| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:14 - 16 Oct 2018 Post subject: Just one coat of Sandtex... |
...makes a fair bit of difference.
A lot of the brick had different textures, so some were smooth, some engineering, whilst others rough and drank the paint. Second coat is now on, but will wait to see what finish is like once it's dry. Asbestos ceiling is being sealed today, power being run in by the weekend, then electric roller door. Going to be a few weeks of being crammed with furniture whilst the rest of the house is being done, but operation mancave is underway
https://cdn.bcf.44bytes.net/files/garage_2.jpg
https://cdn.bcf.44bytes.net/files/garage_3.jpg ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| bacon |
 bacon World Chat Champion
| Freddyfruitba... |
 Posted: 13:29 - 16 Oct 2018 Post subject: |
But... but... Sandtex is exterior grade paint - you do realise you will now die from the fumes leaching out over the next few years?  ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
| The Shaggy D.A. |
That's just a single 11w LED portable worklamp from Screwfix I used whilst painting at night.
https://www.screwfix.com/p/diall-portable-led-work-light-11w-220-240v/2564k
I'm not going to need much more lighting, methinks. One warm overhead for when just putting the bikes away and getting stuff off the racking, then a few white strips over the work area and either side of the front section switched separately. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| The Shaggy D.A. |
| B5234FT |
 B5234FT Brolly Dolly
| Riejufixing |
| The Shaggy D.A. |
 Posted: 14:17 - 16 Oct 2018 Post subject: |
Aye, the floor will be done. Not sure of my budget yet. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| B5234FT |
 Posted: 15:48 - 16 Oct 2018 Post subject: |
| Sister Sledge |
 Posted: 21:19 - 16 Oct 2018 Post subject: |
Best thing you can do to brick shed walls is white paint - brightens it and needs less lighting fitted in the end. Makes a good clean surface and gives contrast behind shelves that allows things to be found easily.
I always use old leftover emulsion for that because of the initial absorption.
Envious that you have such a big space - I'm about to knock an inner wall out to allow myself more working space - probably 2 more square metres  |
| grr666 |
 grr666 Super Spammer
 Posted: 21:32 - 16 Oct 2018 Post subject: |
Smashing job. Nice garage. Still waiting for mine to be built. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| tittymcarsefa... |
 tittymcarsefa... Borekit Bruiser
 Posted: 01:44 - 17 Oct 2018 Post subject: |
For some reason is miss read it as one coat of spandex , I was expecting some nsfw pics. |
| Irn-Bru |
 Irn-Bru World Chat Champion
 Posted: 06:38 - 17 Oct 2018 Post subject: |
Will soon be doing my garage up, white walls and grey floor paint me thinks. Currently got a up and over door which is about 5'10" tall when opened up (just enough to hit your head on) so need to replace that as there is another foot or so above that could be utilised by a roller door. Been told it's very easy to go overboard with LED lights so start off with 2 and see if you actually need more. Mines got 5 or 6 old strip lights in at the minute that will be going, just replaced the house lights with LED ones and they are the shit
How much are electric roller doors these days? I'll be needing a new frame on mine (rotten at the bottom) so that'll add a bit extra to things. Can they be operated if the power goes off? no side door on mine. ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| BTTD |
 BTTD World Chat Champion
| Serendipity |
 Serendipity World Chat Champion
 Posted: 10:20 - 17 Oct 2018 Post subject: |
I went with large interlocking vinyl floor tiles which I bought from bigdug:
https://i.imgur.com/lY2DHV9h.jpg
I used Sketchup to plan out how many I would need and they were pretty heavy. They turned up on a pallet.
They've been down for two years now and are surviving fairly well. Sort of wish I'd put down that thin underlay for a bit more insulation and sound-deadening, but not enough to go lifting them all.
The light grey ones have discoloured slightly where I ride dirty bikes onto them all year round, but the floor is much easier to sweep and mop than bare concrete. I do use side stand pucks to stop the stands sinking in, but where I've dented the tiles with center stands the marks have vanished after a while. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| The Shaggy D.A. |
 Posted: 12:56 - 17 Oct 2018 Post subject: |
| Irn-Bru wrote: | How much are electric roller doors these days? I'll be needing a new frame on mine (rotten at the bottom) so that'll add a bit extra to things. Can they be operated if the power goes off? |
Depends on whether you go for single skin, double skin, insulated, etc. This'll give you a guide :-
https://www.thegaragedoorcentre.co.uk/type-and-price-guide/Roller-Garage-Doors/price_range+asc
There's a manual winding system for if the power goes off. Wouldn't be too hard to incorporate a small backup battery & inverter. Might look at that myself now I'm moving to a village
| jnw010 wrote: | I've done my garage floor in plastic tiles by Plasfloor. Single garage cost about £250 iirc. |
| Serendipity wrote: | I went with large interlocking vinyl floor tiles which I bought from bigdug: |
Online calculator estimates £288, without mentioning delivery, for the Plasfloor and around £350-400 including delivery from BigDug. I like it, may go that route in the future, but it's not as though the garage will be seeing any heavy duty use - just parking and basic servicing really. Not sure I want to spend that much when a couple of coats of paint would be £30 Spare cash is going into the house at the mo. And £400 would go towards a second bike, too
| jnw010 wrote: | Also, if you can cut some French cleat strips for the wall you can hang stuff all over and easily re-arrange. |
Aye, that's on my list  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 18:05 - 17 Oct 2018 Post subject: |
Someone sells heavy duty floor paint on gumtree for £40 for 20L, and will deliver too - don't know if that ups the price or not tho. ____________________ A Guide To Powerbands |
| woo |
 woo World Chat Champion
| kerr |
 kerr World Chat Champion
 Posted: 20:01 - 17 Oct 2018 Post subject: |
Yip, always go for industrial floor paint, avoid domestic stuff as even the trade paint isn't tough enough to deal with shoes let alone tyres.
Did a job in an mot garage some years ago and i pleaded with the guy to spend just a little bit extra on industrial floor paint but no, went for domestic and it lasted weeks  ____________________ aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple |
| stevo as b4 |
| The Shaggy D.A. |
 Posted: 23:56 - 17 Oct 2018 Post subject: |
If you raise up the leg braces on that pallet bench you can slide stuff under it AND have a shelf for storage. ____________________ a.k.a 'Geri'
| The Shaggy D.A. |
 Posted: 11:14 - 18 Oct 2018 Post subject: |
| Triumph1300 |
 Triumph1300 Nova Slayer
 Posted: 15:01 - 22 Oct 2018 Post subject: |
Doug,
Do you want my GT550 to put in that space??? ____________________ BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit  |
The last post was made 7 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
