FZ6 No tail light, no turn signals or hazards but fuse ok
edthebad
PostPosted: 19:39 - 29 Sep 2018    Post subject: FZ6 No tail light, no turn signals or hazards but fuse ok Reply with quote
I have recently bought a 2006 FZ6 which was all working this afternoon until I think I accidentally shorted to ground a live feed to the rear bulb. It had been bodged by the po and I was going to solder and heat shrink it, however the fuse it ok which makes me wonder why it and the turn signals no longer work (they're on the same fuse). I have ordered another flasher relay as a possibility but does anyone know what else I could check. Could I have blown the resistors for the indicators and would that or the relay really have affected the whole circuit and not blown the fuse? Just for clarity I changed the fuse and the new didn't make it work either. Any help much appreciated. The bike starts up fine and I have checked all the other fuses in that fuse box just in case.
Ed
cresad
PostPosted: 21:52 - 29 Sep 2018    Post subject: Reply with quote
This might sound daft but have you checked the bulbs themselves ?
Adam
edthebad
PostPosted: 23:20 - 29 Sep 2018    Post subject: Reply with quote
Not a stupid question. , really don't think it's the bulbs as everything was working fine and then suddenly not. Which would mean they would have had tp all go together.
Ed
Sister Sledge
PostPosted: 08:11 - 30 Sep 2018    Post subject: Reply with quote
Electrical isn't a strong point but think of it this way - they share a common fuse so do they share a common ground (Earth) point? Could that common ground point have failed? (melted)
If you don't have one then it's time to grab an electrical test meter. They're useful around the house too.
Islander
PostPosted: 10:38 - 30 Sep 2018    Post subject: Reply with quote
Are you sure the fuse isn't blown? Have you tried substituting a known good fuse?
If yes to the above then check the ground for the rear lights.
Also, as above buy a multimeter. They take a lot of guesswork out of electrical issues. Thumbs Up
edthebad
PostPosted: 12:45 - 30 Sep 2018    Post subject: Reply with quote
I have substituted the fuse. The ground could be an issue but it seems strange that it was working one minute and not the next - as if a fuse had blown. Usually I’m pretty good with electrics (I have an old MGB so I need to be!j, but I’m looking at wiring which has been fiddled with when a po has upgraded to LED signals. It’s as if the circuit has broken somewhere certainly but if it isn’t at the fuse then could it be a resistor or a relay? I’ve ordered a new relay anyway so I’ll have that answer tomorrow but I’ve never known a relay to fail before a fuse.
Ed
Sister Sledge
PostPosted: 08:45 - 01 Oct 2018    Post subject: Reply with quote
If the fuse had a higher fail rating than the bodged in wiring then the wire will be the weakest link.
Could be the wire failing internally or wire which is damaged inside the insulation failing - sometimes incorrect wire frays inside the insulation and those last threads of copper are easily blown.
Please tell me the bodged in wire isn't single strand copper?
Sounds like a full replacement of the wires that have been bodged in are the answer. I know I'd be doing that.
edthebad
PostPosted: 12:57 - 01 Oct 2018    Post subject: Reply with quote
No it's not single strand but I'm inclined to rip it out and start again. I'm leaning towards it being a dodgy earth so I'll get out the multimeter and see what's what.
Ed
Islander
PostPosted: 19:45 - 01 Oct 2018    Post subject: Reply with quote
I'd say that as it's affecting not only the indicators but the rear light as well, it really does have to be an earth unless it's a common live feed further back. You could provide an earth as a test - a bit of wire connected to the negative on the battery connected directly to the rear light earth would be a pretty good indication.
Rednine
PostPosted: 18:14 - 03 Oct 2018    Post subject: Reply with quote
Are your dashboard lights working? I'd also check the white multi connector block behind the screen, assuming it's typical Yamaha
Smoke me a kipper, I'll be back for breakfast.
Hong Kong Phooey
PostPosted: 22:12 - 03 Oct 2018    Post subject: Reply with quote
Sounds like earth wire melted, electrical faults or shorts rarely take out more than one component, that's normally the consequential fire's job. Wink
Brake light circuit gone too?
Common point to all those failed items would be an earth feed or fuse.
There will probably be a wiring diagram in the stickies, possibly gone at the switchgear end rather than where you'd be expecting, but less likely.
I'd start simple. Multimeter the subframe to both test points on the top of the blade fuse, should be continuity. Test battery neg to subframe, same result. Bulb holder to frame, same again. Don't forget to disconnect the +'ve as you don't want to knacker anything else when probing, especially in the bulb compartment.
lukamon
PostPosted: 18:47 - 04 Oct 2018    Post subject: Reply with quote
this happened to my fz6 not a month ago. the cause was crusty connectors under the left hand seat panel. just unplug them a few times to scrape them clean, spray with cleaner, and see if they work Thumbs Up
killa wrote: Im an ass man myself
barrkel
PostPosted: 22:36 - 04 Oct 2018    Post subject: Reply with quote
I had a similar-sounding issue with my VFR once upon a time. It turned out to be corrosion in a connector block. My friendly local mechanic put some shunts around it, took the bad wires out of the block with separate connectors.
Like lukamon, I'd check out the state of your connectors.
The last post was made 7 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 75.4 Kb
