aftermarket levers
bigdom86
PostPosted: 13:48 - 23 Oct 2018    Post subject: aftermarket levers Reply with quote
hi all
looking for some adjustable aftermarket levers for the CBR, any recommendations? I have small hands (medium or large gloves) so sometimes find it difficult to throttle and cover front brake at same time in situations where I want to
PostPosted: 13:53 - 23 Oct 2018    Post subject: Reply with quote
I have some cheapo chinese pazzo knock offs (not shorties, full length ones) on my CBR600RR, and they are quite nice. They work for what I want, and unlike the shorties I don't miss the end when suddenly grabbing a handful of brake. I've heard some stories of badly made ones causing accidents and stuff, but these seem OK. Came from ebay, cost about £18 and took about six weeks.
grr666
PostPosted: 14:53 - 23 Oct 2018    Post subject: Reply with quote
https://www.ebay.co.uk/str/jaybeebikerbits
Got a nice set of shorties for my MT09 from here. No doubt also chinese made but I'd sooner deal with a UK seller,
particularly in the event of not being 100% satisfied. The chinks are experts at taking deliberately misleading photos
of the crap they flog on ebay, and it's the gweilos own job deciphering their pidgin like delay tactic responses in the likely
event of a problem with shoddy goods.
DrDonnyBrago
PostPosted: 15:21 - 23 Oct 2018    Post subject: Reply with quote
I had chinese Spazzos on my CBR (same model as yours). Cost £15 but they needed a bit of fettling to fit right. On the clutch side there was a little pokey out tooth to activate the clutch switch that was a bit too big and needed filing down so that the lever wasn't held back a little.
Can see the tooth on the bottom left of this image:
https://images-na.ssl-images-amazon.com/images/I/61NxI2s9ToL._SL1001_.jpg
Took about 10 minutes, filed maybe 0.5mm of metal from the front of the tooth. Just file away until the lever sits flush against the lever mount.
natefz6
PostPosted: 16:37 - 23 Oct 2018    Post subject: Reply with quote
They look just like the ones I have on my fz6, they have also been fine for 3 years including going down the road once :/
"no I didn't steal it that's just the way I ride"
wristjob
PostPosted: 17:08 - 23 Oct 2018    Post subject: Reply with quote
get some cheapo ones.i would avoid the ones with adjustable lever length(not because they wont fit just because they look shit)
if they fit you will be fine,
if you need to adjust them to fit and you are happy to do it then you'll be fine.
if they dont fit then dont fit em.
people will tell you about how they died because of cheapness.
if you dig into their stories you will find out that they knew they didnt fit right and still went out with them.
find some you like,fit em and move on with life.
Kentol750
PostPosted: 18:21 - 23 Oct 2018    Post subject: Reply with quote
Bought some short adjustable ones on eBay for wife's cb1000r, (probably same fit) very reasonably priced (less than a Honda clutch lever). As said, check feedback before committing to buy.
Some bikes.
AshWebster
PostPosted: 11:45 - 24 Oct 2018    Post subject: Reply with quote
got some cheap ones off amazon. work ok, loose ish fitment though.
i'd recommend RSV unbreakable levers however.
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
DrSnoosnoo
PostPosted: 12:09 - 24 Oct 2018    Post subject: Reply with quote
AshWebster wrote:
...i'd recommend RSV unbreakable levers however.
Why?
kramdra
PostPosted: 18:13 - 25 Oct 2018    Post subject: Reply with quote
As with any lever you need to check clearance on the brake when fitting. There are a lot of different bikes and master cylinders that these levers fit.
Recommend the ebay folding shorties - not the adjustable length ones, about 15 quid delivered. Only dislike is the red adjusters will turn pink after a few months in the sun..
Ed Case
PostPosted: 22:14 - 25 Oct 2018    Post subject: Reply with quote
I had some Chinky full size Pazzo rip-offs for my then ER6F for £16 delivered and they were spot on, in fact far more precision than the standard Kawa parts. A great buy !.
Hong Kong Phooey
PostPosted: 22:41 - 25 Oct 2018    Post subject: Reply with quote
I bought these.
https://www.ebay.co.uk/itm/CNC-Adjustable-Foldable-Extendable-Levers-Honda-CBR600-F2-F3-F4-F4i-1991-2007/172291466957
I checked them thoroughly before fitting, and there was no issue with the MBC.
The screw (and bush iirc) from the existing levers is required to be reused.
They're still fine after 18 months and feel so much better than the standard set.
Ed Case
PostPosted: 22:57 - 27 Oct 2018    Post subject: Reply with quote
Hong Kong Phooey wrote:
I bought these.
If they are anything like the ones I got for my 6F, and they look like they are, the quality is superb !.
bigdom86
PostPosted: 10:59 - 29 Oct 2018    Post subject: re Reply with quote
I bought these.
these were one of the first ones i came across when searching and looked good to me, think i will go with these ones cheers
Ed Case
PostPosted: 23:11 - 29 Oct 2018    Post subject: Re: re Reply with quote
I bought these.
Report back to 'The Panel' when you get them, OK ?.
bigdom86
PostPosted: 12:09 - 30 Oct 2018    Post subject: Re: re Reply with quote
Report back to 'The Panel' when you get them, OK ?.[/quote]
aye aye captain Thumbs Up Very Happy
The last post was made 7 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 88.21 Kb
