downpipe glowing
thedodge
PostPosted: 21:41 - 13 Oct 2018    Post subject: downpipe glowing Reply with quote
1998 carb model honda blackbird 1100xx, right hand middle down pipe glowing red hot. any help would be appreciated, the bike is very rarely used. Thank you. I must add the Bike probably hasn't done 100 miles in 5 years so would like to think there is no damage.....
Riejufixing
PostPosted: 21:49 - 13 Oct 2018    Post subject: Re: downpipe glowing Reply with quote
Oh dear.
https://www.bikechatforums.com/viewtopic.php?t=325887&highlight=
Third post.
Possibly valve trouble of some sort.
iooi
PostPosted: 18:05 - 14 Oct 2018    Post subject: Re: downpipe glowing Reply with quote
Is this while it is moving Shocked Or when you are just sat there not going anywhere...
thedodge
PostPosted: 18:11 - 14 Oct 2018    Post subject: downpipe glowing Reply with quote
Hi as far as I know its just when stationary, I've not noticed it before, it hardly ever gets used , I just fire her up now and then to keep her going and noticed it one day
PostPosted: 18:16 - 14 Oct 2018    Post subject: Reply with quote
Carb model or injection?
Doesn't matter really, it's probably gummed up and running lean on that cylinder. Running just a little bit lean will push exhaust temps up a lot.
thedodge
PostPosted: 18:20 - 14 Oct 2018    Post subject: glowing downpipe Reply with quote
So a quick blast up the road 5/6 miles should be ok either way without doing damage, and probably sorting it out?
BusterGonads
PostPosted: 19:09 - 14 Oct 2018    Post subject: Re: glowing downpipe Reply with quote
I'd warm it up and then do a compression check. My bet is that the affected cylinder will show low compression from a leaking valve. It could just be mis adjusted or it might be burned away. I don't see a weak mixture on its own making the pipe hot enough to glow while ticking over, or running hard come to that. You've got high energy gases escaping the exhaust valve during combustion I think. Weak mixtures mind you will eventually destroy exhaust valves and lead to this symptom.
tittymcarsefa...
PostPosted: 19:34 - 14 Oct 2018    Post subject: Reply with quote
If it's a carb model you might have a blocked idle jet on that cylinder causing it to run lean or an air leak on the inlet stubs.
Sister Sledge
PostPosted: 19:56 - 14 Oct 2018    Post subject: Reply with quote
Stuck valve from sitting around? If stuck slightly open the exhaust valve could be letting the burning mixture down a pipe??
Compression test it - all cylinders to look for signs.
Could also be a damaged valve where it seats.
RhynoCZ
PostPosted: 20:22 - 14 Oct 2018    Post subject: Re: downpipe glowing Reply with quote
PostPosted: 20:38 - 14 Oct 2018    Post subject: Reply with quote
Pete will be right btw...
thedodge
PostPosted: 20:57 - 14 Oct 2018    Post subject: glowing downpipe Reply with quote
Thanks for your thoughts and help guys, it's obviously mixture or a valve/valve clearance problem
bikenut
PostPosted: 09:46 - 18 Oct 2018    Post subject: lack of use Reply with quote
lack of use, you are a biker so only use it on sunny summer sundays, whilst motorcyclists use theirs all year round, but keep a very keen eye/nose for diesel and black ice. :karma:
nuts about bikes
PostPosted: 23:52 - 18 Oct 2018    Post subject: Reply with quote
^ wang, have car, use car. Pointless freezing for a fucking title. Laughing
bikenut
PostPosted: 08:41 - 19 Oct 2018    Post subject: cold Reply with quote
never the less, lack of use so there!
nuts about bikes
ThatDippyTwat
PostPosted: 15:10 - 19 Oct 2018    Post subject: Reply with quote
You only freeze if you buy shit/incorrect gear. Wink
sickpup
Old Timer
PostPosted: 13:11 - 20 Oct 2018    Post subject: Reply with quote
Perished or missing carb balance point cover for that cylinder. Wink
PostPosted: 14:31 - 20 Oct 2018    Post subject: Reply with quote
I ride for enjoyment, not to increase my clothing collection.
The last post was made 7 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 94.67 Kb
