Painting a flywheel ok?
stevo as b4
PostPosted: 19:56 - 05 Nov 2018    Post subject: Painting a flywheel ok? Reply with quote
Just after any opinions on painting a flywheel or if it's a nutjob idea?
I had some light surface rusting on my steel flywheel, so I treated the rust and rubbed it back smooth being careful to not touch the pickup tab.
Is a couple of light dust coats of VHT silver as some protection a reasonable idea? I'd keep the pick up clear and as long as the flywheel doesn't rub on anything in use I can't see it being a problem?
PostPosted: 20:24 - 05 Nov 2018    Post subject: Reply with quote
What engine are we talking about?
If it's an external flywheel, sure, paint away.
PostPosted: 20:49 - 05 Nov 2018    Post subject: Reply with quote
You can buy special enamel paint called Glyptal which is specifically designed for painting the insides of engines.
It comes in red.
BusterGonads
PostPosted: 21:27 - 05 Nov 2018    Post subject: Reply with quote
It comes in red.
I'm just wondering if it could come off and cause blockages in oil galleries and ducts.
stevo as b4
PostPosted: 23:26 - 05 Nov 2018    Post subject: Reply with quote
Just a little steel scabby Kawasaki KMX external flywheel. But as you say if it was a nice stationary, agricultural or marine engine then a nicely painted flywheel would look cool.
I just want to protect it against future corrosion, so I might just dust a couple of coats of Wheel silver over it, after masking off the ignition pick up tab.
I suspect the bike had been used off road in a previous life and got water inside the generator cover, which is probably why the old stator looks like it's been to the bottom of the sea.
I've got a new Stator coming for £294, it's only about £40/50 more than getting a re-wind done and that'd take weeks at best.
The last post was made 7 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 43.58 Kb
