Power commander MT09 2017
onlyzeros
PostPosted: 08:23 - 21 Oct 2018    Post subject: Power commander MT09 2017 Reply with quote
Hi everyone,
I have an MT09 2017 with a full Akrapovic exhaust and I recently went to a garage to fit a power commander V on it.
So it was fitted, put on a dyno and got tottal of 128 bhp a gain of 12bhp.
I just want to know your opinion on this result.
Thank you
Evil Hans
PostPosted: 08:32 - 21 Oct 2018    Post subject: Reply with quote
I'd be slightly worried about it appearing to be running leaner than it was before, given that modern bikes are tuned to run a bit lean already. But I'm no expert. Other than that ... meh. How does it feel?
onlyzeros
PostPosted: 08:48 - 21 Oct 2018    Post subject: Reply with quote
Before it was popping a lot but now not so much. So I thought was running rich.
Running too lean or this lean can be a problem?
Edit: I got confused rich vs lean. Sorry.
Nobby the Bastard
Harley Gaydar
PostPosted: 08:58 - 21 Oct 2018    Post subject: Reply with quote
onlyzeros wrote:
I'm not an expert either but are you sure it's leaner? Before it was popping a lot but now not so much.
One of the reasons i wanted a PCV was because with the full exhaust was running lean already and popping a lot.
Popping means rich, it's unburnt fuel igniting in the exhaust.
bacon
PostPosted: 09:32 - 21 Oct 2018    Post subject: Reply with quote
You don't need a PCV to flash the MT09 btw, bit late now I know.
Many companies do it with the stock ECU with Woolwich, they can control the fueling properly through the ECU. They can also disable the AIS, remove the speed limiter etc which I don't believe a power commander can.
What other mods do you have? 128bhp at the rear wheel seems very generous.
onlyzeros
PostPosted: 11:22 - 21 Oct 2018    Post subject: Reply with quote
I was told by HM Racing that it would be better to go with PCV because there can be problems with flashing ecu. That's why I went with PCV.
At the moment the mods I have it's just a full Akrapovic exhaust with a short (sliced) DB killer.
Formerly known as
P.
PostPosted: 15:20 - 21 Oct 2018    Post subject: Reply with quote
Company in 'you should buy this cos it's better' shocker Laughing
bacon
PostPosted: 12:29 - 22 Oct 2018    Post subject: Reply with quote
Most seem to get around 118 to 120bhp at the rear wheel with a full system (baffle out) and an ECU map.
Have they quoted you a crank figure maybe? Still seems high though.
Robby
Dirty Old Man
PostPosted: 12:54 - 25 Oct 2018    Post subject: Reply with quote
Assuming the blue line is the new one, it's running richer, not leaner. More consistent, too.
Evil Hans
PostPosted: 17:14 - 25 Oct 2018    Post subject: Reply with quote
Yeah, sorry you're right. I was thinking Fuel/Air ratio when it clearly says Air/Fuel ... doh!
The last post was made 7 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 63.23 Kb
