Removing f*cked mixture screw
stirlinggaz
PostPosted: 14:57 - 09 Nov 2018    Post subject: Removing f*cked mixture screw Reply with quote
Hi all,
Looks like previous owner of this tdr was a butcher by trade.
The air/fuel mixture screw is chewed to f*ck 😑
Is there a not so complicated way of removing one of these?
I though of grinding down the tip of of a screwdriver to "fatten" it up to try get some purchase or using a small left handed cobalt drill bit.
Any other suggestions?
These carbs are getting hard to get hold of second hand (mikuni vm26ss) so replacement is out of the question.
TIA
cheers,
GAZ
bugeye_bob
PostPosted: 17:40 - 09 Nov 2018    Post subject: Reply with quote
Im unsure how much room or how big the screw in question is, but would something like this work ?
https://www.toolstation.com/shop/p38732?r=googleshopping&rr=marin&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=EAIaIQobChMI7N7z6N_H3gIV2YjVCh2BDwrHEAQYBSABEgIcx_D_BwE
the smallest one.
jaffa90
PostPosted: 18:30 - 09 Nov 2018    Post subject: Reply with quote
Any pics, is the housing damaged?
Tankie
PostPosted: 20:41 - 09 Nov 2018    Post subject: Reply with quote
Strip the carb,then if you are still able to get a purchase on the offending screw heat the carb body up with HEATGUN , not a flame ,this should loosen the hold on the screw
Tankie
PostPosted: 20:49 - 09 Nov 2018    Post subject: Reply with quote
PostPosted: 22:04 - 09 Nov 2018    Post subject: Reply with quote
Do you know anyone who works in a lab who can get you concentrated nitric acid?
Conc. (not dilute) nitric acid will dissolve brass on contact into a dense cloud of noxious brown fumes and a boiling green liquid. It will passivate the aluminium doing minimal damage to it. Dilute nitric acid will turn your whole carb into an Escher painting.
This is NOT stuff to casually fuck about with mind. It's extremely nasty. As are some of the gasses and salts eluted from the copper/tin/trace heavy metals that get broken down. Effective though.
Hard to get hold of due to it being a key componant in the manufacture of high explosives.
bikenut
PostPosted: 12:17 - 10 Nov 2018    Post subject: Reply with quote
There's a manual on one of the recent threads, steering head races from memory, so save that !!!! then post the diagram/picture of the carb and the problem on your TD, or even the cmsnl exploded view, it may help.
nuts about bikes
stirlinggaz
PostPosted: 16:41 - 11 Nov 2018    Post subject: Reply with quote
hi,
unable to get ANY purchase on screw. tips chewed right off.
common problem caused by idiots using wrong tools.
So much so, theres a guy charges 60 quid to remove them on ebay Shocked
screw is in a blind hole btw so not sure heating it will help.
cheers,
GAZ
stirlinggaz
PostPosted: 16:42 - 11 Nov 2018    Post subject: Reply with quote
hi,
linky? or hint in general direction?
cheers,
GAZ
stirlinggaz
PostPosted: 16:46 - 11 Nov 2018    Post subject: Reply with quote
Hi,
for some reason whenever you reply, i get an image of that old guy from back to the future & then get scared, very scared.
cheers though,
GAZ
stirlinggaz
PostPosted: 16:51 - 11 Nov 2018    Post subject: Reply with quote
bugeye_bob wrote:
it would need to be a very small one, like 2 or 3mm
AND id be damn sccared of it snapping in situ, causing carb to be scrap.
cheers,
GAZ
it would eedc to be a very smal one, like 2 or 3mm
Tankie
PostPosted: 18:24 - 11 Nov 2018    Post subject: Reply with quote
Have you got a mixture screw out so you can see what the proper undamaged item looks like to give an idea of how much material you have to play with
Self centering drill bits are available to help you centre up the hole, I take it the offending screw is recessed, I don't think a left handed bit will help as these bloody screws tend to lock themselves in, heat will help as this will expand the casting a little.
The carb should be put in a machine vice and drilled with a quality pillar drill, this is no easy task, I think a lot of machinists would baulk at this kind of job
bikenut
PostPosted: 10:52 - 12 Nov 2018    Post subject: lazy bugger Reply with quote
https://www.oemmotorparts.com/oem5.asp?M=Yamaha&T=TRX%20%20850&Y=1996&L=YA-TRX-850&O=FRONT%20FORK&F=YA-TRX-850_bd&L2=YA-TRX-850_bd
https://www.google.co.uk/url?q=https://www.trx850.com/hosted/manual/trxmanual.pdf&sa=U&ved=2ahUKEwjCjoGeh6neAhVFLVAKHX1RCjYQFjAGegQIBxAB&usg=AOvVaw2d6Z1j1rI_YZZA7faOS25R
you know what your bike is so go and find it on cmsnl, post a pic of the carb diagram and dont be so lazy, be more self reliant
post a picture of what you see so we can, we may be able to help more that way.
nuts about bikes
doombug11
PostPosted: 01:09 - 19 Nov 2018    Post subject: Reply with quote
I got one out by soaking it in WD40, then used a hand impact driver to get the bit to bite down on the fucked screw and get a enough purchase to loosen it.
1999 CBR900RR, 1984 CM200 (previously 125)
PostPosted: 01:54 - 19 Nov 2018    Post subject: Reply with quote
Concentrated nitric acid sounds more fun. (Hello GCHQ and MI5 Laughing)
https://www.youtube.com/watch?v=pJSQq494oV4
doombug11
PostPosted: 02:07 - 19 Nov 2018    Post subject: Reply with quote
Yer man, you know as soon as you typed 'Nitric Acid' the computer screens at GCHQ just lit up Laughing
garth
PostPosted: 05:13 - 19 Nov 2018    Post subject: Reply with quote
Don't do what I did and heat the carb enough to melt the float though. That's a proper dickhead move.
bikenut
PostPosted: 11:02 - 19 Nov 2018    Post subject: screw screwed Reply with quote
\any pics, of the screw or the float even !
nuts about bikes
Robby
Dirty Old Man
PostPosted: 16:03 - 24 Nov 2018    Post subject: Reply with quote
You could drill a hole and bash in a small torx bit, which should allow you to unscrew it.
If you are going to drill the whole screw out, make sure you have a new screw to understand what shape the hole is, and how deep you can drill. The metals are very soft, so drilling mistakes happen very quickly.
redeem ouzzer
PostPosted: 09:51 - 25 Nov 2018    Post subject: Reply with quote
^^this
I’ve done the same on pilot jets that wouldn’t shift, although they are a bit easier because they tend to self centre the drill bit.
Be a REAL MAN!
stirlinggaz
PostPosted: 08:18 - 30 Nov 2018    Post subject: Re: lazy bugger Reply with quote
hi,
wasnt being lazy, just had problems uploadling exploded diagram of carb, which is a mikuni tm26 s/s1 & im sorry but i found your links to be of no use to me as i couldnt find any listing of a TDR125, perhaps you can?
MAYBE I was being lazy, hmmmm. but it is 7am and i havnt been to bed yet.
oh & im aware of what a decent oem mixtrure screw looks like, i have one here Wink
cheers,
GAZ
bikenut
PostPosted: 11:14 - 01 Dec 2018    Post subject: Reply with quote
part number 30 in the cmsnl view ?
If this is the correct view then the screw looks quite get at able ?
nuts about bikes
bugeye_bob
PostPosted: 15:18 - 01 Dec 2018    Post subject: Reply with quote
https://www.ebay.co.uk/i/153000583623?chn=ps . . .
stirlinggaz
PostPosted: 10:04 - 03 Dec 2018    Post subject: Reply with quote
Hi,
Yes it's part no.30 but it sits a few mm (at least 4 or 5mm) down inside a blind hole.
Can hardly see tip.of screw 😑 especially since tip of screw is gone Rolling Eyes
cheers,
GAZ
stirlinggaz
PostPosted: 11:51 - 03 Dec 2018    Post subject: Reply with quote
Hi,
This was my original thought as had lots of success with cobalt bits.
BUT smallest in that set is 2mm, snappy snappy bit = f*cked carb.
Might as well give it a go though Thumbs Up
cheers,
GAZ
The last post was made 7 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 131.01 Kb
