Honda hornet 900 cooling fan always on when riding
nikle46
PostPosted: 20:01 - 06 Oct 2018    Post subject: Honda hornet 900 cooling fan always on when riding Reply with quote
Fan start on higher throttle position and stop as soon as the throttle is returned to idle. To explain.. bike has been idling from cold for say 3 minutes, I open the revs to 3000 and after about 5 seconds the fan comes on... the gauge is reading below C at this time.. and the fan will stop as soon as the throttle is shut, i can repeat this over and over. When running if dont touch the throttle everything is normal, gauge goes to between, fan starts works normal and then turn off
jaffa90
PostPosted: 01:00 - 07 Oct 2018    Post subject: Reply with quote
I don`t think you have a problem but check the thermo switch or replace it.
nikle46
PostPosted: 09:01 - 07 Oct 2018    Post subject: Reply with quote
There is not therm switch, there is only temperature sensor that sends info to ecu, and ecu activates cooling fan reley
recman
PostPosted: 09:03 - 07 Oct 2018    Post subject: Reply with quote
Ride faster.
jaffa90
PostPosted: 10:24 - 07 Oct 2018    Post subject: Reply with quote
Check the sensor then.
nikle46
PostPosted: 13:46 - 09 Oct 2018    Post subject: Reply with quote
I change 3 sensors, thermostat, coolant, everything is normal when not push throttle, when ride on 2000 rpm or more fan comes on, when release throttle it stops. weird problem
The last post was made 7 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 46.04 Kb
