Car audio Sub/Amp quesiton.
PostPosted: 17:46 - 16 Oct 2018    Post subject: Car audio Sub/Amp quesiton. Reply with quote
Hi all,
I recently bought a 2004 Scooby Forester STI
As standard this model comes with a Sub in the boot, it is a 6x9. This sub is amplified by the stock headunit, however as this is an import I do not have the stock head unit. I fitted an Android Head unit which has a RCA sub out. I fitted a Speaker wire to RCA convertor to sub connector but it doesn't work. A bit of research says this signal needs to be amplified.
All I want to to do is replicate what the stock headunit was doing however single channel sub amps are expensive and MASSIVE. I just want a cheap little box I can hide and will make the sub make noise.
Any ideas how I can get it to work? One option is to wire the sub into the rear speakers but I'd rather keep it separate so I can control it with the sub level on the head unit.
PostPosted: 18:15 - 16 Oct 2018    Post subject: Re: Car audio Sub/Amp quesiton. Reply with quote
chris-red wrote:
Hi all,
Would something like this work?
https://www.ebay.co.uk/itm/DC-12-24V-TPA3116-D2-100W-Mono-Channel-Audio-Power-Amplifier-Board-for-Car-TE633/153186791680?hash=item23aaa4f100:g:pksAAOSwb-RbojT1:rk:1:pf:0
PostPosted: 20:06 - 16 Oct 2018    Post subject: Reply with quote
Your headunit sub out is good to have as it'll handle the crossover, that amp module has to be worth a punt.
It'll get warm so best fit on a metal plate/chassis which leads me to the earthing point. Where is it and etc etc.
Suspect there is a video to help.
PostPosted: 10:41 - 17 Oct 2018    Post subject: Reply with quote
Anything needs to be special about the earth? Just make sure it has a good one right?
The last post was made 7 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 42.94 Kb
