Suzuki GS550 Piston Dimensions
ian Jamieson
PostPosted: 14:54 - 08 Nov 2018    Post subject: Suzuki GS550 Piston Dimensions Reply with quote
Hoping that someone can help me with the dimensions of a Suzuki GS550 piston 1977-79 models. Possible that I could use it in a non Suzuki application but need the dimensions.
The standard bore is I think 56mm but if someone can confirm that would be great. Need the following
Pin Diameter
Distance from centre of pin to top edge of piston
Distance from centre of pin to top of piston
Overall height of piston.
Thanks
p65crosser
A100man
PostPosted: 00:13 - 10 Nov 2018    Post subject: Reply with quote
Obvious Q but if you're replacing can't you measure existing? Honda CB500F from 70s is also 56mm bore and 2 valve. Honda stuff seems to be more generally available too..
OR find a piston within a mm or so and get your barrels bored to suit.
Riejufixing
PostPosted: 00:47 - 10 Nov 2018    Post subject: Reply with quote
EURGH!!!!
ian Jamieson
PostPosted: 01:00 - 10 Nov 2018    Post subject: Gs550 pistons Reply with quote
I am trying to find alternative pistons for a Benelli 500 four. Standard bore is 56mm but Honda pistons are only 9.5 to 1 whereas Benelli are 10.25 to 1. Looking at possibility of Suzuki pistons which are 56mm but need to know other dimensions to see if the y fit without hitting valves or head etc. Honda race pistons are very expensive but GS pistons look to have a decent crown on them for good high cr so if dimensions fir could be a viable alternative to Benelli parts which are not available new.
Regards
Ian
p65crosser
temeluchus
PostPosted: 01:05 - 10 Nov 2018    Post subject: Reply with quote
maybe someone on Oldskoolsuzuki would know?
A100man
PostPosted: 12:20 - 10 Nov 2018    Post subject: Reply with quote
Riejufixing wrote:
EURGH!!!!
Come on, you lived in brussel county , you must be used to an agricultural bodge or two.. Wink
Riejufixing
PostPosted: 13:57 - 10 Nov 2018    Post subject: Reply with quote
Yes, but it would be much "nicer" to do the bodge on the piston!
A100man
PostPosted: 16:51 - 10 Nov 2018    Post subject: Reply with quote
Might be in need of a rebore anyway.. Confused
The last post was made 7 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 56.09 Kb
