Loud ticking sound CBR600F4i
Itchy
PostPosted: 14:02 - 25 Sep 2018    Post subject: Loud ticking sound CBR600F4i Reply with quote
CBR600F4i 2002. No mods other than suspension and stainless exhaust pipes.
Haven't ridden it for a few weeks.
I did however change the oil.
I can't work out what it is.
Is the exhaust blowing?
Clutch rattle? (Honda it's a given).
Cam chain?
Valves need adjustment?
I'd rather find out what the problem is get the bits then fix it rather than take it apart to find out the problem.
Thanks
chickenstrip
PostPosted: 14:07 - 25 Sep 2018    Post subject: Reply with quote
Before I listened to it, I thought, "CBR600, gotta be cam chain" Laughing
Having listened to it, is it the twin cylinder version? Razz
Exhaust blow is what I'm thinking now.
Itchy
PostPosted: 15:31 - 25 Sep 2018    Post subject: Reply with quote
Good guess.
I took the body work off and one of the nuts on the studs is missing on cylinder 1.
Hopefully it will be a simple nut replacement and I've got a couple of them.
Thanks
DrDonnyBrago
PostPosted: 15:39 - 25 Sep 2018    Post subject: Reply with quote
Where does the sound come from? Side, front, top, bottom, back of engine?
Cam chain tensioner noise is much more metallic and more of a rattle than a tap. The typical clutch basket noise isn't tappy either, more of a low level rattle that goes when you pull in the clutch and comes from under the clutch side.
It sounds like a blowing exhaust to me which should be fairly easy to find by feeling and listening for leaks, mine sounded dreadful when a header stud came loose. Does the bike run well?
Itchy
PostPosted: 15:55 - 25 Sep 2018    Post subject: Reply with quote
Found it.
Cylinder 1 the nuts on the collar had come loose.
One was completely missing and the other side was loose.
https://imgur.com/a/nf22iAw
https://i.imgur.com/QcpMQU8l.jpg
So it's just a case of tightening those nuts and thread locking them right Praying
DrDonnyBrago
PostPosted: 16:01 - 25 Sep 2018    Post subject: Reply with quote
Should be. The gaskets are crushed to seal, so there is a chance you might need new gaskets if they blow a bit after tightening up. I have a set of 4 copper CBR600f gaskets you can have if it is still blowing afterwards.
RhynoCZ
PostPosted: 16:37 - 25 Sep 2018    Post subject: Reply with quote
Does it even run on all 4 cylinders? I do agree with the exhaust leak, but even then, it does sound rough.
Itchy
PostPosted: 16:40 - 25 Sep 2018    Post subject: Reply with quote
Thanks for the offer but I still have some left from about 11 years ago when I fixed my other bike. Fat fingers ordered two sets. Thumbs Up
Itchy
PostPosted: 17:59 - 25 Sep 2018    Post subject: Reply with quote
Yes it does, all 4 of the pipes are hot.
I did a lot of riding over the summer and it needs a some servicing.
The problem is that it's pretty much impossible to get into town in under 90 minutes (15 miles) as there are roadworks on every main road into town so I've not had time to do the servicing.
Itchy
PostPosted: 13:00 - 26 Sep 2018    Post subject: Reply with quote
I did up the nut.
There is significantly less noise.
What is worrying however is almost ALL the nuts were loose.
So I guess at the weekend it will be a case of a radiator removal and sticking in some new copper crush washers and thread locking them as the danger (I hope) of the studs snapping is greatly diminished if I can undo the nuts with my fingers.
DrDonnyBrago
PostPosted: 14:09 - 26 Sep 2018    Post subject: Reply with quote
Itchy wrote:
I did up the nut.
Mine were like that a year or so after fitting new downpipes using brass nuts and stainless studs properly dripping in copper grease. I assumed the gaskets settled in a bit and released tension on the studs allowing the nuts to come undone. They didn't loosen off again after I tweaked them all up but I was planning on adding a second nut to each stud to lock them in place if they did.
Can you get threadlock that can handle the heat?
The last post was made 5 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 77.54 Kb
