 24 Sep 2018    Post subject: Reply with quote
As I said in the other thread, I'm 5'6" and didn't have any problem at all learning to ride a 650cc bike.
Once I passed, I bought a CBR650F which has 810mm seat height. That's about average seat height (as far as I know), but still higher than the various bikes I've seen schools use. I'm very comfortable on my 810mm seat and I'm sure with your similar height you'll wonder why you were worried before!
As for the practice you've been doing on the 125 - yes, that will help a lot! I assume you're taking some lessons before Mod1 with a school? If so they will fill in all the gaps.
Mk1
PostPosted: 22:54 - 24 Sep 2018    Post subject: Reply with quote
Yeah doing a 8 1/2 hour days training on the 28th of next month as they think thats all I need and then test on the monday morning at 8.15. When i been doing a bit of training ive made the distance between the cones smaller as im only on a 125 so hopefully it will help. I've been trying to just keep going round and round on full lock at slow speeds but I keep putting my feet down its so hard to keep my balance
Johanna
PostPosted: 12:25 - 25 Sep 2018    Post subject: Reply with quote
Are you doing a slalom followed by figure of 8?
Remember that you can go quite wide for the figure of 8. For the slalom you go between each set of cones but then you can take the figure of 8 a bit wider. You'll never need full lock.
How are you finding the U-turn?
Mk1
PostPosted: 16:02 - 25 Sep 2018    Post subject: Reply with quote
Yes got it down to around 4mph cant go any slower
Mk1
PostPosted: 16:05 - 25 Sep 2018    Post subject: Reply with quote
Mmmm U turn sometimes im good others end up puting my foot down i know thats a No No on test. Think I'm trying to go to slow
Nobby the Bastard
Harley Gaydar
PostPosted: 20:34 - 25 Sep 2018    Post subject: Re: Seat hight Reply with quote
Mk1 wrote:
im only 5'5"
You lucky bastard! 1/2" taller than me!
Triumph Sprint ST 1050
Johanna
PostPosted: 09:00 - 26 Sep 2018    Post subject: Reply with quote
Try going a little faster than 4mph for slalom and figure-8. See if it helps.
You need to go about 4mph in a straight line for the slow ride. Can you ride slow in a straight line ok?
I genuinely think you're doing things in a way that's more difficult than the test will be. But that's good. It's good practice.
Mk1
PostPosted: 17:10 - 26 Sep 2018    Post subject: Reply with quote
Mrs says that 1/2 inch makes all the difference lol . I'm trying to make it harder so hopefully I will find it easy on my test
Mk1
PostPosted: 17:14 - 26 Sep 2018    Post subject: Reply with quote
In a straight line i can around 3 mph no problem
Freddyfruitba...
PostPosted: 18:19 - 26 Sep 2018    Post subject: Reply with quote
Well that will definitely make a difference Shocked
Kentol750
PostPosted: 22:25 - 26 Sep 2018    Post subject: Reply with quote
8 1/2 hours would be almost dawn till dusk! Good luck.
Some bikes.
PostPosted: 10:29 - 27 Sep 2018    Post subject: Reply with quote
And U turn,
There is nowhere that says how slow the slow riding has to be, it does need to be controlled so if you are wobbling around at 4mph then you are not in control.
The thing is, slow control on the bigger bikes is much easier, the bikes have a lower centre of gravity with the weight and they feel more planted. You'll find it so much easier.
Yeah I have half an inch on you and your mrs tells me the same thing. Wink
Mk1
PostPosted: 14:51 - 28 Sep 2018    Post subject: Reply with quote
I will just keep practicing untill i do my test on the 28th Oct and let you know how I get on Very Happy
bacon
PostPosted: 08:16 - 29 Sep 2018    Post subject: Reply with quote
Height isn't as important as leg length.
I'm 5ft 6 and have 28" legs, proper stumpy! If you have 30-31"+ legs you will have a large advantage.
The riding school gave me a gs500 for my DAS back in the day with a lower saddle, they had it carved out for dwarves like me Smile did the trick.
First bike was a shock though, cbr600f sport, 810mm seat height or so, i was on tip toes.
Every bike ever since has been the same Laughing you get used to it, don't be put off.
Enquire with your school about a low bike. Though when you turn up for training they will do their best to get you comfortable anyway, probably have a lowered bike for shorties, or perhaps a low seat option etc.
Mk1
PostPosted: 16:37 - 29 Sep 2018    Post subject: Reply with quote
Yeah I've asked about the seat hight as you I only have a 28inch leg and they have a 650 with 765mm seat hight so should be ok I hope
Johnnythefox
PostPosted: 22:09 - 29 Sep 2018    Post subject: Reply with quote
repeated fault (hight) makes it a serious fault and results in a MOD 2 fail
Mk1
PostPosted: 12:01 - 29 Oct 2018    Post subject: Reply with quote
Hi everyone just to let you know I passed my mod1 today with no faults
UncleFester
PostPosted: 18:02 - 29 Oct 2018    Post subject: Reply with quote
765mm with a 28" inside leg you won't be flat footed but you'll not be wobbling on tippytoes either. I know from stumpy experience Thumbs Up
Well done on the mod 1 Smile
2017 Z1000SX
Johanna
PostPosted: 09:15 - 30 Oct 2018    Post subject: Reply with quote
Nice one, congratulations!
I had a minor for being slightly slow in the speed trap when I did mine! Well done on the zero faults!
When is your Mod2?
How was the seat height by the way?
Hong Kong Phooey
PostPosted: 12:44 - 31 Oct 2018    Post subject: Reply with quote
Congrats Thumbs Up
https://i.makeagif.com/media/10-31-2018/ChC8_p.gif
doggone
PostPosted: 14:22 - 31 Oct 2018    Post subject: Reply with quote
Hong Kong Phooey wrote:
Congrats Thumbs Up
Brilliant gif, I found the video
https://www.youtube.com/watch?v=YId9Pr_RlIo
Have seen more regular shorter people doing similar with a big off road bike, its worth being able to do it anyway for unexpected awkward moments.
Johanna
PostPosted: 14:40 - 31 Oct 2018    Post subject: Reply with quote
How did that person get from not being able to get on the bike to being able to do that?! Surely the learning process must involve a lot of falling off?
UncleFester
PostPosted: 15:48 - 31 Oct 2018    Post subject: Reply with quote
They are already in gear, clutch gently out and as long as you don't over balance the bike off you go. They are not pushing it off by hand to get going. Big bike = very stable when upright/./ Moving forward
2017 Z1000SX
The last post was made 7 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 124.02 Kb
