| BenR |
 BenR World Chat Champion
| jaffa90 |
 jaffa90 World Chat Champion
| stinkwheel |
 Posted: 11:54 - 04 Nov 2018 Post subject: |
Use nuts, thread them loosely on a bit of string first.
Or treat the whole tank with POR15. Which you'll probably land up doing anyway. Any tank I've ever de-rusted like that has landed up with pinhole leaks very soon after.
Another thing to try is filling it up with white vinegar (often sold very cheaply as "non-brewed condiment) for a couple of days then rinsing it out with a pressure washer.
It would have to be pretty heavy rust for me to bother at all though. As long as it's not coming lose and blocking the fuel tap, I'd make sure I have a good filter fitted and avoid parking it for prolonged periods with an empty tank. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| doggone |
 doggone World Chat Champion
| andym |
 andym World Chat Champion
 Posted: 12:26 - 04 Nov 2018 Post subject: |
3 replies and no mention of electrolysis  |
| piazza |
 piazza Could Be A Chat Bot
| stinkwheel |
| BenR |
 Posted: 16:29 - 04 Nov 2018 Post subject: |
Thanks for the replies guys.  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| Robby |
 Robby Dirty Old Man
| WD Forte |
 WD Forte World Chat Champion
| jaffa90 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:31 - 04 Nov 2018 Post subject: |
Main ingredient of coke-a-cola is phosphoric acid...... its a fantastic solution for de-rusting stuff, and disolving teeth.....
I have to err with Stink though; I tend to use a lot of water rinces to get the crud and silt out first; then I might, depending on how bad, use electrolysis on a car-battery charger, then onto a couple of soaks with whit vinegar and rince.... Then POR15 treatment, following instructions ABSOLUTELY to the letter vis the rinces and turn times, and especially the drying and drying times and excessively extending the final cure of the liner treatment 'cure'.
If the tanks old, and or particularl;y bad, AND if you use electrolysis, you can very easily knock out any rust that's actually plugging pin holes... so you need the POR15 ultimately anyway to seal it back up!
If you DONT do a liner treatment, like POR15... then tends to be a fop, and the rust comes back, and you end up doing and doing over time after time, to 'not' save the time or a lot of money doing it once, and doing it right first time about.
Your call.... how rusty is the tank, and is it enough that the rust is clogging tap, pipes and cab-jets, yet? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| BTTD |
 BTTD World Chat Champion
| Moo. |
 Moo. World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 23:43 - 05 Nov 2018 Post subject: |
Tried them all but phosphoric stands out as the best/quickest in my experience, Get the 90% concentrate and dilute down to 10-15%. Probably works out cheaper than vinegar which I always found a bit weedy. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
The last post was made 7 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
