cb1300
mucker
PostPosted: 13:06 - 07 Oct 2018    Post subject: cb1300 Reply with quote
hi all does any one know how to stop tank slap on a Honda cb1300
it happens between 30 to 50 mph Confused
RhynoCZ
PostPosted: 13:26 - 07 Oct 2018    Post subject: Reply with quote
Tyre pressure, steering bearings, the suspension system needs some care.
jaffa90
PostPosted: 18:01 - 07 Oct 2018    Post subject: Reply with quote
Sounds in a bad way, i would be jacking the bike up and spinning /feeling them tyre & wheels.
Sister Sledge
PostPosted: 19:18 - 07 Oct 2018    Post subject: Reply with quote
As RhynoCZ says - those need to be spot on. Even something a little 'off' can make a lot of difference.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:53 - 07 Oct 2018    Post subject: Reply with quote
Steering bearings too loose.
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 22:01 - 07 Oct 2018    Post subject: Reply with quote
Are you sure it's a tank slapper? Describe us what the motorcycle does. Unbalanced front wheel does all sorts of things once you hit the sweet spot (speed) and then it goes away as you exceed higher speed.
mucker
PostPosted: 08:54 - 08 Oct 2018    Post subject: Reply with quote
Hi all i have had my tyres balanced front and back both steering bearings replace. When my bike gets to 30 if i lift my hands slightly of the bars it shakes left to right violently any thing over 50 its totally smooth
Nobby the Bastard
Harley Gaydar
PostPosted: 11:05 - 08 Oct 2018    Post subject: Reply with quote
Steering bearing nuts are too loose. Typically your looking at 50nm or higher torque
RhynoCZ
PostPosted: 14:24 - 08 Oct 2018    Post subject: Reply with quote
I agree with Nobby.
rpsmith79
PostPosted: 15:53 - 08 Oct 2018    Post subject: Reply with quote
Wobble or weave?
Worth a watch
https://www.youtube.com/watch?time_continue=1&v=fvsDIq3WwVA
tittymcarsefa...
PostPosted: 22:28 - 16 Oct 2018    Post subject: Reply with quote
Are your tyres in good nick? tyre pressures ok?
Make sure your rear wheel is aligned correctly then check the front wheel is in line with the rear.
Could be accident damage upsetting the geometry on the bike, check for cracked paint around the head stock area especially around the welds.
No need for one of those to be shaking the bars at those speeds tbh they are set up for stability rather than handling.
The last post was made 7 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 65.55 Kb
