GPZ500s Front wheel bearing issue please
Blockheads121
PostPosted: 19:58 - 27 Oct 2018    Post subject: GPZ500s Front wheel bearing issue please Reply with quote
Hi, I've replaced bearings before so just asking for any tips or knowledge of tools I can use to remove them on the GPZ.
The spacer only moves enough to expose a 1mm lip of inner bearing ring, so I can't get a good enough purchase using a drift to tap them out.
I have read on another forum that a mechanic had a rod of some description with a bent/hooked tooth on it.
Is there such a tool available?
Cheers!
Honda100H-MBX125-RG125-NSR125-KH125-Scooter-GSXR400-KX125-XT225-4X-XR400-DRZ400-FZ6-98ZX6F-2000ZX6R-GPZ500S
jaffa90
PostPosted: 00:04 - 28 Oct 2018    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=325892
Blockheads121
PostPosted: 00:15 - 28 Oct 2018    Post subject: Reply with quote
Cheers mate.
Blockheads121
PostPosted: 17:46 - 29 Oct 2018    Post subject: Reply with quote
Well, I took the front wheel to a local bike shop with two brand new bearings made in Japan, and they put me a used one in. Drop off and pick up job £25.00.
Same old whirling sound.
Pair a lizards busy robbing thier fellow man, and been at for a while by the looks of it - Should have known better.
I'le have to get another and take to a mates.
PostPosted: 19:10 - 29 Oct 2018    Post subject: Reply with quote
You're sure it isn't the speedo drive/cable?
Blockheads121
PostPosted: 19:16 - 29 Oct 2018    Post subject: Reply with quote
Oops, yeah, it could be.
Old bearings were knackered though, and one of the new replacements felt a bit rough - Slight knock when moving front wheel too.
Mechanic might have damaged it whacking it in - Or he's put an old one in.
I'le unplug it tomoz and have a listen.
The last post was made 7 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 47.5 Kb
