Street Triple electrical woes
Mr Hammers
PostPosted: 13:56 - 06 Nov 2018    Post subject: Street Triple electrical woes Reply with quote
Ok, so on way to work and bike just cuts out completely. Had issues the day before, hit the start button and everything goes dead. Left it for a minute, electrics come back on, but still won't turn over. Play around with clutch switch, sidestand, and then it fires up no problem. Ride to work and it's fine. Leave work and same agin, but again fires up eventually.
Get home, check under seat, everything looks ok, except terminals on battery are a little loose. Tighten them up, test it, all good, leave it for a while, still all good.
Fires up this morning no probs, but halfway round the roundabout engine just stops.
Still have electrics, but won't start. No clicking when hitting start button, nothing.
Battery is fine (putting out 12ish volts when checked yesterday, and 14ish when running) and it's not the starter or it wouldn't have stopped when running.
Anyone have an idea as to what it might be?
A Guide To Powerbands
bacon
PostPosted: 14:48 - 06 Nov 2018    Post subject: Reply with quote
Over 12.6v is what you want to see from a fully charged battery without the engine running.
Does sound like a loose or corroded connector, maybe even a bad earth?
PostPosted: 16:42 - 06 Nov 2018    Post subject: Reply with quote
Is it a Mk1 (2007-2009) Street triple? If so, have a look at this thread:
https://www.bikechatforums.com/viewtopic.php?t=325271
Also check the regulator rectifier, the battery and the ECM fuse.
Does the dash light up? Do the indicators and brake light work? If so, and nothing else works, then what happened to me has happened to you.
PostPosted: 16:54 - 06 Nov 2018    Post subject: Reply with quote
Is gonna be a horrible corroded connector ala MarJay or its managed to rub one of the wires against your frame around the headstock for maximum fun.
colink98
PostPosted: 17:19 - 06 Nov 2018    Post subject: Reply with quote
you know i'm having exactly the same issues with my Honda and i'm 100% certain it the connector between the wiring harness and the solenoid, which is giving an intermittent fault to the bikes +
result bike dies for no reason, all the lights go out and the revs drop to nothing, the engine still turns but make empty noise if i throttle.
give the connector a good wiggle and it springs back into life.
not sure if how the wiring is on the stripple... but maybe there is some common ground.
Ride it like you stole it.
Mr Hammers
PostPosted: 20:12 - 06 Nov 2018    Post subject: Reply with quote
Thanks for all the suggestions, all, much appreciated. Just got home ready to try them all out one by one, but glad to say i've now fixed it, and it was embarrassingly easy one. Embarassed
As i was about to start pulling everything off, i thought i'd see what the little black box thing under the seat was. I'd tugged at it this morning along with all the other wires/connectors when i broke down, but didn't occur to me to actually pull it apart and push it back together.
First thing i tried when i got home, and as soon as i did, it fired up straight after.
It's this thing here;
https://www.planetash.net/bcf/bastard.jpg
Not even sure what it's for, as in what it actually is connecting to what, but the main thing is that that is what was the problem.
Glad it was such a cheap and easy fix, but feel a bit daft not figuring it out at the time. Had a hour's walk home after work as well. That was shit. Fuck walking!
Anyway, again thanks everyone! Thumbs UpVery Happy
bacon
PostPosted: 20:25 - 06 Nov 2018    Post subject: Reply with quote
Do you have an alarm fitted?
Reason I ask is the wires are all black. Maybe it came loose and immobilised the bike.
owl
PostPosted: 20:54 - 06 Nov 2018    Post subject: Reply with quote
that looks remarkably like the immobiliser bypass plug my dealer gave me
Observation is the greatest source of wisdom.
Mr Hammers
PostPosted: 21:59 - 06 Nov 2018    Post subject: Reply with quote
I don't think so Smile
Well, it wasn't loose exactly, but there was some milky goo in there, which i think might be acf-50, from a couple of weekends ago. But whatever it's for, that seems to be cause of it Smile
Hmm, that's interesting...maybe that is what it is then? Thinking
bacon
PostPosted: 22:15 - 06 Nov 2018    Post subject: Reply with quote
The first gen street triple didn't have an immobiliser as standard, in which case maybe a previous owner fitted a alarm/immobiliser at some stage?
The second gen does have an immobiliser as standard. What year is your bike?
bacon
PostPosted: 22:18 - 06 Nov 2018    Post subject: Reply with quote
Could add some dielectric grease to the connectors, keep out moisture.
Mr Hammers
PostPosted: 22:26 - 06 Nov 2018    Post subject: Reply with quote
It's a 2008, bacon. It's had two previous owners, the guy i bought it from never mentioned anything, but the first one might've.
I'll have a look on t'ebay for some, cheers!
owl
PostPosted: 01:12 - 07 Nov 2018    Post subject: Reply with quote
Alarm blanking plug, like bacon said probably had one that was removed
https://www.ebay.co.uk/itm/TRIUMPH-DATATOOL-S4-OR-SYSTEM-3-THREE-ALARM-REMOVAL-PLUG-FOR-STREET-TRIPLE-675/201998597431
Mr Hammers
PostPosted: 21:46 - 07 Nov 2018    Post subject: Reply with quote
Think you're right, looks exactly the same. Thirty quid?!? Blimey.
Anyway, as it's there, and i've been thinking about fitting an alarm, maybe this one, but the blurb says;
"Datatool S4 Green - upgrades bikes or scooters already fitted with Thatcham approved Category 2 immobilisation to full Thatcham Category 1 status"
I'm not sure if it already has Cat 2 immobilisation...is there any way to check?
bacon
PostPosted: 22:03 - 07 Nov 2018    Post subject: Reply with quote
Owl, what led you to fitting an immobiliser bypass plug?? Was ithe stock immobiliser misbehaving? Or did you fit an alarm?
Pigeon
PostPosted: 22:07 - 07 Nov 2018    Post subject: Reply with quote
Most owners fit that blanking plug to get rid of useless factory option Datatool Alarms that leave them stranded (me too).
I certainly wouldn't buy a Datatool alarm again.
Keep the blanking plate, clean connectors, use dielectric grease on the outer ends of the plug (but not the connectors inside) to stop further water ingress.
bacon
PostPosted: 22:23 - 07 Nov 2018    Post subject: Reply with quote
Well Owl bought my street triple from me so I know it never had an alarm!
Curiosity about an old bike is all Smile
owl
PostPosted: 23:23 - 07 Nov 2018    Post subject: Reply with quote
Yeah don’t pay £30 for that Laughing
Asked my dealer for the bypass plug to test something and he gave me one for free.
Don’t know much about alarms sorry, you could try the street-triple.co.uk bunch, generally quite knowledgeable about this stuff.
@bacon yeah I had a few incidents where it seemed to be the immobiliser playing up, red light blinking on the dash and just wouldn’t start. As usual the moment I got the plug it stopped happening and then I got shot of it shortly after as I fancied a change.
bacon
PostPosted: 08:27 - 08 Nov 2018    Post subject: Reply with quote
/Thread hijack
Ah so you got rid? What did you get? The 1290? MT09SP?
owl
PostPosted: 12:37 - 08 Nov 2018    Post subject: Reply with quote
bacon wrote:
/Thread hijack
PM sent Thumbs Up
McJamweasel
BCF Junkie
PostPosted: 13:14 - 10 Nov 2018    Post subject: Reply with quote
That connector is an OE part of the wiring harness to blank off the connector that the alarm is fitted to. It's usually shrink wrapped, so the fact that it isn't suggests that an alarm has been fitted & removed at some point. It should be coated with dielectric grease, if it isn't then give it a coating and then cable tie it back on to stop it coming back off. Thumbs Up
The last post was made 7 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 108.13 Kb
