Honda CB900 chain issues
MisterPrice10...
PostPosted: 17:55 - 25 Sep 2018    Post subject: Honda CB900 chain issues Reply with quote
Hi all
Been riding my 2001 CB900 for a few years now
Have completed a trip to Spain and back no issues last year and numerous ride outs etc this year with no issues
Recently I completed Lands end to John O'Groats, prior to the trip I fitted new chain and sprockets to the bike.
I regularly tightened / lubed the chain during the 1800 mile (ish) trip and seemed to have no issues
Ive just gotten around 3500 miles out of the chain and its stretched so much that the adjusters are as far out as they can go, ive never had a chain strecth as quickly / far as this in such little time
This is the same kit i have used on the bike the year before and that lasted around 5000 miles but with no real adjustment or oiling on that occasion (partly because i forgot to take my tools to spain and partly because I am an idiot)
I would of expected this kit to last much longer seeing as I was taking much better care of it. I wasnt riding nearly as hard as i did in spain and am a bit baffled!
My real questions are:
Has similar happened to anyone else?
Is it safe to fit JUST a new chain, the sprockets dont appear worn or hooked over and seem in good order.
Lastly, i fitted a 530 x 114 chain. IM guessing this means 530 pitch and 114 links? if this is the case im tempted to buy a 530 110 so its a bit shorter and i get more life out of it?
First post here so hope this all makes sense
thanks in advance for any help and hope you are all enjoying safe and sunny riding!
Adam
18 bikes later and still no idea what i'm doing.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:48 - 25 Sep 2018    Post subject: Reply with quote
One word.
Scotoiler.
Triumph Sprint ST 1050
Kawasaki Jimbo
PostPosted: 21:22 - 25 Sep 2018    Post subject: Reply with quote
You might be over-tightening it.
Blockheads121
PostPosted: 21:53 - 25 Sep 2018    Post subject: Reply with quote
4 words - Imports dressed like gold.
Honda100H-MBX125-RG125-NSR125-KH125-Scooter-GSXR400-KX125-XT225-4X-XR400-DRZ400-FZ6-98ZX6F-2000ZX6R-GPZ500S
Confusion
PostPosted: 23:29 - 25 Sep 2018    Post subject: Re: Honda CB900 chain issues Reply with quote
A decent (= made in Japan) chain should not need any adjustment
in just 1800 miles. The DID 530 chain on my ZZR11 has
17,000 miles on it. I expect to get another few thousand out
of it. It needs only very small adjustment every 8,000 miles or so.
What kind of chain is it? I have seen very poor performance
and short lifespan from JT branded chains. IMO, it is best
to spend the few quid extra for a Japanese made chain.
Even 5,000 miles is a very short life for a sealed chain,
unless you did most of that mileage with the front
wheel off the ground?
Yes. My mate fitted JT X-ring chain and sprockets to his
GSX650F. As he was doing a lot of mileage at the time,
they only lasted a few months and just 7,000-8,000km
(around 5,000 miles). The chain needed frequent adjustment
throughout it's short life. It was lubricated regularly and never
over-tightened.
If the sprockets are absolutely perfect, there is no point in changing
them. In my experience, a knackered chain means that there
will be some wear/damage on the sprockets, so you are better
off replacing them. Sprockets are relatively cheap, particularly
when they are part of a C&S kit.
Don't run a badly worn chain. Check the length of 20 links. If it
exceeds the original length by more than around 1%, you should
replace it before it breaks. A brand new 530 chain will be around 318mm
for 20 links. The service limit is around 321mm. For reference,
my 17,000 mile DID measures just over 319mm for 20 links.
I fitted a new DID 530 VX X-ring chain and matching JT sprockets
to my Bandit 650 just over a year ago. It has only done 7,000km
since then. It has not needed any adjustment since it was fitted
and is still in as-new condition.
Please let us know what kind of chains you use and where
you buy them.
Bandit 650SA, ZZ-R1100
jaffa90
PostPosted: 00:04 - 26 Sep 2018    Post subject: Reply with quote
Sounds like an inferior chain this time, also check the tension under load.
MisterPrice10...
PostPosted: 02:28 - 26 Sep 2018    Post subject: Thanks for replies! Reply with quote
Thanks everyone for their replies
The chain was purchased from wemoto (who i have used for years, bought bits for pretty much all 17 bikes I have owned and never had an issue with quality)
However this was part of a JT chain and sprocket kit so it wouldnt surprise me if this was a gold covered copy as was mentioned above (not in that exact wording, i dont know who to quote because im an idiot as previously mentioned)
The comment about over tightening could be an accurate one as well, while I always tried to get it accurate to around 35mm movement i didnt consider that the bike was under full luggage (box and panniers)
Scottoilers are great bits of kit but i dont think thats the issue as i was lubing my chain daily while on tour and regularly when back.
Getting 5000 miles out of the old chain was due to almost zero maintenance and riding.... very enthusiastically.... for days at a time aha.
I think im gonna stick a new chain on as the sprockets look good and should this only last same again look into a higher quality kit next year after the bike goes into hibernation!
Thanks again for replies, this was my first post here and its nice to see everyone is knowledgeable and helpful!
Thanks again
Adam
Nobby the Bastard
Harley Gaydar
PostPosted: 12:05 - 26 Sep 2018    Post subject: Re: Thanks for replies! Reply with quote
A scotoiler is the difference between getting 5000 miles out of a chain and getting 5000 miles between adjustments.
Daily oiling is no substitute for constant oiling.
MisterPrice10...
PostPosted: 18:30 - 26 Sep 2018    Post subject: Re: Thanks for replies! Reply with quote
[/quote]
Daily oiling is no substitute for constant oiling.[/quote]
Ive had scotoilers on bikes before and have found them to be no different than daily oiling, especially where a scot oiler is a drop every few iles on a random part of the chain where as daily oiling is a good dose of oil on all of it, but then again maybe I was a bit too conservative with the fluid when i used mine.
Im reluctant to put them on carbed bikes as the kits often have a breather pipe to carb number 1 (or have in my experience)
maybe a gravity fed kit or similar could help me in future
PostPosted: 18:44 - 26 Sep 2018    Post subject: Reply with quote
The chain being over tightened is about the only possible explanation assuming the chain is made of low quality cheese.
If your scottoiler is only giving a drop every few miles then you need to turn it up. You can tell when it's lubing the chain enough as there'll be a patch of oil left wherever you park. Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 18:57 - 26 Sep 2018    Post subject: Reply with quote
What ste said. You should be getting a four to five drops a minute.
It's not a breqther. It's a vacuum take off (which doesn't affect carb function) which activates a valve which only let's oil through when the engine is running.
The oil itself is gravity fed. You clearly don't know how a scotoiler works which is why you find manual oiling works better.
After all any fool can spray oil all their tyre and destroy their chain in a few thousand miles.
Kentol750
PostPosted: 23:00 - 26 Sep 2018    Post subject: Reply with quote
5k miles for chain and sprockets? It's not normal love. I'd go with bad alignment being an issue. What bike is an 01 cb900? Very early release hornet 900 or an import?
Some bikes.
DrDonnyBrago
PostPosted: 09:57 - 27 Sep 2018    Post subject: Reply with quote
Fit a DID VX chain
Ensure the wheel is aligned properly (check your swingarm etc hasn't been quadraspazzed using the string method)
Don't overtighten the chain
Fit a scottoiler with a dual nozzle
Don't think about it, enjoy 20k+ chain life.
MisterPrice10...
PostPosted: 21:37 - 09 Oct 2018    Post subject: Reply with quote
I'll admit defeat on this one! Definitely didn't understand how they worked properly and had poor advice off the one other person I knew who had one so today is a school day for me!
(I probably should of educated myself on them a bit sooner, but if i did everything I probably should of done I wouldn't have a bike aha)
Good calls all round on the alignment. Looks like im gonna have to spend some £££ but if thats what it takes then thats what we will do!
Will be for after cold weather now but I'm sure ill come back asking for help in the spring! Cheers again
MisterPrice10...
PostPosted: 22:26 - 11 Oct 2018    Post subject: Update Reply with quote
I was going to wait until after the cold weather to sort the bike but I am impatient!
Bike is booked in for a new chain and wheel alignment check next week.
DID XV chain and following the above advice should do the trick (i hope!)
Ideally I would like to do the work myself but I have moved 200 miles from home to a house with no drive / garage and don't have tools or facilities to do it here. Im hoping having a professional opinion on it wll highlight any contributing factors but as I say following the above advice should see me right.
Thanks for all the help with it again, even 10 years into biking every day is a school day!
Confusion
PostPosted: 00:36 - 12 Oct 2018    Post subject: Re: Update Reply with quote
You mean VX? The DID 530VX is a high quality chain. You should
get years of service from it.
IMO, the VX is the ideal chain for your bike. There is a slightly
heavier duty 530 chain from DID. The ZVM-X is even more expensive
than the VX. It would be difficult to justify the higher cost unless
you were fitting it to a hyperbike like the ZZR14 or Hayabusa.
The last post was made 7 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 93.82 Kb
