Seperating forks?
BenR
PostPosted: 18:07 - 27 Oct 2018    Post subject: Seperating forks? Reply with quote
Hi can anyone tell me how to split the forks on a yamaha trx850? Mainly the left hand leg I've done the right but the left one doesn't have the bolt in the bottom & I can't work out how to get the stanchion out cheers.
Hong Kong Phooey
PostPosted: 12:46 - 28 Oct 2018    Post subject: Reply with quote
Looking at the exploded parts diagram not help you? There are 2 versions of fork leg depending on year, the bike might have one of each.
https://www.oemmotorparts.com/oem5.asp?M=Yamaha&T=TRX%20%20850&Y=1996&L=YA-TRX-850&O=FRONT%20FORK&F=YA-TRX-850_bd&L2=YA-TRX-850_bd
Checking in this manual shows they're similar to almost all RWU forks, there should be a bottom bolt, shine a torch in to check and hope, nay pray that it's not been rounded.
https://www.google.co.uk/url?q=https://www.trx850.com/hosted/manual/trxmanual.pdf&sa=U&ved=2ahUKEwjCjoGeh6neAhVFLVAKHX1RCjYQFjAGegQIBxAB&usg=AOvVaw2d6Z1j1rI_YZZA7faOS25R
bikenut
PostPosted: 11:36 - 29 Oct 2018    Post subject: Reply with quote
parts diagrams are great ain't they !!!!!
nuts about bikes
Snod Blatter
PostPosted: 22:25 - 30 Oct 2018    Post subject: Reply with quote
Mine has bolts in the bottom of both, how else would the damper rod be held in place?
Also the bush on the stanchion will have to knock the seal out before you can separate the stanchion and the leg, just keep whacking it until it comes to bits (if you haven't tried that already!).
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
bikenut
PostPosted: 10:55 - 31 Oct 2018    Post subject: forks Reply with quote
on some yams and others, you need to fit a long hex drive down inside the fork to undo a threaded fastener that holds the forks together.....
nice one hong kong fweee for posting the oe manual will save that as it may come in useful sometime, as well as being an interesting read......see special tool section in the oe manual, the "T" bar and hex........and then look at the forks section.....
nuts about bikes
The last post was made 7 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 43.88 Kb
