Villiers Junior Carburettor
Jiggers
PostPosted: 20:52 - 20 Oct 2018    Post subject: Villiers Junior Carburettor Reply with quote
Parts listed for this Carburettor some times shows Tapered Needle Spring and Control Cable Spring, other places show just the taper needle spring. Are both springs required or just one?.
I am restoring a 1950's James Autocycle with a Villiers 2F engine, but unfortunately a lot of the small parts are missing, including the throttle cable and the spring(s)
Your help would be much appreciated.
James 1950 Autocycle
jaffa90
PostPosted: 23:41 - 20 Oct 2018    Post subject: Reply with quote
It is common to have a throttle return spring, from memory a tapered needle spring is to stop it flapping about under vibration and wearing its parts. Maybe an old biro pen spring may help or other light spring.
Jiggers
PostPosted: 15:42 - 22 Oct 2018    Post subject: Reply with quote
Thank you for your reply.
Lyle
bikenut
PostPosted: 10:14 - 25 Oct 2018    Post subject: Reply with quote
will check in my little red villiers book for you.......
nuts about bikes
bikenut
PostPosted: 10:49 - 31 Oct 2018    Post subject: villiers Reply with quote
sorry for delay, scanner power supply died.......pic coming over now, if its fuzzy can scan where I am at present.......any other info needed ?
ah that came out better than expected.....
nuts about bikes
Jiggers
PostPosted: 14:31 - 31 Oct 2018    Post subject: Reply with quote
Thank you for your reply and scanned image. This helps a lot.
Lyle
bikenut
PostPosted: 10:59 - 01 Nov 2018    Post subject: lyle Reply with quote
need any more info....in process of fixing the scanner power supply but the picture cam out quite well....
nuts about bikes
The last post was made 7 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 49.17 Kb
