What's "normal" Tyre pressure differences when col
Val
PostPosted: 16:52 - 29 Sep 2018    Post subject: What's "normal" Tyre pressure differences when col Reply with quote
Installed tire pressure monitor.
https://farm2.staticflickr.com/1918/43956742355_04172878a8_k.jpg
https://farm2.staticflickr.com/1931/44817470042_13e3a07da4_k.jpg
https://farm2.staticflickr.com/1947/44817458652_f2cbce90cd_k.jpg
The pressure shown is the pressure when cold 36psi/42psi which is recomended one for MT09. After short ride yesterday I've noticed the pressure rises to 39 psi front and 49 psi rear tyre. Is that "normal"?
I mean I know there is a rule of thumb for cars you always measure tyre pressure when cold.
The question here is what is acceptable rise of pressure after a ride?
Northern Monkey
PostPosted: 17:01 - 29 Sep 2018    Post subject: Reply with quote
Change in pressure is calculated using the equation pv = nrt
In your tyre volume, n and r remain constant, the pressure changes in the same ratio as the temperature (measured in kelvin)
If you’re ike tyres stated at 10c or 283k, then this pressure rise would be given bY a temperature of (283 / 42 x 49) -273 which is 58c
Sounds like you weren’t going very hard to have the tyre temps less than 60
kramdra
PostPosted: 17:08 - 29 Sep 2018    Post subject: Reply with quote
www.google.com/search?q=Gay-Lussac's+law
A 25-40 degree temperature increase is quite possible after a long or fast ride. That is 10-20% total energy of the gas, and the same proportion pressure increase.
Bin the valve cap monitors, they hold the valve open, not good if they fail. In-wheel sort do not appear that expensive, and are very common on cars.
bacon
PostPosted: 17:09 - 29 Sep 2018    Post subject: Reply with quote
Tyre pressures are always set when cold. As a tyre warms up, the pressure will of course increase.
Generally 36F 42R is what manufacturers reccomend, as it's the safest option if you have to take a pillion, or add luggage etc.
However, if you get your bike setup properly, for solo use, they will set your tyre pressures in the region of 36F 36R.
I have my MT09 set at 36F/36R and it works well.
Val
PostPosted: 18:01 - 29 Sep 2018    Post subject: Reply with quote
thank you guys,
according to the formula posted apparently 1 psi increase for 10F is the norm. Means 7 psi increase is expected and if the temp was 50F in the morning (10C) 7 psi means 70F increase which will make the tyre 120F (48C). Seems fine to me.
Yes I do consider to change it for valve rim mounted sensors at some point.
PostPosted: 11:22 - 30 Sep 2018    Post subject: Re: What's "normal" Tyre pressure differences when Reply with quote
Yes - that's quite reasonable.
On track you'd expect a few PSI raise, but start at a good lot lower pressure (ie you're generally looking for around 26 hot in the rear these days.)
Not if you particularly care about having the right pressure Smile - as you do on track, as per above. Where you go by hot - as setting it cold can result in a good bit different pressures when actually riding; depending on the track, ambient conditions and riding style.
grr666
PostPosted: 11:38 - 30 Sep 2018    Post subject: Reply with quote
bacon wrote:
I have my MT09 set at 36F/36R.
Ditto.
johnsmith222
PostPosted: 13:50 - 30 Sep 2018    Post subject: Reply with quote
I would just check and set tyre pressures when cold, check at a minimum monthly, and don't worry about it.
Not sure how I feel about those attached to the valve cap too.
RhynoCZ
PostPosted: 14:29 - 30 Sep 2018    Post subject: Reply with quote
And that is exactly what you are supposed to do. Knowing the ''hot tyre'' pressure is pointless.
kramdra
PostPosted: 19:15 - 30 Sep 2018    Post subject: Reply with quote
I am thinking I will get one. Quite often I stop thinking the tires are not quite right. A couple of times I did not stop and one of those was followed by a rear puncture going completely flat at 70mph... could have easily been a bit faster.... This would let me stop earlier when there is a problem, and restore my confidence when there is not - confidence being extremely important on a bike.
Looms like there are two types for bikes - both valve cap. One is bluetooth and has no dash unit, intended for a phone app. The other, as OP, appears to be 433mhz not bluetooth.
Im unsure if these are interchangeable. The car types mounted on the valve stem, some appear go be bluetooth. I cant see any shorty stem types (tr412).
Unsure if thsse valve caps will work glued inside the rim, they might need (or self contain) a pressure differential, as they likely do not measure absolute pressure.
I belive 36Psi rear pressure is only recommended with a harder shock. Its no good on a standard cbr6.
PostPosted: 20:13 - 30 Sep 2018    Post subject: Reply with quote
You do get motorcycle ones that stick on the rim inside the tyre.
I've got some valve cap ones for my van - after having a puncture from a stone that I'd like to have known about a bit sooner - I made a point of getting metal valve stems as there's a good bit of weight on them compared to a normal valve cap.
The ones that go to bluetooth won't be compatible with the ones that have their own display as far as I know.
MCN
PostPosted: 21:23 - 30 Sep 2018    Post subject: Reply with quote
My BMW K bike has TPMS.
I use the indicated pressure increase it to let me know when the tires are warm enough to engage Sport Mode. Cool
Val
PostPosted: 23:01 - 30 Sep 2018    Post subject: Reply with quote
Funny enough two days after I've mounted TPMS I've got tyre puncture too Laughing
I have noticed the pressure on the rear droping to 36. I have stopped at petrol station made it 44 psi and 30 minutes later on the way home it was 35psi.
Gone to my local mc tyre guys and they found the tyre is punctured. It was slow puncture by really tiny piece 4mmx2mm very sharp rock Shocked When the guy removed the rock and spit on the tyre you'd see the air bubbles.
£25 later I've got full repair. Yes it is useful and I'm very happy with it. Probably will change it at some point with valve mounted sensor one, but it requires to unmounting and mounting again the tyres on the rims which is major PITA. So far this works perfect and the installation was just charging the base unit in the evening and then mounting it for 5 mins on the bars in the morning and screwing the sensor, the easiest job I've done on my bike ever Smile
sickpup
Old Timer
PostPosted: 10:45 - 02 Oct 2018    Post subject: Reply with quote
I actually agree with you for once but there does seem to be a shortage of internal sensor type systems, can you recommend any?
kramdra
PostPosted: 14:16 - 05 Oct 2018    Post subject: Reply with quote
As you are a tire fitter I thought you would know more about them.
PostPosted: 14:44 - 05 Oct 2018    Post subject: Reply with quote
The ones fitted to Triumphs are charged by them at £200 a set when the batteries go flat. They are CR2032s if i remember right and you have to split the plastic to fit them and then reglue if you don't want to pay their exorbitant prices. So don't buy Triumph ones!
Val
PostPosted: 23:31 - 06 Oct 2018    Post subject: Reply with quote
Here is one that is exactly like mine, but the seller gives you the option to buy it with internal sensors by senidng him email asking for Built in WI: https://www.ebay.co.uk/itm/Motorcycle-Bike-TPMS-Tire-Tyre-Temp-Pressure-Monitoring-System-2-Sensor-CAREUD/263889569797
Obviously this comes somewhere from China, if I can find who sells the sensors only would be great Very Happy
Steelmate do 3x times more expensive: https://www.steel-mate.co.uk/acatalog/TP-90I-Pro-Professional-Motorcycle-Tyre-Pressure-Monitoring-System-317.html#SID=53
The problem with the internal sensors is you can't change the battery.
The last post was made 7 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 99.71 Kb
