| bladerunner |
 bladerunner World Chat Champion
 Posted: 00:31 - 25 Sep 2018 Post subject: Mikuni jet sizes in mm?? |
I'm looking for a mm size to compare mikuni hex jet sizes in MM. yup I went cheap and got a "200-300" 10 piece jet kit from ebay on the listing they were stamped 200,210,220 etc however when they arrived I had no stamp..even better they were not all different ie 2 or 3 of the same sizes!! Anyhow I got my money back and they didnt need them returning so I'd like to have a ball park figure if anyone knows the actual diameter of given sizes? I know the test and flow procedure and indeed the differences for the same size due to finish etc but hey I'm up jetting so thought I'd ask as no actual jet size requirement is known until I do some testing so a ball park figure would let me try these jets if I know the 210-240 sizes for a std genuine mikuni but I'm struggling to find any info on the webs! ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| bladerunner |
| sickpup |
 sickpup Old Timer
| ThatDippyTwat |
 Posted: 07:23 - 29 Sep 2018 Post subject: |
Goes to show. I was told this when I was an apprentice, *many* years ago.
Turns out it's shite. You learn every day.
https://i.imgur.com/brAJrU6.jpg ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| Pete. |
 Pete. Super Spammer
 Posted: 08:12 - 29 Sep 2018 Post subject: |
You don't need an expensive tool to measure jet sizes. You can do a very good job using basic tools with a little thought. Here's how I did it when I was making up some jets for my mate's BROS.
*Get a jeweller's screwdriver - the cheap all-metal ones with the little spinning top.
*Grind a very shallow taper on it down to a point. I used a bench grinder with a fine wheel and put the screwdriver in my battery drill on slow speed to make sure it was round. You just need a gentle touch to get a nice finish, or you can use fine emery to make it smooth.
*Use a permanent marker to paint the taper black for each measurement.
*Put the tapered needle in the hole and gently seat it and give it a little turn.
*When you remove the tool there will be a shiny ring in the black. *Measure the taper at that point with digital calipers. That's your hole size. ____________________ a.k.a 'Geri'
| bladerunner |
 Posted: 22:02 - 01 Oct 2018 Post subject: |
where did you find that? AND...does it go upto larger sizes ??? you've done better than I found  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| bladerunner |
 Posted: 00:50 - 06 Oct 2018 Post subject: |
ok I measured the main jet fitted..which being a different carb and std looking motor I got from Scotland a few years ago actually had a 230 main jet already fitted ..measured 1.28mm so I've put in a 1.48mm just to be safe! its a 12a UK restricted carb and the last RD125LC I jetted was a 10w or the full power model....so it wasnt the 155 main I was expecting to find but hey better safe to start with as no airbox and running a 350 lc Allspeed at least having a 230 size to measure means I know I'm in the right ball park  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
The last post was made 7 years, 316 days ago. Instead of replying here, would creating a new thread be more useful? |
