| talkToTheHat |
| Sister Sledge |
| Hong Kong Phooey |
 - Super Spammer
 Posted: 14:17 - 31 Oct 2018 Post subject: |
I wouldn't be surprised of it was just the wiring from the old sensor broken up internally, somewhere up to the connector. It;s only this part which moves every time you turn the front wheels or the suspension moves. Over time, the wiring will break internally.
The sensors are so cheap, why not just fit one? I quite like a bit of warning before my pads give up the ghost. I'm also surprised a bodge like that passes an MOT, considering a pad wear sensor light not coming on with ignition, is now a fail. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| talkToTheHat |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| bugeye_bob |
 Posted: 17:20 - 01 Nov 2018 Post subject: |
| Monkeywrencher wrote: | | talkToTheHat wrote: | VW sensors are in the pads, current pads are pattern and have no sensors.
But the problem is that the cabling leading upto the pad is damaged somewhere. The ABS sensor is connected and appears to work. |
Theeres a repair loom available from VW, it splices in to the loom up under the scuttle somewhere, if your handy with a soldering iron and heatshrink it's not too hard. |
This, follow the wiring up, when you reach the big grommet carefully remove it,
You will then find a plug and socket, this is where you join the wires, if you look at the bottom of the loom close to where the pad plugs in, this will tell you what colours to join, if after you have the abs light on, then you know you got it wrong lol |
| talkToTheHat |
| jimspeed |
 jimspeed World Chat Champion
 - Super Spammer
| Monkeywrenche... |
 - Super Spammer
 Posted: 10:44 - 03 Nov 2018 Post subject: |
| Monkeywrencher wrote: | the pattern pads he has probably did come with seperate sensors |
Then buy another? At the very worst, just buy a set with new sensors, they're only £28 for all 4 sets!
https://brakeparts.co.uk/shop/VW/POLO/02-09/POLO%201.2%20&%201.4%20inc%2016V/Front%20-%20Brake%20Pads%20and%20Shoes
| Monkeywrencher wrote: | but the person who fitted them threw them away . |
Did they? How do you know this? Why would they throw them away?
| Monkeywrencher wrote: | and it's irrelevant, as the problem is with the wiring on the car |
Or possibly the wiring on what's left of the sensor harness, which is the part of the wire which normally fails, as it's the only part of the wiring which moves every time you turn the wheel. When I had this issue, I thought the fault was further up the wiring too, until I put a meter across the sensor pins and realised I could get it to go open circuit if I moved the sensor wires.
It's also worth noting that some faults actually need resetting with VCDS on a VAG car. I have a copy and a cable for my T5 Transporter.
You can certainly turn the light off with it, although warning lights should be checked to come on and go off for an MOT, so at some stage it should fail if not fixed anyway.
Maybe it's just me, but I prefer to fix the problem, not bodge it. This is such a cheap fix, why not just fix it? ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| talkToTheHat |
| Monkeywrenche... |
 - Super Spammer
 Posted: 12:32 - 05 Nov 2018 Post subject: |
You're not reading the thread properly.
The problem is that the plug (on the car wiring loom) that the sensor joins to is broken, this is common on VAG cars, even if the pad sensor wire was present there would be no way to attach it to the car.
why would someone throw a sensor sire away (or cut it off the pad)...
Because the was no way to attach it to the car and they didn't want it flapping loose? and how would i know? because he said it's not there
I already posted the correct fix, which is to replace the wiring loom for the sensor and abs sensor with a repair loom from VW which isn't a bodge.
Also The light doesn't need to illuminate for the mot it just has to not be on. |
Fair enough. Worth doing properly.
Are the warning lights not supposed to be seen to come on and go off again on ignition for an MOT now? That's certainly true for most, other wise people would just pull the bulb. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| Monkeywrenche... |
The last post was made 7 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
