| Phil_B |
 Phil_B Borekit Bruiser
 Posted: 22:47 - 13 Mar 2017 Post subject: |
Hiya
When you attach the cable you poke the cable through the end of the housing, then push the end out through the window, push the blade in place with the hole for the nipple in line with the window, hook the nipple into place and then rotate the blade 180 degrees within the housing. Then the nipple on the cable is held in place by the housing.
Can you take a better piccy of the flywheel? So I can see the holes. On the 123 flywheel the holes are blanked off.
Note that VERY early 123 engines had the same ignition as the 127, but think these early ones were only fitted to the Red Rose custom thing
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Phil_B |
 Posted: 23:00 - 13 Mar 2017 Post subject: |
 Posted: 23:10 - 13 Mar 2017 Post subject: |
Yep, that looks like a 127 flywheel. On the 127 ignition (which has a black coil rather than the blue coil) there is a set of timing marks embossed on the stator. Hence you can check the timing with a strobe light through the cutouts (as the 123 ignition advances with rpm, this isn't really worthwhile on a 123).
The flywheels are hard to find for sensible money so people tend to stick on whatever they can find.
I am toying with having a batch of flywheels made up, just drilled to take the existing starter gear (place has made SEM flywheels before but only for non electric start models, and they are not interested in making the electric start ring gear).
| Phil_B |
| Phil_B |
 Posted: 07:54 - 14 Mar 2017 Post subject: |
I guess it is possible it's been changed, although I never had any issues with it starting so can't really see why it would have been. Just one of those things, I've learnt a little bit more, you are a wealth of knowledge  ____________________ This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3 |
| Phil_B |
 Posted: 09:39 - 14 Mar 2017 Post subject: |
| NutsyUk |
 NutsyUk Nearly there...
| Phil_B |
| chris-red |
 Posted: 16:48 - 14 Mar 2017 Post subject: |
It's really bugging me you are using that mankey manifold and plastic covers on that lovely clean engine.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Phil_B |
 Posted: 17:05 - 14 Mar 2017 Post subject: |
It's bugging me too! Once up and running I'm thinking about putting the 34mm carb on which will require a new manifold so that'll be sorted. The plastic covers do need something doing with them, but I'm not sure what yet, I guess a spray to match the engine is the best option. ____________________ This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3 |
| chris-red |
 Posted: 17:51 - 14 Mar 2017 Post subject: |
You'll struggle to get it bob on, it might be worth thinking about a complementary colour instead  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
There is a gap of 1 year, 195 days between these two posts... |
| BenR |
 BenR World Chat Champion
| Phil_B |
 Posted: 23:42 - 10 Oct 2018 Post subject: |
As embarrassing as it is....not yet!
It's still ongoing, I've done a few bits here and there as and when I've had chance, but it's still a work in progress...
I haven't given up on it yet...one day! haha  ____________________ This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3 |
| BenR |
| Phil_B |
 Posted: 19:40 - 15 Oct 2018 Post subject: |
I've been getting some stick off my work colleagues with it dragging on...I got told to get my lad on it as he's got his hand in with some lego technic, might get finished then! haha
Hoping to have something to show soon...then again...  ____________________ This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3 |
| stevo as b4 |
| Phil_B |
| BenR |
 Posted: 22:10 - 15 Oct 2018 Post subject: |
| Phil_B |
 Posted: 20:33 - 06 Nov 2018 Post subject: Aprilia AF1 125 Replica - Full Rebuild - Updated 6-11-18 |
So, after a very long break in the project, with several false starts, I've finally got going on the rebuild. With all the bits that I have replaced, I'm not sure
if the project is a restoration or a rebuild, realistically a hybrid of both. This project has been many things for me, but the end product of being able to ride the
motorbike that I bought in 1991 is all that counts.
When I started off taking photos, I wanted to make sure that everything went back to where it came from, but it's evolved into a full-on geek account of what I've been up to!
For those that have followed the project, I hope you'll enjoy seeing the bike returning to how it should be, piece by piece. As I go along I'll try to remember what I've
replaced, and what I've done, so you can see the full picture of what this has taken. Unfortunately I seem to have lost the file with all the costs involved, but it's
been way more than the bike is worth now, and what I paid for it to start with...it's only money, and you can't take it with you at the end!!
Front wheel
Powdercoated original wheel. New bearings, wheel spacer, disc bolts, brake disc.
1 - Fit first bearing
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/1DSCF1010_zpsxwvnpekw.jpg
2 - Insert spacer
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/2DSCF1011_zpsxijat1nq.jpg
3 - Fit second bearing
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/3DSCF1012_zpsuprkptpk.jpg
4 - Loctite disc to wheel
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/4DSCF1023_zpsdtwyxob4.jpg
Frame & yokes
Powdercoated original frame and top yoke. New top bearing
1 - Fit top bearing
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/5DSCF1028_zpshuvjrbqn.jpg
2 - Fit bearing cup
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/6DSCF1027_zpsmoiq4tlf.jpg
3 - Grease bearing and fit stem into frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/7DSCF1031_zpspmnfipcr.jpg
4 - Place cover over stem, top bearing and frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/8DSCF1039_zps64gwb6a6.jpg
5 - Fit stem nut and tighten
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/9DSCF1041_zpsa1cxzrml.jpg
6 - Place top yoke over stem
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/10DSCF1071_zpshxc93ijj.jpg
7 - Fit nut into stem and tighten
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/11DSCF1045_zpsmnhvg0gi.jpg
8 - Frame up onto paddock stands
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/12DSCF1047_zpsmqedovhj.jpg ____________________ This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3 |
| Phil_B |
 Posted: 20:39 - 06 Nov 2018 Post subject: |
| Phil_B |
 Posted: 20:43 - 06 Nov 2018 Post subject: |
| Phil_B |
 Posted: 20:45 - 06 Nov 2018 Post subject: |
| Sister Sledge |
The last post was made 8 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
