Honda CBF 500 alternative radiator
Gorilla_Pilot
PostPosted: 16:57 - 05 Nov 2018    Post subject: Honda CBF 500 alternative radiator Reply with quote
Hi all,
I am doing a complete rebuild on a Honda CBF 500 (2004 year), it was rusted to hell when i got it but everything is going fine in the restore but I got a little problem, the old radiator has more leaks than the titanic and even a profession radiator repair shop said to scrap it. The problem with that is a new Honda CBF 500 radiator costs around 300 to 500 pounds new.
https://www.wemoto.com/parts/picture/ho-19010-met-642
This is a bit of a slap in the face so i could either find a second hand radiator if i am lucky the bike is rarer than usual and the new radiator could break in a couple of years.
So my plan was to use a Honda CB 500 radiator as a alternative replacement, the CB radiator is slightly smaller by a little and some of the brackets are a little different but i could weld on some new brackets. The Cb 500 radiator is only 70 to 120 pound which is so much cheaper.
https://www.bikermart.co.uk/Honda-CB500-Radiator-1993~04
Dose anyone think this is possible or do you reckon ill overheat the bike, would love to hear your guys and girls though on the matter.
Suntan Sid
PostPosted: 17:11 - 05 Nov 2018    Post subject: Reply with quote
If you're worried about the cooling capacity and you're confident you can modify the brackets, how do the radiators from larger capacity Hondas compare to your original?
Gorilla_Pilot
PostPosted: 18:03 - 05 Nov 2018    Post subject: Reply with quote
Honda CB500 1993-04 (PC26/32) models.
Outer dimensions of the body: 335 x 180 x 29 mm
Honda CBF 500 2005
Outer Dimensions of the body: 350 * 180 * 30 mm
So it not to different in size its just the brackets that ill need to adjust.
The last post was made 7 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 36.05 Kb
