Yamaha yzf can't start when overheat
alexsobike
PostPosted: 07:47 - 24 Oct 2018    Post subject: Yamaha yzf can't start when overheat Reply with quote
Hi everyone,
When i am trying to start my motorbike when engine is cold everything looks fine,
after few seconds when temp reach to 100 degrees Celsius (212 degrees Fahrenheit), i am turning off the engine.
now when trying to start it again engine wont start, please edvice.
video added.
https://vimeo.com/296646748
https://vimeo.com/296646819
jaffa90
PostPosted: 09:16 - 24 Oct 2018    Post subject: Reply with quote
The engine won`t start because the battery is in a low state and re-coups (!) when switched off.
I would check battery to bike connections and the charging system.
Have you a multi-meter?
alexsobike
PostPosted: 09:58 - 24 Oct 2018    Post subject: Reply with quote
Thanks for quick response,
We already checkef the charging system.
Replaced the starter.
New battery.
Wire harness.
Coils.
Clutch.
throttle body.
Teflon-Mike
tl;dr
PostPosted: 10:19 - 24 Oct 2018    Post subject: Reply with quote
If you crank it with the plugs out... anything spray out the plug-holes?
jaffa90
PostPosted: 10:23 - 24 Oct 2018    Post subject: Reply with quote
Is the battery connected to the bike, also have you tried jump leads.
What `s the battery voltage when cranking like the second video using the black probe on the frame and engine?
alexsobike
PostPosted: 10:49 - 24 Oct 2018    Post subject: Reply with quote
No, nothing spray out
Copycat73
PostPosted: 11:52 - 24 Oct 2018    Post subject: Reply with quote
how many kilometers has bike done ?
when was the last valve clearance service done ?
caveat emptor
alexsobike
PostPosted: 12:52 - 24 Oct 2018    Post subject: Reply with quote
engine full service and maintenance was done recently
Robby
Dirty Old Man
PostPosted: 13:09 - 25 Oct 2018    Post subject: Reply with quote
You mentioned overheating, and getting up to 100c in a few seconds in your first post.
If it really is overheating, and getting that hot that fast, then you have a problem. Assuming it's a water cooled engine, is there any coolant in it?
tittymcarsefa...
PostPosted: 10:42 - 27 Oct 2018    Post subject: Reply with quote
Is there sufficient coolant in the system? shouldn't be getting hot that fast.
I agree that your battery sounds flat though, check your running voltage to make sure the bike's generator is putting out a charge (12-14v whilst running with voltage not steadily dropping) if it is then your battery is not storing the charge properly and should be replaced.
The last post was made 7 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 62.05 Kb
